Matt DeVillier has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/80750?usp=email )
Change subject: soc/intel/common/lpc: Don't open a window for unassigned resources ......................................................................
Don't attempt to open a PMIO window for a resource which doesn't have the IORESOURCE_ASSIGNED flag set, since there is no point in doing so and there's a high likelihood that the base address is 0, which will throw an error.
TEST=build/boot purism/librem_cnl (Mini v2), ensure no errors in cbmem log for attempting to open a PMIO window for unaassigned resources with base address 0.
Change-Id: Ifba14a8f134ba12d5f5e9fdbac775d4f82b4c4de Signed-off-by: Matt DeVillier matt.devillier@gmail.com --- M src/soc/intel/common/block/lpc/lpc.c 1 file changed, 1 insertion(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/50/80750/1
diff --git a/src/soc/intel/common/block/lpc/lpc.c b/src/soc/intel/common/block/lpc/lpc.c index b27e09e9..e805035 100644 --- a/src/soc/intel/common/block/lpc/lpc.c +++ b/src/soc/intel/common/block/lpc/lpc.c @@ -91,7 +91,7 @@ return;
for (res = dev->resource_list; res; res = res->next) { - if (res->flags & IORESOURCE_IO) + if ((res->flags & IORESOURCE_IO) && (res->flags & IORESOURCE_ASSIGNED)) lpc_open_pmio_window(res->base, res->size); } pch_lpc_set_child_resources(dev);
