Angel Pons has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/47179 )
Change subject: mainboard: Drop unused CMOS options ......................................................................
None of these options are handled in coreboot code.
Change-Id: If0cb1d716fa0a7da249e72c7c006849371f49835 Signed-off-by: Angel Pons th3fanbus@gmail.com --- M src/mainboard/amd/inagua/cmos.layout M src/mainboard/amd/olivehill/cmos.layout M src/mainboard/amd/parmer/cmos.layout M src/mainboard/amd/persimmon/cmos.layout M src/mainboard/amd/south_station/cmos.layout M src/mainboard/amd/thatcher/cmos.layout M src/mainboard/amd/union_station/cmos.layout M src/mainboard/asrock/e350m1/cmos.layout M src/mainboard/asrock/imb-a180/cmos.layout M src/mainboard/asus/a88xm-e/cmos.layout M src/mainboard/asus/f2a85-m/cmos.layout M src/mainboard/bap/ode_e20XX/cmos.layout M src/mainboard/biostar/a68n_5200/cmos.layout M src/mainboard/biostar/am1ml/cmos.layout M src/mainboard/elmex/pcm205400/cmos.layout M src/mainboard/emulation/qemu-i440fx/cmos.default M src/mainboard/emulation/qemu-i440fx/cmos.layout M src/mainboard/emulation/qemu-q35/cmos.default M src/mainboard/emulation/qemu-q35/cmos.layout M src/mainboard/gizmosphere/gizmo/cmos.layout M src/mainboard/gizmosphere/gizmo2/cmos.layout M src/mainboard/hp/abm/cmos.layout M src/mainboard/jetway/nf81-t56n-lf/cmos.layout M src/mainboard/lenovo/g505s/cmos.layout M src/mainboard/lippert/frontrunner-af/cmos.layout M src/mainboard/msi/ms7721/cmos.layout M src/mainboard/pcengines/apu1/cmos.default M src/mainboard/pcengines/apu1/cmos.layout M src/mainboard/pcengines/apu2/cmos.layout 29 files changed, 0 insertions(+), 285 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/79/47179/1
diff --git a/src/mainboard/amd/inagua/cmos.layout b/src/mainboard/amd/inagua/cmos.layout index d26d6aa..f6031ec 100644 --- a/src/mainboard/amd/inagua/cmos.layout +++ b/src/mainboard/amd/inagua/cmos.layout @@ -8,15 +8,9 @@ 0 384 r 0 reserved_memory 384 1 e 4 boot_option 388 4 h 0 reboot_counter -395 1 e 1 hw_scrubber -396 1 e 1 interleave_chip_selects -397 2 e 8 max_mem_clock -399 1 e 2 multi_core 400 1 e 1 power_on_after_fail 412 4 e 6 debug_level 444 1 e 1 nmi -445 1 e 1 iommu -456 1 e 1 ECC_memory 728 256 h 0 user_data 984 16 h 0 check_sum # Reserve the extended AMD configuration registers @@ -27,18 +21,12 @@ #ID value text 1 0 Disable 1 1 Enable -2 0 Enable -2 1 Disable 4 0 Fallback 4 1 Normal 6 5 Notice 6 6 Info 6 7 Debug 6 8 Spew -8 0 400Mhz -8 1 333Mhz -8 2 266Mhz -8 3 200Mhz
checksums
