Paul Menzel has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/51177 )
Change subject: libpayload: Enable LTO by default ......................................................................
Link Time Optimization (LTO) decreases the size of the binaries, which is important for firmware with small flash ROM chip sizes. Using LTO might result in longer build times, which is not an issue for a small project like libpayload.
Therefore, enable LTO by default.
Change-Id: I4bc58034ea8a9510ddc08d61d19e75a7c6f9cbc7 Signed-off-by: Paul Menzel pmenzel@molgen.mpg.de --- M payloads/libpayload/Kconfig 1 file changed, 1 insertion(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/77/51177/1
diff --git a/payloads/libpayload/Kconfig b/payloads/libpayload/Kconfig index 7a502b5..ae4d1d8 100644 --- a/payloads/libpayload/Kconfig +++ b/payloads/libpayload/Kconfig @@ -81,7 +81,7 @@
config LTO bool "Use link time optimization (LTO)" - default n + default y depends on COMPILER_GCC help Compile with link time optimization. This can often decrease the
