Attention is currently required from: Christian Walter, Patrick Rudolph. Hello build bot (Jenkins), Subrata Banik, Christian Walter, Nick Vaccaro, Patrick Rudolph,
https://review.coreboot.org/c/coreboot/+/61721
Change subject: drivers/i2c/tpm/cr50: Add support to get and set BOARD_CFG register ......................................................................
The cr50 BOARD_CFG register has a bit to support extended interrupt pulses to the PCH. There is support for this in the SPI driver, but not in the I2C driver, and it may be required for some boards, therefore port the logic over to the I2C driver.
Signed-off-by: Tim Wawrzynczak twawrzynczak@chromium.org Change-Id: I9fcfed9fa133db2560c4a855376d249e865c1335 --- M src/drivers/i2c/tpm/cr50.c M src/drivers/i2c/tpm/tpm.h 2 files changed, 82 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/21/61721/6
