Attention is currently required from: Jakub Czapiga, Tim Wawrzynczak, Paul Menzel, Alex Levin, Jan Dabros. Hello build bot (Jenkins), Tim Wawrzynczak, Alex Levin, Julius Werner, Jan Dabros,
https://review.coreboot.org/c/coreboot/+/62474
to look at the new patch set (#13).
Change subject: util/cbmem: Add FlameGraph-compatible timestamps output ......................................................................
Flame graphs are used to visualize hierarchical data, like call stacks. Timestamps collected by coreboot can be processed to resemble profiler-like output, and thus can be feed to flame graph generation tools.
Generating flame graph using https://github.com/brendangregg/FlameGraph: cbmem -S > trace.txt FlameGraph/flamegraph.pl --flamechart trace.txt > output.svg
TEST=Run on coreboot-enabled device and extract timestamps using -t/-T/-S options
Signed-off-by: Jakub Czapiga jacz@semihalf.com Change-Id: I3a4e20a267e9e0fbc6b3a4d6a2409b32ce8fca33 --- M src/commonlib/include/commonlib/timestamp_serialized.h M util/cbmem/cbmem.c 2 files changed, 321 insertions(+), 149 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/74/62474/13
