Paul Menzel (paulepanter@users.sourceforge.net) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/3183
commit a33685814867072f2680839a05a794a979e9fe53 Author: Paul Menzel paulepanter@users.sourceforge.net Date: Fri May 3 12:23:39 2013 +0200
Intel BD82x6x: LPC: Unify I/O APIC setup
Remove local copies of reading and writing I/O APIC registers by using already available functions.
This change is similar to
commit db4f875a412e6c41f48a86a79b72465f6cd81635 Author: Kyösti Mälkki kyosti.malkki@gmail.com Date: Tue Jan 31 17:24:12 2012 +0200
IOAPIC: Divide setup_ioapic() in two parts.
Reviewed-on: http://review.coreboot.org/300
and
commit e614353194c712a40aa8444a530b2062876eabe3 Author: Kyösti Mälkki kyosti.malkki@gmail.com Date: Tue Feb 26 17:24:41 2013 +0200
Unify setting 82801a/b/c/d IOAPIC ID
Reviewed-on: http://review.coreboot.org/2532
and uses `io_apic_read()` and `io_apic_write()` too.
Change-Id: I4478b1902d09061ca1db8eab6b71fef388c7a74c Signed-off-by: Paul Menzel paulepanter@users.sourceforge.net --- src/southbridge/intel/bd82x6x/lpc.c | 65 +++++++++++++++++++------------------ 1 file changed, 34 insertions(+), 31 deletions(-)
diff --git a/src/southbridge/intel/bd82x6x/lpc.c b/src/southbridge/intel/bd82x6x/lpc.c index 7bcadc9..3e5b653 100644 --- a/src/southbridge/intel/bd82x6x/lpc.c +++ b/src/southbridge/intel/bd82x6x/lpc.c @@ -39,43 +39,43 @@
typedef struct southbridge_intel_bd82x6x_config config_t;
-static void pch_enable_apic(struct device *dev) +/** + * Enable ACPI I/O range. + * + * @param dev PCI device with ACPI and PM BAR's + */ +static void pch_enable_acpi(struct device *dev) +{ + /* Set ACPI base address (I/O space). */ + /* pci_write_config32(dev, PMBASE, (PMBASE_ADDR | 1)); // not needed? */ + + /* Enable ACPI I/O range decode and ACPI power management. */ + pci_write_config8(dev, ACPI_CNTL, ACPI_EN); +} + +/** + * Set miscellanous static southbridge features. + * + * @param dev PCI device with I/O APIC control registers + */ +static void pch_enable_ioapic(struct device *dev) { int i; u32 reg32; - volatile u32 *ioapic_index = (volatile u32 *)(IO_APIC_ADDR); - volatile u32 *ioapic_data = (volatile u32 *)(IO_APIC_ADDR + 0x10); - - /* Enable ACPI I/O and power management. - * Set SCI IRQ to IRQ9 - */ - pci_write_config8(dev, ACPI_CNTL, 0x80);
- *ioapic_index = 0; - *ioapic_data = (2 << 24); + set_ioapic_id(IO_APIC_ADDR, 0x02);
/* affirm full set of redirection table entries ("write once") */ - *ioapic_index = 1; - reg32 = *ioapic_data; - *ioapic_index = 1; - *ioapic_data = reg32; - - *ioapic_index = 0; - reg32 = *ioapic_data; - printk(BIOS_DEBUG, "Southbridge APIC ID = %x\n", (reg32 >> 24) & 0x0f); - if (reg32 != (2 << 24)) - die("APIC Error\n"); - - printk(BIOS_SPEW, "Dumping IOAPIC registers\n"); - for (i=0; i<3; i++) { - *ioapic_index = i; - printk(BIOS_SPEW, " reg 0x%04x:", i); - reg32 = *ioapic_data; - printk(BIOS_SPEW, " 0x%08x\n", reg32); - } + reg32 = io_apic_read(IO_APIC_ADDR, 0x01); + io_apic_write(IO_APIC_ADDR, reg32); + + printk(BIOS_SPEW, "IOAPIC: Dumping registers\n"); + for (i = 0; i < 3; i++) + printk(BIOS_SPEW, " reg 0x%04x: 0x%08x\n", i, + io_apic_read(ioapic_base, i));
- *ioapic_index = 3; /* Select Boot Configuration register. */ - *ioapic_data = 1; /* Use Processor System Bus to deliver interrupts. */ + io_apic_write(IO_APIC_ADDR, 0x03, /* Select Boot Configuration register. */ + 0x01); /* Use Processor System Bus to deliver interrupts. */ }
static void pch_enable_serial_irqs(struct device *dev) @@ -537,8 +537,11 @@ static void lpc_init(struct device *dev) /* Set the value for PCI command register. */ pci_write_config16(dev, PCI_COMMAND, 0x000f);
+ /* ACPI initialization. */ + pch_enable_acpi(dev); + /* IO APIC initialization. */ - pch_enable_apic(dev); + pch_enable_ioapic(dev);
pch_enable_serial_irqs(dev);
