Joel Kitching has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/31298
Change subject: vboot: rename VB2_DISABLE_DEVELOPER_MODE ......................................................................
Rename VB2_DISABLE_DEVELOPER_MODE to VB2_CONTEXT_DISABLE_DEVELOPER_MODE. See CL in CQ-DEPEND for details.
BUG=b:124141368 TEST=Build locally CQ-DEPEND=CL:1460645 BRANCH=none
Change-Id: Ib9754425dc2f346e8edac584c4d076d13ae31d2d Signed-off-by: Joel Kitching kitching@google.com --- M src/security/vboot/vboot_logic.c 1 file changed, 1 insertion(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/98/31298/1
diff --git a/src/security/vboot/vboot_logic.c b/src/security/vboot/vboot_logic.c index 1b24160..afed5cc 100644 --- a/src/security/vboot/vboot_logic.c +++ b/src/security/vboot/vboot_logic.c @@ -326,7 +326,7 @@ if (get_recovery_mode_switch()) { ctx.flags |= VB2_CONTEXT_FORCE_RECOVERY_MODE; if (IS_ENABLED(CONFIG_VBOOT_DISABLE_DEV_ON_RECOVERY)) - ctx.flags |= VB2_DISABLE_DEVELOPER_MODE; + ctx.flags |= VB2_CONTEXT_DISABLE_DEVELOPER_MODE; }
if (IS_ENABLED(CONFIG_VBOOT_WIPEOUT_SUPPORTED) &&
Julius Werner has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/31298 )
Patch Set 1: Code-Review+2
Joel Kitching has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/31298 )
Patch Set 1:
Wait for vboot commit and coreboot vboot sub-repo uprev.
Patrick Georgi has submitted this change and it was merged. ( https://review.coreboot.org/c/coreboot/+/31298 )
Change-Id: Ib9754425dc2f346e8edac584c4d076d13ae31d2d Signed-off-by: Joel Kitching kitching@google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/31298 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Julius Werner jwerner@chromium.org --- M src/security/vboot/vboot_logic.c 1 file changed, 1 insertion(+), 1 deletion(-)
Approvals: build bot (Jenkins): Verified Julius Werner: Looks good to me, approved
diff --git a/src/security/vboot/vboot_logic.c b/src/security/vboot/vboot_logic.c index 8c3ba80..7ab9824 100644 --- a/src/security/vboot/vboot_logic.c +++ b/src/security/vboot/vboot_logic.c @@ -331,7 +331,7 @@ if (get_recovery_mode_switch()) { ctx.flags |= VB2_CONTEXT_FORCE_RECOVERY_MODE; if (IS_ENABLED(CONFIG_VBOOT_DISABLE_DEV_ON_RECOVERY)) - ctx.flags |= VB2_DISABLE_DEVELOPER_MODE; + ctx.flags |= VB2_CONTEXT_DISABLE_DEVELOPER_MODE; }
