Attention is currently required from: Arthur Heymans, Elyes Haouas, Michał Żygowski, Sergii Dmytruk.
Hello Elyes Haouas, Krystian Hebel, Martin L Roth, Michał Żygowski, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/67065?usp=email
to look at the new patch set (#39).
The following approvals got outdated and were removed: Code-Review+1 by Elyes Haouas, Verified+1 by build bot (Jenkins)
Change subject: 3rdparty/open-power-signing-utils: add SecureBoot utility for OpenPOWER ......................................................................
Signing is performed with test keys by default, set CONFIG_SIGNING_KEYS_DIR to non-empty value to use other keys.
Change-Id: Id88baef5ecb1f8ffd74a7f464bbbaaaea0ca643d Signed-off-by: Michał Żygowski michal.zygowski@3mdeb.com Signed-off-by: Sergii Dmytruk sergii.dmytruk@3mdeb.com --- M .gitmodules A 3rdparty/open-power-signing-utils M Makefile.mk M src/soc/ibm/power9/Kconfig M src/soc/ibm/power9/Makefile.mk 5 files changed, 51 insertions(+), 5 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/65/67065/39