diff --git a/src/mainboard/amd/olivehill/cmos.layout b/src/mainboard/amd/olivehill/cmos.layout index d26d6aa..f6031ec 100644 --- a/src/mainboard/amd/olivehill/cmos.layout +++ b/src/mainboard/amd/olivehill/cmos.layout @@ -8,15 +8,9 @@ 0 384 r 0 reserved_memory 384 1 e 4 boot_option 388 4 h 0 reboot_counter -395 1 e 1 hw_scrubber -396 1 e 1 interleave_chip_selects -397 2 e 8 max_mem_clock -399 1 e 2 multi_core 400 1 e 1 power_on_after_fail 412 4 e 6 debug_level 444 1 e 1 nmi -445 1 e 1 iommu -456 1 e 1 ECC_memory 728 256 h 0 user_data 984 16 h 0 check_sum # Reserve the extended AMD configuration registers @@ -27,18 +21,12 @@ #ID value text 1 0 Disable 1 1 Enable -2 0 Enable -2 1 Disable 4 0 Fallback 4 1 Normal 6 5 Notice 6 6 Info 6 7 Debug 6 8 Spew -8 0 400Mhz -8 1 333Mhz -8 2 266Mhz -8 3 200Mhz
checksums
diff --git a/src/mainboard/amd/parmer/cmos.layout b/src/mainboard/amd/parmer/cmos.layout index d26d6aa..f6031ec 100644 --- a/src/mainboard/amd/parmer/cmos.layout +++ b/src/mainboard/amd/parmer/cmos.layout @@ -8,15 +8,9 @@ 0 384 r 0 reserved_memory 384 1 e 4 boot_option 388 4 h 0 reboot_counter -395 1 e 1 hw_scrubber -396 1 e 1 interleave_chip_selects -397 2 e 8 max_mem_clock -399 1 e 2 multi_core 400 1 e 1 power_on_after_fail 412 4 e 6 debug_level 444 1 e 1 nmi -445 1 e 1 iommu -456 1 e 1 ECC_memory 728 256 h 0 user_data 984 16 h 0 check_sum # Reserve the extended AMD configuration registers @@ -27,18 +21,12 @@ #ID value text 1 0 Disable 1 1 Enable -2 0 Enable -2 1 Disable 4 0 Fallback 4 1 Normal 6 5 Notice 6 6 Info 6 7 Debug 6 8 Spew -8 0 400Mhz -8 1 333Mhz -8 2 266Mhz -8 3 200Mhz
checksums
diff --git a/src/mainboard/amd/persimmon/cmos.layout b/src/mainboard/amd/persimmon/cmos.layout index d26d6aa..f6031ec 100644 --- a/src/mainboard/amd/persimmon/cmos.layout +++ b/src/mainboard/amd/persimmon/cmos.layout @@ -8,15 +8,9 @@ 0 384 r 0 reserved_memory 384 1 e 4 boot_option 388 4 h 0 reboot_counter -395 1 e 1 hw_scrubber -396 1 e 1 interleave_chip_selects -397 2 e 8 max_mem_clock -399 1 e 2 multi_core 400 1 e 1 power_on_after_fail 412 4 e 6 debug_level 444 1 e 1 nmi -445 1 e 1 iommu -456 1 e 1 ECC_memory 728 256 h 0 user_data 984 16 h 0 check_sum # Reserve the extended AMD configuration registers @@ -27,18 +21,12 @@ #ID value text 1 0 Disable 1 1 Enable -2 0 Enable -2 1 Disable 4 0 Fallback 4 1 Normal 6 5 Notice 6 6 Info 6 7 Debug 6 8 Spew -8 0 400Mhz -8 1 333Mhz -8 2 266Mhz -8 3 200Mhz
checksums
diff --git a/src/mainboard/amd/south_station/cmos.layout b/src/mainboard/amd/south_station/cmos.layout index d26d6aa..f6031ec 100644 --- a/src/mainboard/amd/south_station/cmos.layout +++ b/src/mainboard/amd/south_station/cmos.layout @@ -8,15 +8,9 @@ 0 384 r 0 reserved_memory 384 1 e 4 boot_option 388 4 h 0 reboot_counter -395 1 e 1 hw_scrubber -396 1 e 1 interleave_chip_selects -397 2 e 8 max_mem_clock -399 1 e 2 multi_core 400 1 e 1 power_on_after_fail 412 4 e 6 debug_level 444 1 e 1 nmi -445 1 e 1 iommu -456 1 e 1 ECC_memory 728 256 h 0 user_data 984 16 h 0 check_sum # Reserve the extended AMD configuration registers @@ -27,18 +21,12 @@ #ID value text 1 0 Disable 1 1 Enable -2 0 Enable -2 1 Disable 4 0 Fallback 4 1 Normal 6 5 Notice 6 6 Info 6 7 Debug 6 8 Spew -8 0 400Mhz -8 1 333Mhz -8 2 266Mhz -8 3 200Mhz
