Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/70119 )
Change subject: mb/intel/adlrvp: Add RTD3 support for PCIe slot1 ......................................................................
Add RTD3 support for adlrvp_p_ext_ec and adlrvp_rpl_ext_ec
BUG=none BRANCH=firmware-brya-14505.B
TEST=Insert a SD card or NIC AIC on PCIe slot1 and run 'suspend_stress_test -c 1'. The RP8 should not cause suspend issue.
Signed-off-by: Cliff Huang cliff.huang@intel.corp-partner.google.com Change-Id: Ieb7d207a7ec3763bad3e82522e86a825c1ed00b6 Reviewed-on: https://review.coreboot.org/c/coreboot/+/70119 Reviewed-by: Eric Lai eric_lai@quanta.corp-partner.google.com Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Dtrain Hsu dtrain_hsu@compal.corp-partner.google.com Reviewed-by: Anil Kumar K anil.kumar.k@intel.corp-partner.google.com --- M src/mainboard/intel/adlrvp/variants/adlrvp_p_ext_ec/overridetree.cb M src/mainboard/intel/adlrvp/variants/adlrvp_rpl_ext_ec/overridetree.cb 2 files changed, 61 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Dtrain Hsu: Looks good to me, approved Anil Kumar K: Looks good to me, but someone else must approve Eric Lai: Looks good to me, approved
diff --git a/src/mainboard/intel/adlrvp/variants/adlrvp_p_ext_ec/overridetree.cb b/src/mainboard/intel/adlrvp/variants/adlrvp_p_ext_ec/overridetree.cb index 2eea1e4..c78189f 100644 --- a/src/mainboard/intel/adlrvp/variants/adlrvp_p_ext_ec/overridetree.cb +++ b/src/mainboard/intel/adlrvp/variants/adlrvp_p_ext_ec/overridetree.cb @@ -84,5 +84,24 @@ end end end + device ref pcie_rp8 on + # NOTE: requires GPP_A7 set to Native Function 1 for SRCCLK_OE7 + register "pch_pcie_rp[PCH_RP(8)]" = "{ + .clk_src = 7, + .clk_req = 7, + .flags = PCIE_RP_CLK_REQ_DETECT | PCIE_RP_LTR, + .PcieRpL1Substates = L1_SS_L1_2, + .pcie_rp_detect_timeout_ms = 50, + }" + chip soc/intel/common/block/pcie/rtd3 + register "enable_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_H17)" + register "enable_delay_ms" = "50" + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_F10)" + register "reset_off_delay_ms" = "20" + register "srcclk_pin" = "7" + device generic 0 on + end + end + end end end diff --git a/src/mainboard/intel/adlrvp/variants/adlrvp_rpl_ext_ec/overridetree.cb b/src/mainboard/intel/adlrvp/variants/adlrvp_rpl_ext_ec/overridetree.cb index 2eea1e4..c78189f 100644 --- a/src/mainboard/intel/adlrvp/variants/adlrvp_rpl_ext_ec/overridetree.cb +++ b/src/mainboard/intel/adlrvp/variants/adlrvp_rpl_ext_ec/overridetree.cb @@ -84,5 +84,24 @@ end end end + device ref pcie_rp8 on + # NOTE: requires GPP_A7 set to Native Function 1 for SRCCLK_OE7 + register "pch_pcie_rp[PCH_RP(8)]" = "{ + .clk_src = 7, + .clk_req = 7, + .flags = PCIE_RP_CLK_REQ_DETECT | PCIE_RP_LTR, + .PcieRpL1Substates = L1_SS_L1_2, + .pcie_rp_detect_timeout_ms = 50, + }" + chip soc/intel/common/block/pcie/rtd3 + register "enable_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_H17)" + register "enable_delay_ms" = "50" + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_F10)" + register "reset_off_delay_ms" = "20" + register "srcclk_pin" = "7" + device generic 0 on + end + end + end end end
