Vaibhav Shankar (vaibhav.shankar@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/16349
commit 7eaf702fa6c92dff4dbf97e4f1ef095782799766 Author: Vaibhav Shankar vaibhav.shankar@intel.com Date: Mon Aug 29 14:03:38 2016 -0700
soc/intel/apollolake: Configure DW0 and DW1 GPIO registers through ASL
Implement a macro to calculate DW0 register address. Added GPIO methods to configure DW0 and DW1 registers. Added GNVS variable for PERST_0.
BUG=chrome-os-partner:55877
Change-Id: I6eaa1fcecf5970b365e3418541c75b9866959f7e Signed-off-by: Vaibhav Shankar vaibhav.shankar@intel.com --- src/soc/intel/apollolake/acpi/globalnvs.asl | 1 + src/soc/intel/apollolake/acpi/gpiolib.asl | 73 ++++++++++++++++++++++++ src/soc/intel/apollolake/include/soc/gpio_defs.h | 5 ++ src/soc/intel/apollolake/include/soc/nvs.h | 3 +- 4 files changed, 81 insertions(+), 1 deletion(-)
diff --git a/src/soc/intel/apollolake/acpi/globalnvs.asl b/src/soc/intel/apollolake/acpi/globalnvs.asl index 404f36c..faff8df 100644 --- a/src/soc/intel/apollolake/acpi/globalnvs.asl +++ b/src/soc/intel/apollolake/acpi/globalnvs.asl @@ -38,6 +38,7 @@ Field (GNVS, ByteAcc, NoLock, Preserve) GPEI, 64, // 0x11 - 0x18 - GPE Wake Source NHLA, 64, // 0x19 - 0x20 - NHLT Address NHLL, 32, // 0x21 - 0x24 - NHLT Length + PRAD, 32, // 0x25 - 0x28 - PERST_0 Address
/* ChromeOS stuff (0x100 -> 0xfff, size 0xeff) */ Offset (0x100), diff --git a/src/soc/intel/apollolake/acpi/gpiolib.asl b/src/soc/intel/apollolake/acpi/gpiolib.asl new file mode 100644 index 0000000..f31f83e --- /dev/null +++ b/src/soc/intel/apollolake/acpi/gpiolib.asl @@ -0,0 +1,73 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2016 Intel Corporation. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +Scope (_SB) +{ + + /* Get Pad Configuration DW0 register value */ + Method (GPC0, 0x1, Serialized) + { + /* Arg0 - GpioCommunity_Address + PadCfgBase_Address + PadCommunityPin_Address */ + Store (Arg0, Local0) + OperationRegion (PDW0, SystemMemory, + Or (CONFIG_IOSF_BASE_ADDRESS, Local0), 4) + Field (PDW0, AnyAcc, NoLock, Preserve) { + TEMP, 32 + } + Return (TEMP) + } + + /* Set Pad Configuration DW0 register value */ + Method (SPC0, 0x2, Serialized) + { + /* Arg0 - GpioCommunity_Address + PadCfgBase_Address + PadCommunityPin_Address */ + /* Arg1 - Value for DW0 register */ + Store (Arg0, Local0) + OperationRegion (PDW0, SystemMemory, + Or (CONFIG_IOSF_BASE_ADDRESS, Local0), 4) + Field (PDW0, AnyAcc, NoLock, Preserve) { + TEMP,32 + } + Store (Arg1, TEMP) + } + + /* Get Pad Configuration DW1 register value */ + Method (GPC1, 0x1, Serialized) + { + /* Arg0 = GpioCommunity_Address + PadCfgBase_Address + PadCommunityPin_Address + 0x4 */ + Store ( Add ( Arg0, 0x4), Local0) + OperationRegion (PDW1, SystemMemory, + Or (CONFIG_IOSF_BASE_ADDRESS, Local0), 4) + Field (PDW1, AnyAcc, NoLock, Preserve) { + TEMP, 32 + } + Return (TEMP) + } + + + /* Set Pad Configuration DW1 register value */ + Method (SPC1, 0x2, Serialized) + { + /* Arg0 - GpioCommunity_Address + PadCfgBase_Address + PadCommunityPin_Address + 0x4 */ + /* Arg1 - Value for DW1 register */ + Store ( Add ( Arg0, 0x4), Local0) + OperationRegion (PDW1, SystemMemory, + Or (CONFIG_IOSF_BASE_ADDRESS, Local0), 4) + Field(PDW1, AnyAcc, NoLock, Preserve) { + TEMP,32 + } + Store (Arg1, TEMP) + } +} diff --git a/src/soc/intel/apollolake/include/soc/gpio_defs.h b/src/soc/intel/apollolake/include/soc/gpio_defs.h index 70f86ca..89530fd 100644 --- a/src/soc/intel/apollolake/include/soc/gpio_defs.h +++ b/src/soc/intel/apollolake/include/soc/gpio_defs.h @@ -426,6 +426,11 @@ #define PAD_W(pad) (pad - W_OFFSET) #define PAD_SW(pad) (pad - SW_OFFSET)
+/* calculate GPIO DW0 register address */ +#define PAD_IOSF_MMIO(community, pin) \ + ((GPIO_##community << 16) | \ + (PAD_CFG_BASE | PAD_##community(pin) * 8)) + /* Linux names of the GPIO devices. */ #define GPIO_COMM_N_NAME "INT3452:00" #define GPIO_COMM_NW_NAME "INT3452:01" diff --git a/src/soc/intel/apollolake/include/soc/nvs.h b/src/soc/intel/apollolake/include/soc/nvs.h index bff949e..26e1c49 100644 --- a/src/soc/intel/apollolake/include/soc/nvs.h +++ b/src/soc/intel/apollolake/include/soc/nvs.h @@ -38,7 +38,8 @@ typedef struct global_nvs_t { uint64_t gpei; /* 0x11 - 0x18 - GPE Wake Source */ uint64_t nhla; /* 0x19 - 0x20 - NHLT Address */ uint32_t nhll; /* 0x21 - 0x24 - NHLT Length */ - uint8_t unused[219]; + uint32_t prad; /* 0x25 - 0x28 - PERST_0 Address */ + uint8_t unused[215];
/* ChromeOS specific (0x100 - 0xfff) */ chromeos_acpi_t chromeos;