checksums
diff --git a/src/mainboard/amd/thatcher/cmos.layout b/src/mainboard/amd/thatcher/cmos.layout index d26d6aa..f6031ec 100644 --- a/src/mainboard/amd/thatcher/cmos.layout +++ b/src/mainboard/amd/thatcher/cmos.layout @@ -8,15 +8,9 @@ 0 384 r 0 reserved_memory 384 1 e 4 boot_option 388 4 h 0 reboot_counter -395 1 e 1 hw_scrubber -396 1 e 1 interleave_chip_selects -397 2 e 8 max_mem_clock -399 1 e 2 multi_core 400 1 e 1 power_on_after_fail 412 4 e 6 debug_level 444 1 e 1 nmi -445 1 e 1 iommu -456 1 e 1 ECC_memory 728 256 h 0 user_data 984 16 h 0 check_sum # Reserve the extended AMD configuration registers @@ -27,18 +21,12 @@ #ID value text 1 0 Disable 1 1 Enable -2 0 Enable -2 1 Disable 4 0 Fallback 4 1 Normal 6 5 Notice 6 6 Info 6 7 Debug 6 8 Spew -8 0 400Mhz -8 1 333Mhz -8 2 266Mhz -8 3 200Mhz
checksums
diff --git a/src/mainboard/amd/union_station/cmos.layout b/src/mainboard/amd/union_station/cmos.layout index d26d6aa..f6031ec 100644 --- a/src/mainboard/amd/union_station/cmos.layout +++ b/src/mainboard/amd/union_station/cmos.layout @@ -8,15 +8,9 @@ 0 384 r 0 reserved_memory 384 1 e 4 boot_option 388 4 h 0 reboot_counter -395 1 e 1 hw_scrubber -396 1 e 1 interleave_chip_selects -397 2 e 8 max_mem_clock -399 1 e 2 multi_core 400 1 e 1 power_on_after_fail 412 4 e 6 debug_level 444 1 e 1 nmi -445 1 e 1 iommu -456 1 e 1 ECC_memory 728 256 h 0 user_data 984 16 h 0 check_sum # Reserve the extended AMD configuration registers @@ -27,18 +21,12 @@ #ID value text 1 0 Disable 1 1 Enable -2 0 Enable -2 1 Disable 4 0 Fallback 4 1 Normal 6 5 Notice 6 6 Info 6 7 Debug 6 8 Spew -8 0 400Mhz -8 1 333Mhz -8 2 266Mhz -8 3 200Mhz
checksums
diff --git a/src/mainboard/asrock/e350m1/cmos.layout b/src/mainboard/asrock/e350m1/cmos.layout index 1fb9f0f..6caaeab 100644 --- a/src/mainboard/asrock/e350m1/cmos.layout +++ b/src/mainboard/asrock/e350m1/cmos.layout @@ -8,15 +8,9 @@ 0 384 r 0 reserved_memory 384 1 e 4 boot_option 388 4 h 0 reboot_counter -395 1 e 1 hw_scrubber -396 1 e 1 interleave_chip_selects -397 2 e 8 max_mem_clock -399 1 e 2 multi_core 400 2 e 3 power_on_after_fail 412 4 e 6 debug_level 444 1 e 1 nmi -445 1 e 1 iommu -456 1 e 1 ECC_memory 728 256 h 0 user_data 984 16 h 0 check_sum # Reserve the extended AMD configuration registers @@ -27,8 +21,6 @@ #ID value text 1 0 Disable 1 1 Enable -2 0 Enable -2 1 Disable 3 0 Off 3 1 On 3 2 Last @@ -38,10 +30,6 @@ 6 6 Info 6 7 Debug 6 8 Spew -8 0 400Mhz -8 1 333Mhz -8 2 266Mhz -8 3 200Mhz
