Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/60116 )
Change subject: soc/amd/common/include/spi: fix SPI_FIFO_LAST_BYTE define ......................................................................
The last byte of the SPI FIFO SPI_FIFO_LAST_BYTE is at offset 0xc6 of the SPI controller's MMIO region for Stoneyridge and Picasso. Both SPI_FIFO_LAST_BYTE and SPI_FIFO_DEPTH had an off-by-one error that ended up cancelling out each other, so the resulting value for SPI_FIFO_DEPTH isn't changed.
TEST=Timeless build results in identical image for Mandolin.
Signed-off-by: Felix Held felix-coreboot@felixheld.de Change-Id: I1676be902ccf57e2e9f69d81251b4315866a0628 Reviewed-on: https://review.coreboot.org/c/coreboot/+/60116 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Raul Rangel rrangel@chromium.org --- M src/soc/amd/common/block/include/amdblocks/spi.h 1 file changed, 2 insertions(+), 2 deletions(-)
Approvals: build bot (Jenkins): Verified Raul Rangel: Looks good to me, approved
diff --git a/src/soc/amd/common/block/include/amdblocks/spi.h b/src/soc/amd/common/block/include/amdblocks/spi.h index 5c3bd0e..4efed68 100644 --- a/src/soc/amd/common/block/include/amdblocks/spi.h +++ b/src/soc/amd/common/block/include/amdblocks/spi.h @@ -71,8 +71,8 @@ #define SPI_RD4DW_EN_HOST BIT(15)
#define SPI_FIFO 0x80 -#define SPI_FIFO_LAST_BYTE 0xc7 -#define SPI_FIFO_DEPTH (SPI_FIFO_LAST_BYTE - SPI_FIFO) +#define SPI_FIFO_LAST_BYTE 0xc6 +#define SPI_FIFO_DEPTH (SPI_FIFO_LAST_BYTE - SPI_FIFO + 1)
struct spi_config { /*
