Attention is currently required from: Jan Philipp Groß.
Hello Angel Pons,
https://review.coreboot.org/c/coreboot/+/82760?usp=email
Change subject: mb/asrock: Add Z97E-ITX/ac (Haswell/Broadwell) ......................................................................
This is a rudimentary port of this board. It was done with Haswell Autoport, wherein some adjustments for Broadwell were made (Thanks to Angel Pons!). The VBT was copied from /sys/kernel/debug/dri/1/i915_vbt on version 2.20 of the vendor firmware.
Working:
- Broadwell MRC.bin - Libgfxinit - HDMI - DVI-I - Rear USB ports (with the exception of the top-most USB-2-port) - mPCIe SSD - mPCIe WiFi slot - x16 PCIe slot - edk2
Not yet tested: - SATA ports - Ethernet - DisplayPort - PS/2 keyboard/mouse - USB 2.0 header - USB 3.0 header - Audio header
Not working: - Broadwell CPUs (refer to Angel Pons Z97 Extreme 6 port for further info)
Special thanks to Angel Pons for guiding me through the process of porting this board and pushing it to Gerrit!
Change-Id: I3b940e9281814e8360900221714c0dfa3ae39540 Signed-off-by: Jan Philipp Groß jeangrande@mailbox.org --- A src/mainboard/asrock/z97e-itx_ac/Kconfig A src/mainboard/asrock/z97e-itx_ac/Kconfig.name A src/mainboard/asrock/z97e-itx_ac/Makefile.mk A src/mainboard/asrock/z97e-itx_ac/acpi/ec.asl A src/mainboard/asrock/z97e-itx_ac/acpi/platform.asl A src/mainboard/asrock/z97e-itx_ac/acpi/superio.asl A src/mainboard/asrock/z97e-itx_ac/board_info.txt A src/mainboard/asrock/z97e-itx_ac/bootblock.c A src/mainboard/asrock/z97e-itx_ac/data.vbt A src/mainboard/asrock/z97e-itx_ac/devicetree.cb A src/mainboard/asrock/z97e-itx_ac/dsdt.asl A src/mainboard/asrock/z97e-itx_ac/gma-mainboard.ads A src/mainboard/asrock/z97e-itx_ac/gpio.c A src/mainboard/asrock/z97e-itx_ac/hda_verb.c A src/mainboard/asrock/z97e-itx_ac/romstage.c 15 files changed, 473 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/60/82760/2
