Elyes Haouas has submitted this change. ( https://review.coreboot.org/c/coreboot/+/82759?usp=email )
Change subject: Revert "tree: Use Wcalloc-transposed-args command option" ......................................................................
This reverts commit b3db3abd6311924930f3250c9f9fc3157fbbf7da.
Reason for revert: `Wcalloc-transposed-args` is new command option came with GCC-14. older versions will not support it.
Change-Id: I74ef8de1f7d38e1e0519c3b41e79fd9b11d8e16f Signed-off-by: Elyes Haouas ehaouas@noos.fr Reviewed-on: https://review.coreboot.org/c/coreboot/+/82759 Reviewed-by: Nico Huber nico.h@gmx.de Reviewed-by: Angel Pons th3fanbus@gmail.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M Makefile.mk M src/southbridge/intel/common/rcba_pirq.c 2 files changed, 1 insertion(+), 2 deletions(-)
Approvals: build bot (Jenkins): Verified Angel Pons: Looks good to me, approved Nico Huber: Looks good to me, approved
diff --git a/Makefile.mk b/Makefile.mk index e406702..0358c88 100644 --- a/Makefile.mk +++ b/Makefile.mk @@ -502,7 +502,6 @@ CFLAGS_common += -Wstring-compare ifeq ($(CONFIG_COMPILER_GCC),y) CFLAGS_common += -Wold-style-declaration -Wflex-array-member-not-at-end -CFLAGS_common += -Wcalloc-transposed-args # Don't add these GCC specific flags when running scan-build ifeq ($(CCC_ANALYZER_OUTPUT_FORMAT),) CFLAGS_common += -Wno-packed-not-aligned diff --git a/src/southbridge/intel/common/rcba_pirq.c b/src/southbridge/intel/common/rcba_pirq.c index 956fe63..c9ab140 100644 --- a/src/southbridge/intel/common/rcba_pirq.c +++ b/src/southbridge/intel/common/rcba_pirq.c @@ -59,7 +59,7 @@
printk(BIOS_DEBUG, "Generating ACPI PIRQ entries\n");
- pin_irq_map = calloc(MAX_SLOTS * PCI_INT_MAX, sizeof(struct slot_pin_irq_map)); + pin_irq_map = calloc(sizeof(struct slot_pin_irq_map), MAX_SLOTS * PCI_INT_MAX); pirq_map.type = PIRQ_SOURCE_PATH; for (i = 0; i < PIRQ_COUNT; i++) snprintf(pirq_map.source_path[i], sizeof(pirq_map.source_path[i]),
