Nico Huber has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/43444 )
Change subject: mb/qemu/fw_cfg: Add info messages about (un)found files ......................................................................
Change-Id: I1431d569c57634277ea5cf7feb352419db432b44 Signed-off-by: Nico Huber nico.huber@secunet.com --- M src/mainboard/emulation/qemu-i440fx/fw_cfg.c 1 file changed, 2 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/44/43444/1
diff --git a/src/mainboard/emulation/qemu-i440fx/fw_cfg.c b/src/mainboard/emulation/qemu-i440fx/fw_cfg.c index 536e775..6ee6863 100644 --- a/src/mainboard/emulation/qemu-i440fx/fw_cfg.c +++ b/src/mainboard/emulation/qemu-i440fx/fw_cfg.c @@ -74,9 +74,11 @@ if (strcmp(file->name, name) == 0) { file->size = be32_to_cpu(file->size); file->select = be16_to_cpu(file->select); + printk(BIOS_INFO, "QEMU: firmware config: Found '%s'\n", name); return 0; } } + printk(BIOS_INFO, "QEMU: firmware config: Couldn't find '%s'\n", name); return -1; }
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43444 )
Patch Set 1: Code-Review+1
(2 comments)
https://review.coreboot.org/c/coreboot/+/43444/1//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/43444/1//COMMIT_MSG@7 PS1, Line 7: un not
https://review.coreboot.org/c/coreboot/+/43444/1//COMMIT_MSG@8 PS1, Line 8: What's the rationale behind this change?
Patch Set 1:
Ack
Hello build bot (Jenkins), Angel Pons,
Change subject: mb/qemu/fw_cfg: Add info messages about (not) found files ......................................................................
Print some more information at BIOS_INFO, like our CBFS code does.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/44/43444/2
Nico Huber has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43444 )
Patch Set 2:
not
Done
Patch Set 2: Code-Review+2
Nico Huber has submitted this change. ( https://review.coreboot.org/c/coreboot/+/43444 )
Change-Id: I1431d569c57634277ea5cf7feb352419db432b44 Signed-off-by: Nico Huber nico.huber@secunet.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/43444 Reviewed-by: Angel Pons th3fanbus@gmail.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/mainboard/emulation/qemu-i440fx/fw_cfg.c 1 file changed, 2 insertions(+), 0 deletions(-)
