Attention is currently required from: Michał Żygowski. Hello build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/63463
Change subject: mainboard/msi/ms7d25: Add early support for MSI PRO Z690-A DDR4 WIFI ......................................................................
Initial mainboard code MSI PRO Z690-A DDR4 WIFI. The platform boots up up to romstage where it returns from FSP memory init with an error.
What works: - open-source CAR setup - NCT6687D serial port with TX pin exposed on JBD1 header - SMBus reading SPD from all 4 DIMMs
This board will serve as a reference board for enabling Alder Lake-S support in coreboot. More code and functionalities will be added in subsequent patches as src/soc/alderlake code will be improved for PCH-S.
TEST=Extract the microcode from vendor firmware and include it in the build. The platform should print the console on the serial port even without FSP blob.
Signed-off-by: Michał Żygowski michal.zygowski@3mdeb.com Change-Id: I5df69822dbb3ff79e087408a0693de37df2142e8 --- A configs/config.msi_ms7d25 A src/mainboard/msi/ms7d25/Kconfig A src/mainboard/msi/ms7d25/Kconfig.name A src/mainboard/msi/ms7d25/Makefile.inc A src/mainboard/msi/ms7d25/board_info.txt A src/mainboard/msi/ms7d25/bootblock.c A src/mainboard/msi/ms7d25/devicetree.cb A src/mainboard/msi/ms7d25/dsdt.asl A src/mainboard/msi/ms7d25/mainboard.c A src/mainboard/msi/ms7d25/romstage_fsp_params.c 10 files changed, 243 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/63/63463/3
