Arthur Heymans (arthur@aheymans.xyz) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/16513
commit 3e5ab3714f45ff361b8a19e376a7bff23add73cf Author: Arthur Heymans arthur@aheymans.xyz Date: Tue Sep 6 23:53:32 2016 +0200
i945/gma.c: Only init LVDS if it is present on the device
Some devices have no LVDS output but if no VGA is connected or no edid can be found, it will try to init LVDS.
This patch makes sure only devices that have an LVDS connector can use LVDS graphic initialisation.
Change-Id: Ie15631514535bab6c881c1f52e9edbfb8aaa5db7 Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- src/mainboard/apple/macbook21/Kconfig | 4 ++++ src/mainboard/getac/p470/Kconfig | 4 ++++ src/mainboard/lenovo/t60/Kconfig | 4 ++++ src/mainboard/lenovo/x60/Kconfig | 4 ++++ src/northbridge/intel/i945/Kconfig | 4 ++++ src/northbridge/intel/i945/gma.c | 2 +- 6 files changed, 21 insertions(+), 1 deletion(-)
diff --git a/src/mainboard/apple/macbook21/Kconfig b/src/mainboard/apple/macbook21/Kconfig index e653c08..8ba3d77 100644 --- a/src/mainboard/apple/macbook21/Kconfig +++ b/src/mainboard/apple/macbook21/Kconfig @@ -35,6 +35,10 @@ config DCACHE_RAM_SIZE hex default 0x8000
+config HAS_LVDS + bool + default y + if BOARD_APPLE_MACBOOK21
config MAINBOARD_PART_NUMBER diff --git a/src/mainboard/getac/p470/Kconfig b/src/mainboard/getac/p470/Kconfig index ea68bed..e74b70c 100644 --- a/src/mainboard/getac/p470/Kconfig +++ b/src/mainboard/getac/p470/Kconfig @@ -64,4 +64,8 @@ config VGA_BIOS_FILE string default "getac-pci8086,27a2.rom"
+config HAS_LVDS + bool + default y + endif # BOARD_GETAC_P470 diff --git a/src/mainboard/lenovo/t60/Kconfig b/src/mainboard/lenovo/t60/Kconfig index 52eeda3..e5a7554 100644 --- a/src/mainboard/lenovo/t60/Kconfig +++ b/src/mainboard/lenovo/t60/Kconfig @@ -54,4 +54,8 @@ config SEABIOS_PS2_TIMEOUT int default 3000
+config HAS_LVDS + bool + default y + endif diff --git a/src/mainboard/lenovo/x60/Kconfig b/src/mainboard/lenovo/x60/Kconfig index ab4b58e..152e6b2 100644 --- a/src/mainboard/lenovo/x60/Kconfig +++ b/src/mainboard/lenovo/x60/Kconfig @@ -61,4 +61,8 @@ config SEABIOS_PS2_TIMEOUT int default 3000
+config HAS_LVDS + bool + default y + endif diff --git a/src/northbridge/intel/i945/Kconfig b/src/northbridge/intel/i945/Kconfig index 6e8d35b..ae7961f 100644 --- a/src/northbridge/intel/i945/Kconfig +++ b/src/northbridge/intel/i945/Kconfig @@ -71,4 +71,8 @@ config CHECK_SLFRCS_ON_RESUME On other boards the check always creates a false positive, effectively making it impossible to resume.
+config HAS_LVDS + bool + default n + endif diff --git a/src/northbridge/intel/i945/gma.c b/src/northbridge/intel/i945/gma.c index abe7dd6..be299f4 100644 --- a/src/northbridge/intel/i945/gma.c +++ b/src/northbridge/intel/i945/gma.c @@ -611,7 +611,7 @@ static void gma_func0_init(struct device *dev) );
int err; - if (vga_connected(mmiobase)) + if (!CONFIG_HAS_LVDS || vga_connected(mmiobase)) err = intel_gma_init_vga(conf, pci_read_config32(dev, 0x5c) & ~0xf, iobase, mmiobase, graphics_base); else
