Martin Roth (martinroth@google.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/12838
commit 83fa68341d03d0f7a60db0f7c161565bd517825e Author: Martin Roth martinroth@google.com Date: Tue Jan 5 14:21:02 2016 -0700
xcompile: Add separation for architectures to improve readability
- Add bar at the top of each architecture - Make the architecture name and the TARCH_SEARCH to two lines - Add a second line at the bottom of each architecture - Add a comment about the two blank lines so they don't get accidentally removed.
Change-Id: Ib4326bd94fe39b979244816ce54b752d083f6b16 Signed-off-by: Martin Roth martinroth@google.com --- util/xcompile/xcompile | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/util/xcompile/xcompile b/util/xcompile/xcompile index 82a5885..3535793 100755 --- a/util/xcompile/xcompile +++ b/util/xcompile/xcompile @@ -225,7 +225,9 @@ STRIP_${TARCH}:=${GCCPREFIX}strip AR_${TARCH}:=${GCCPREFIX}ar CROSS_COMPILE_${TARCH}:=${GCCPREFIX}
+ EOF +#The two blank lines above are intentional separators }
# Architecture definitions @@ -320,7 +322,9 @@ test_architecture() { search="$search $toolchain-linux-gnu-" search="$search $toolchain-" done - echo "# $architecture TARCH_SEARCH=$search" + echo "###########################################################################" + echo "# $architecture" + echo "# TARCH_SEARCH=$search"
# Search toolchain by checking assembler capability. for TBFDARCH in $TBFDARCHS; do
