Martin Roth has submitted this change. ( https://review.coreboot.org/c/coreboot/+/51077 )
Change subject: soc/amd/common/blocks/lpc: Explicitly disable serial IRQ ......................................................................
The serirq enable bit defaults to true, so if we want it disabled, we need to explicitly disable it.
BUG=b:180631748 TEST=Boot majolica and see spurious IRQ 9 gone.
Signed-off-by: Raul E Rangel rrangel@chromium.org Change-Id: I7f1e18f836f29cb75334dd88c91ad047f5bdfb10 Reviewed-on: https://review.coreboot.org/c/coreboot/+/51077 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Felix Held felix-coreboot@felixheld.de Reviewed-by: Marshall Dawson marshalldawson3rd@gmail.com --- M src/soc/amd/common/block/lpc/lpc.c 1 file changed, 4 insertions(+), 3 deletions(-)
Approvals: build bot (Jenkins): Verified Felix Held: Looks good to me, but someone else must approve Marshall Dawson: Looks good to me, approved
diff --git a/src/soc/amd/common/block/lpc/lpc.c b/src/soc/amd/common/block/lpc/lpc.c index 1d019a3..2586ba9 100644 --- a/src/soc/amd/common/block/lpc/lpc.c +++ b/src/soc/amd/common/block/lpc/lpc.c @@ -28,7 +28,9 @@ u8 byte;
/* Set up SERIRQ, enable continuous mode */ - byte = (PM_SERIRQ_NUM_BITS_21 | PM_SERIRQ_ENABLE); + byte = PM_SERIRQ_NUM_BITS_21; + if (!CONFIG(SOC_AMD_COMMON_BLOCK_USE_ESPI)) + byte |= PM_SERIRQ_ENABLE; if (!CONFIG(SERIRQ_CONTINUOUS_MODE)) byte |= PM_SERIRQ_MODE;
@@ -91,8 +93,7 @@ /* Initialize i8254 timers */ setup_i8254();
- if (!CONFIG(SOC_AMD_COMMON_BLOCK_USE_ESPI)) - setup_serirq(); + setup_serirq(); }
static void lpc_read_resources(struct device *dev)
