Attention is currently required from: Paul Menzel, Nick Vaccaro, Scott Chao. Hello build bot (Jenkins), Tim Wawrzynczak, Nick Vaccaro,
https://review.coreboot.org/c/coreboot/+/60270
Change subject: mb/google/brya/var/gimble: Decrease touchscreen T3 timing to 200ms ......................................................................
We set T3 as 300ms to meet Elan's spec, but the resume/suspend times are greater than 500ms, which is the spec for Chromebooks. The actual kernel timing has been measured, and given the ACPI delay after deasserting reset in addition to the delay until the kernel driver accesses the device, delaying only 200ms in the ACPI method is also sufficient to meet the 300ms requirement.
BUG=b:210772498 BRANCH=none TEST=build and test touchscreen function on DUT. TEST=suspend, wake DUT and check touchscreen function.
Signed-off-by: Scott Chao scott_chao@wistron.corp-partner.google.com Change-Id: I4bb4eda09686cb59b6e19c741aa2b78d84332d2a --- M src/mainboard/google/brya/variants/gimble/overridetree.cb M src/mainboard/google/brya/variants/gimble4es/overridetree.cb 2 files changed, 2 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/70/60270/4