checksums
diff --git a/src/mainboard/asrock/imb-a180/cmos.layout b/src/mainboard/asrock/imb-a180/cmos.layout index d26d6aa..f6031ec 100644 --- a/src/mainboard/asrock/imb-a180/cmos.layout +++ b/src/mainboard/asrock/imb-a180/cmos.layout @@ -8,15 +8,9 @@ 0 384 r 0 reserved_memory 384 1 e 4 boot_option 388 4 h 0 reboot_counter -395 1 e 1 hw_scrubber -396 1 e 1 interleave_chip_selects -397 2 e 8 max_mem_clock -399 1 e 2 multi_core 400 1 e 1 power_on_after_fail 412 4 e 6 debug_level 444 1 e 1 nmi -445 1 e 1 iommu -456 1 e 1 ECC_memory 728 256 h 0 user_data 984 16 h 0 check_sum # Reserve the extended AMD configuration registers @@ -27,18 +21,12 @@ #ID value text 1 0 Disable 1 1 Enable -2 0 Enable -2 1 Disable 4 0 Fallback 4 1 Normal 6 5 Notice 6 6 Info 6 7 Debug 6 8 Spew -8 0 400Mhz -8 1 333Mhz -8 2 266Mhz -8 3 200Mhz
checksums
diff --git a/src/mainboard/asus/a88xm-e/cmos.layout b/src/mainboard/asus/a88xm-e/cmos.layout index 173d8c4..ad72d70 100644 --- a/src/mainboard/asus/a88xm-e/cmos.layout +++ b/src/mainboard/asus/a88xm-e/cmos.layout @@ -5,15 +5,9 @@ 0 384 r 0 reserved_memory 384 1 e 4 boot_option 388 4 h 0 reboot_counter -395 1 e 1 hw_scrubber -396 1 e 1 interleave_chip_selects -397 2 e 8 max_mem_clock -399 1 e 2 multi_core 400 1 e 1 power_on_after_fail 412 4 e 6 debug_level 444 1 e 1 nmi -445 1 e 1 iommu -#456 1 e 1 ECC_memory 728 256 h 0 user_data 984 16 h 0 check_sum # Reserve the extended AMD configuration registers @@ -24,8 +18,6 @@ #ID value text 1 0 Disable 1 1 Enable -2 0 Enable -2 1 Disable 4 0 Fallback 4 1 Normal 6 0 Emergency @@ -37,10 +29,6 @@ 6 6 Info 6 7 Debug 6 8 Spew -8 0 400Mhz -8 1 333Mhz -8 2 266Mhz -8 3 200Mhz
checksums
diff --git a/src/mainboard/asus/f2a85-m/cmos.layout b/src/mainboard/asus/f2a85-m/cmos.layout index d26d6aa..f6031ec 100644 --- a/src/mainboard/asus/f2a85-m/cmos.layout +++ b/src/mainboard/asus/f2a85-m/cmos.layout @@ -8,15 +8,9 @@ 0 384 r 0 reserved_memory 384 1 e 4 boot_option 388 4 h 0 reboot_counter -395 1 e 1 hw_scrubber -396 1 e 1 interleave_chip_selects -397 2 e 8 max_mem_clock -399 1 e 2 multi_core 400 1 e 1 power_on_after_fail 412 4 e 6 debug_level 444 1 e 1 nmi -445 1 e 1 iommu -456 1 e 1 ECC_memory 728 256 h 0 user_data 984 16 h 0 check_sum # Reserve the extended AMD configuration registers @@ -27,18 +21,12 @@ #ID value text 1 0 Disable 1 1 Enable -2 0 Enable -2 1 Disable 4 0 Fallback 4 1 Normal 6 5 Notice 6 6 Info 6 7 Debug 6 8 Spew -8 0 400Mhz -8 1 333Mhz -8 2 266Mhz -8 3 200Mhz
checksums
