Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/62605 )
Change subject: ec/starlabs: Store the correct value for KLSE when suspending ......................................................................
The current code will read the raw value from the EC, which doesn't match the respective setting in CMOS.
Switch argument will store the correct value.
Signed-off-by: Sean Rhodes sean@starlabs.systems Change-Id: I62e0fc3b6fcae72f2d8eacf37a390b4e4b1f0783 Reviewed-on: https://review.coreboot.org/c/coreboot/+/62605 Reviewed-by: Angel Pons th3fanbus@gmail.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/ec/starlabs/merlin/acpi/suspend.asl 1 file changed, 15 insertions(+), 2 deletions(-)
diff --git a/src/ec/starlabs/merlin/acpi/suspend.asl b/src/ec/starlabs/merlin/acpi/suspend.asl index 9f88a05..a753ba6 100644 --- a/src/ec/starlabs/merlin/acpi/suspend.asl +++ b/src/ec/starlabs/merlin/acpi/suspend.asl @@ -26,8 +26,21 @@
_SB.PCI0.LPCB.FLKC = _SB.PCI0.LPCB.EC.ECRD (RefOf (_SB.PCI0.LPCB.EC.FLKE)) - _SB.PCI0.LPCB.KLSC = - _SB.PCI0.LPCB.EC.ECRD (RefOf (_SB.PCI0.LPCB.EC.KLSE)) + + Switch (ToInteger (_SB.PCI0.LPCB.EC.ECRD (RefOf (_SB.PCI0.LPCB.EC.KLSE)))) + { + // 0x00 == Disabled == 0x00 + // 0xdd == Enabled == 0x01 + Case (0x00) + { + _SB.PCI0.LPCB.KLSC = 0x00 + } + Case (0xdd) + { + _SB.PCI0.LPCB.KLSC = 0x01 + } + } + _SB.PCI0.LPCB.KLBC = _SB.PCI0.LPCB.EC.ECRD (RefOf (_SB.PCI0.LPCB.EC.KLBE)) }
