Attention is currently required from: Jason Glenesk, Raul Rangel, Martin Roth, Fred Reitberger, Karthik Ramasubramanian, Felix Held.
Hello build bot (Jenkins), Jason Glenesk, Raul Rangel, Matt DeVillier, Jason Glenesk, Martin Roth, Fred Reitberger, Tim Van Patten, Felix Held,
https://review.coreboot.org/c/coreboot/+/74334
Change subject: soc/amd/common/block/lpc/spi_dma: Leverage CBFS_CACHE when using SPI DMA ......................................................................
CBFS library performs memory mapped access of the files during loading, verification and de-compression. Even with MTRRs configured correctly, first few file access through memory map are taking longer times to load. Update the SPI DMA driver to load the files into CBFS cache, so that they can be verified and de-compression with less overhead. This saves ~60 ms in boot time.
BUG=None TEST=Build Skyrim BIOS image and boot to OS. Observe ~60 ms improvement with the boot time. Performing additional test to confirm there are no regressions. Before: ======= 970:loading FSP-M 15:starting LZMA decompress (ignore for x86) 760,906 (60,035) 16:finished LZMA decompress (ignore for x86) 798,787 (37,881) 8:starting to load ramstage 17:starting LZ4 decompress (ignore for x86) 1,050,093 (13,790) 18:finished LZ4 decompress (ignore for x86) 1,054,086 (3,993) 971:loading FSP-S 17:starting LZ4 decompress (ignore for x86) 1,067,778 (3,313) 18:finished LZ4 decompress (ignore for x86) 1,068,022 (244) 90:starting to load payload 17:starting LZ4 decompress (ignore for x86) 1,302,155 (11,285) 18:finished LZ4 decompress (ignore for x86) 1,303,938 (1,783)
After: ====== 970:loading FSP-M 15:starting LZMA decompress (ignore for x86) 709,542 (12,178) 16:finished LZMA decompress (ignore for x86) 739,379 (29,837) 8:starting to load ramstage 17:starting LZ4 decompress (ignore for x86) 1,001,316 (12,368) 18:finished LZ4 decompress (ignore for x86) 1,001,971 (655) 971:loading FSP-S 17:starting LZ4 decompress (ignore for x86) 1,016,514 (3,031) 18:finished LZ4 decompress (ignore for x86) 1,016,722 (207) 90:starting to load payload 17:starting LZ4 decompress (ignore for x86) 1,244,602 (10,313) 18:finished LZ4 decompress (ignore for x86) 1,244,831 (228)
Change-Id: Ie30b6324f9977261c60e55ed509e979ef290f1f1 Signed-off-by: Karthikeyan Ramasubramanian kramasub@google.com --- M src/soc/amd/common/block/lpc/spi_dma.c M src/soc/amd/mendocino/Kconfig 2 files changed, 88 insertions(+), 17 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/34/74334/5