diff --git a/src/mainboard/bap/ode_e20XX/cmos.layout b/src/mainboard/bap/ode_e20XX/cmos.layout index d26d6aa..f6031ec 100644 --- a/src/mainboard/bap/ode_e20XX/cmos.layout +++ b/src/mainboard/bap/ode_e20XX/cmos.layout @@ -8,15 +8,9 @@ 0 384 r 0 reserved_memory 384 1 e 4 boot_option 388 4 h 0 reboot_counter -395 1 e 1 hw_scrubber -396 1 e 1 interleave_chip_selects -397 2 e 8 max_mem_clock -399 1 e 2 multi_core 400 1 e 1 power_on_after_fail 412 4 e 6 debug_level 444 1 e 1 nmi -445 1 e 1 iommu -456 1 e 1 ECC_memory 728 256 h 0 user_data 984 16 h 0 check_sum # Reserve the extended AMD configuration registers @@ -27,18 +21,12 @@ #ID value text 1 0 Disable 1 1 Enable -2 0 Enable -2 1 Disable 4 0 Fallback 4 1 Normal 6 5 Notice 6 6 Info 6 7 Debug 6 8 Spew -8 0 400Mhz -8 1 333Mhz -8 2 266Mhz -8 3 200Mhz
checksums
diff --git a/src/mainboard/biostar/a68n_5200/cmos.layout b/src/mainboard/biostar/a68n_5200/cmos.layout index d26d6aa..f6031ec 100644 --- a/src/mainboard/biostar/a68n_5200/cmos.layout +++ b/src/mainboard/biostar/a68n_5200/cmos.layout @@ -8,15 +8,9 @@ 0 384 r 0 reserved_memory 384 1 e 4 boot_option 388 4 h 0 reboot_counter -395 1 e 1 hw_scrubber -396 1 e 1 interleave_chip_selects -397 2 e 8 max_mem_clock -399 1 e 2 multi_core 400 1 e 1 power_on_after_fail 412 4 e 6 debug_level 444 1 e 1 nmi -445 1 e 1 iommu -456 1 e 1 ECC_memory 728 256 h 0 user_data 984 16 h 0 check_sum # Reserve the extended AMD configuration registers @@ -27,18 +21,12 @@ #ID value text 1 0 Disable 1 1 Enable -2 0 Enable -2 1 Disable 4 0 Fallback 4 1 Normal 6 5 Notice 6 6 Info 6 7 Debug 6 8 Spew -8 0 400Mhz -8 1 333Mhz -8 2 266Mhz -8 3 200Mhz
checksums
diff --git a/src/mainboard/biostar/am1ml/cmos.layout b/src/mainboard/biostar/am1ml/cmos.layout index 6f61f97..f6dd7cf 100644 --- a/src/mainboard/biostar/am1ml/cmos.layout +++ b/src/mainboard/biostar/am1ml/cmos.layout @@ -30,12 +30,7 @@ #96 288 r 0 temporary_filler 0 384 r 0 reserved_memory 384 1 e 4 boot_option -386 1 e 1 ECC_memory 388 4 h 0 reboot_counter -395 1 e 1 hw_scrubber -396 1 e 1 interleave_chip_selects -397 2 e 8 max_mem_clock -399 1 e 2 multi_core 400 1 e 1 power_on_after_fail 412 4 e 6 debug_level 416 4 e 7 boot_first @@ -44,7 +39,6 @@ 428 4 h 0 boot_index 432 8 h 0 boot_countdown 444 1 e 1 nmi -445 1 e 1 iommu 728 256 h 0 user_data 984 16 h 0 check_sum # Reserve the extended AMD configuration registers @@ -55,8 +49,6 @@ #ID value text 1 0 Disable 1 1 Enable -2 0 Enable -2 1 Disable 4 0 Fallback 4 1 Normal 6 5 Notice @@ -70,10 +62,6 @@ 7 9 Fallback_HDD 7 10 Fallback_Floppy #7 3 ROM -8 0 400Mhz -8 1 333Mhz -8 2 266Mhz -8 3 200Mhz
checksums
