Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/58117 )
Change subject: mb/google/guybrush: Override SPI Fast speeds ......................................................................
Add support to override SPI fast speeds based on board version from both bootblock and verstage. Overrides apply for Guybrush only and SPI speed is overridden from 66 MHz to 100 MHz starting board version 4. This will help to improve the boot time on board version by ~60 ms and still allow the old boards to boot with 66 MHz.
BUG=b:199779306 TEST=Build and boot to OS in Guybrush. Perform S5->S0, G3->S0, warm reset and suspend/resume cycles for 50 iterations each.
Signed-off-by: Karthikeyan Ramasubramanian kramasub@google.com Change-Id: I5bf03ab8772f27aca346589e9c5662caf014d0d2 Reviewed-on: https://review.coreboot.org/c/coreboot/+/58117 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Felix Held felix-coreboot@felixheld.de Reviewed-by: Raul Rangel rrangel@chromium.org --- M src/mainboard/google/guybrush/Kconfig M src/mainboard/google/guybrush/Makefile.inc M src/mainboard/google/guybrush/chromeos.c 3 files changed, 26 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Felix Held: Looks good to me, approved Raul Rangel: Looks good to me, approved
diff --git a/src/mainboard/google/guybrush/Kconfig b/src/mainboard/google/guybrush/Kconfig index c259d25..e5f1382 100644 --- a/src/mainboard/google/guybrush/Kconfig +++ b/src/mainboard/google/guybrush/Kconfig @@ -111,6 +111,22 @@ config ALT_SPI_SPEED default 0 # 66MHz
+config OVERRIDE_EFS_SPI_SPEED + int + default 3 if EM100 + default 4 # 100MHz + help + Override EFS SPI Speed Configuration to be applied based on certain + board version. + +config OVERRIDE_EFS_SPI_SPEED_MIN_BOARD + hex + default 0x4 if BOARD_GOOGLE_GUYBRUSH + default 0xffffffff + help + Minimum board version starting which the Override EFS SPI Speed + configuration has to be applied. + endif # !EM100
config VARIANT_DIR diff --git a/src/mainboard/google/guybrush/Makefile.inc b/src/mainboard/google/guybrush/Makefile.inc index f3140dd..6bc3288 100644 --- a/src/mainboard/google/guybrush/Makefile.inc +++ b/src/mainboard/google/guybrush/Makefile.inc @@ -1,6 +1,7 @@ # SPDX-License-Identifier: GPL-2.0-or-later
bootblock-y += bootblock.c +bootblock-$(CONFIG_CHROMEOS) += chromeos.c
ifneq ($(wildcard $(MAINBOARD_BLOBS_DIR)/APCB_CZN_D4.bin),) $(info APCB sources present.) diff --git a/src/mainboard/google/guybrush/chromeos.c b/src/mainboard/google/guybrush/chromeos.c index c1621d9..a43b303 100644 --- a/src/mainboard/google/guybrush/chromeos.c +++ b/src/mainboard/google/guybrush/chromeos.c @@ -1,5 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0-or-later */
+#include <amdblocks/spi.h> #include <baseboard/gpio.h> #include <boardid.h> #include <boot/coreboot_tables.h> @@ -36,3 +37,11 @@ /* EC is trusted if not in RW. */ return !gpio_get(GPIO_EC_IN_RW); } + +void mainboard_spi_fast_speed_override(uint8_t *fast_speed) +{ + uint32_t board_ver = board_id(); + + if (board_ver >= CONFIG_OVERRIDE_EFS_SPI_SPEED_MIN_BOARD) + *fast_speed = CONFIG_OVERRIDE_EFS_SPI_SPEED; +}
