Hello build bot (Jenkins), Andrey Petrov, Patrick Georgi, Martin Roth, Angel Pons,
https://review.coreboot.org/c/coreboot/+/39427
to look at the new patch set (#26).
Change subject: mb/ocp/tiogapass: use common GPIO config [WIP] ......................................................................
According to changes in the soc/xeon_sp code [1,2], server motherboards with Lewisburg PCH can use the common pad configuration from soc/intel/ common, using macros PAD_CFG_ instead of the FSP-style GPIO definitions.
This patch adds the GPIO configuration, which has the format required by the driver from common/gpio. The data for this was taken from the inteltool register dump with AMI firmware and converted to macros using intelp2m (pch-pads-parser) [3,4].
[1] https://review.coreboot.org/c/coreboot/+/39425 [2] https://review.coreboot.org/c/coreboot/+/39428 [3] https://review.coreboot.org/c/coreboot/+/35643 [4] https://github.com/maxpoliak/pch-pads-parser
Change-Id: I818d040fa33f3e7b94b73c9bbbafca5df424616d Signed-off-by: Maxim Polyakov max.senia.poliak@gmail.com --- M src/mainboard/ocp/tiogapass/Makefile.inc M src/mainboard/ocp/tiogapass/bootblock.c A src/mainboard/ocp/tiogapass/gpio.h M src/mainboard/ocp/tiogapass/ramstage.c M src/mainboard/ocp/tiogapass/romstage.c 5 files changed, 619 insertions(+), 12 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/27/39427/26