diff --git a/src/mainboard/elmex/pcm205400/cmos.layout b/src/mainboard/elmex/pcm205400/cmos.layout index d7d5d12..42e0fea 100644 --- a/src/mainboard/elmex/pcm205400/cmos.layout +++ b/src/mainboard/elmex/pcm205400/cmos.layout @@ -8,15 +8,9 @@ 0 384 r 0 reserved_memory 384 1 e 4 boot_option 388 4 r 0 reboot_bits -395 1 e 1 hw_scrubber -396 1 e 1 interleave_chip_selects -397 2 e 8 max_mem_clock -399 1 e 2 multi_core 400 1 e 1 power_on_after_fail 412 4 e 6 debug_level 444 1 e 1 nmi -445 1 e 1 iommu -456 1 e 1 ECC_memory 728 256 h 0 user_data 984 16 h 0 check_sum # Reserve the extended AMD configuration registers @@ -27,18 +21,12 @@ #ID value text 1 0 Disable 1 1 Enable -2 0 Enable -2 1 Disable 4 0 Fallback 4 1 Normal 6 5 Notice 6 6 Info 6 7 Debug 6 8 Spew -8 0 400Mhz -8 1 333Mhz -8 2 266Mhz -8 3 200Mhz
checksums
diff --git a/src/mainboard/emulation/qemu-i440fx/cmos.default b/src/mainboard/emulation/qemu-i440fx/cmos.default index 8594b46..57750a2 100644 --- a/src/mainboard/emulation/qemu-i440fx/cmos.default +++ b/src/mainboard/emulation/qemu-i440fx/cmos.default @@ -1,4 +1,3 @@ boot_option=Fallback power_on_after_fail=Enable debug_level=Debug -ECC_memory=Disable diff --git a/src/mainboard/emulation/qemu-i440fx/cmos.layout b/src/mainboard/emulation/qemu-i440fx/cmos.layout index 8963e13..5e5a901 100644 --- a/src/mainboard/emulation/qemu-i440fx/cmos.layout +++ b/src/mainboard/emulation/qemu-i440fx/cmos.layout @@ -10,7 +10,6 @@
448 1 e 1 power_on_after_fail 452 4 e 6 debug_level -456 1 e 1 ECC_memory
# VBOOT 464 128 r 0 vbnv diff --git a/src/mainboard/emulation/qemu-q35/cmos.default b/src/mainboard/emulation/qemu-q35/cmos.default index 8594b46..57750a2 100644 --- a/src/mainboard/emulation/qemu-q35/cmos.default +++ b/src/mainboard/emulation/qemu-q35/cmos.default @@ -1,4 +1,3 @@ boot_option=Fallback power_on_after_fail=Enable debug_level=Debug -ECC_memory=Disable diff --git a/src/mainboard/emulation/qemu-q35/cmos.layout b/src/mainboard/emulation/qemu-q35/cmos.layout index 8963e13..5e5a901 100644 --- a/src/mainboard/emulation/qemu-q35/cmos.layout +++ b/src/mainboard/emulation/qemu-q35/cmos.layout @@ -10,7 +10,6 @@
# VBOOT 464 128 r 0 vbnv diff --git a/src/mainboard/gizmosphere/gizmo/cmos.layout b/src/mainboard/gizmosphere/gizmo/cmos.layout index d26d6aa..f6031ec 100644 --- a/src/mainboard/gizmosphere/gizmo/cmos.layout +++ b/src/mainboard/gizmosphere/gizmo/cmos.layout @@ -8,15 +8,9 @@ 0 384 r 0 reserved_memory 384 1 e 4 boot_option 388 4 h 0 reboot_counter -395 1 e 1 hw_scrubber -396 1 e 1 interleave_chip_selects -397 2 e 8 max_mem_clock -399 1 e 2 multi_core 400 1 e 1 power_on_after_fail 412 4 e 6 debug_level 444 1 e 1 nmi -445 1 e 1 iommu -456 1 e 1 ECC_memory 728 256 h 0 user_data 984 16 h 0 check_sum # Reserve the extended AMD configuration registers @@ -27,18 +21,12 @@ #ID value text 1 0 Disable 1 1 Enable -2 0 Enable -2 1 Disable 4 0 Fallback 4 1 Normal 6 5 Notice 6 6 Info 6 7 Debug 6 8 Spew -8 0 400Mhz -8 1 333Mhz -8 2 266Mhz -8 3 200Mhz
checksums
diff --git a/src/mainboard/gizmosphere/gizmo2/cmos.layout b/src/mainboard/gizmosphere/gizmo2/cmos.layout index d26d6aa..f6031ec 100644 --- a/src/mainboard/gizmosphere/gizmo2/cmos.layout +++ b/src/mainboard/gizmosphere/gizmo2/cmos.layout @@ -8,15 +8,9 @@ 0 384 r 0 reserved_memory 384 1 e 4 boot_option 388 4 h 0 reboot_counter -395 1 e 1 hw_scrubber -396 1 e 1 interleave_chip_selects -397 2 e 8 max_mem_clock -399 1 e 2 multi_core 400 1 e 1 power_on_after_fail 412 4 e 6 debug_level 444 1 e 1 nmi -445 1 e 1 iommu -456 1 e 1 ECC_memory 728 256 h 0 user_data 984 16 h 0 check_sum # Reserve the extended AMD configuration registers @@ -27,18 +21,12 @@ #ID value text 1 0 Disable 1 1 Enable -2 0 Enable -2 1 Disable 4 0 Fallback 4 1 Normal 6 5 Notice 6 6 Info 6 7 Debug 6 8 Spew -8 0 400Mhz -8 1 333Mhz -8 2 266Mhz -8 3 200Mhz
checksums
diff --git a/src/mainboard/hp/abm/cmos.layout b/src/mainboard/hp/abm/cmos.layout index d26d6aa..f6031ec 100644 --- a/src/mainboard/hp/abm/cmos.layout +++ b/src/mainboard/hp/abm/cmos.layout @@ -8,15 +8,9 @@ 0 384 r 0 reserved_memory 384 1 e 4 boot_option 388 4 h 0 reboot_counter -395 1 e 1 hw_scrubber -396 1 e 1 interleave_chip_selects -397 2 e 8 max_mem_clock -399 1 e 2 multi_core 400 1 e 1 power_on_after_fail 412 4 e 6 debug_level 444 1 e 1 nmi -445 1 e 1 iommu -456 1 e 1 ECC_memory 728 256 h 0 user_data 984 16 h 0 check_sum # Reserve the extended AMD configuration registers @@ -27,18 +21,12 @@ #ID value text 1 0 Disable 1 1 Enable -2 0 Enable -2 1 Disable 4 0 Fallback 4 1 Normal 6 5 Notice 6 6 Info 6 7 Debug 6 8 Spew -8 0 400Mhz -8 1 333Mhz -8 2 266Mhz -8 3 200Mhz
checksums
diff --git a/src/mainboard/jetway/nf81-t56n-lf/cmos.layout b/src/mainboard/jetway/nf81-t56n-lf/cmos.layout index d26d6aa..f6031ec 100644 --- a/src/mainboard/jetway/nf81-t56n-lf/cmos.layout +++ b/src/mainboard/jetway/nf81-t56n-lf/cmos.layout @@ -8,15 +8,9 @@ 0 384 r 0 reserved_memory 384 1 e 4 boot_option 388 4 h 0 reboot_counter -395 1 e 1 hw_scrubber -396 1 e 1 interleave_chip_selects -397 2 e 8 max_mem_clock -399 1 e 2 multi_core 400 1 e 1 power_on_after_fail 412 4 e 6 debug_level 444 1 e 1 nmi -445 1 e 1 iommu -456 1 e 1 ECC_memory 728 256 h 0 user_data 984 16 h 0 check_sum # Reserve the extended AMD configuration registers @@ -27,18 +21,12 @@ #ID value text 1 0 Disable 1 1 Enable -2 0 Enable -2 1 Disable 4 0 Fallback 4 1 Normal 6 5 Notice 6 6 Info 6 7 Debug 6 8 Spew -8 0 400Mhz -8 1 333Mhz -8 2 266Mhz -8 3 200Mhz
checksums
diff --git a/src/mainboard/lenovo/g505s/cmos.layout b/src/mainboard/lenovo/g505s/cmos.layout index 076ca9d..71bfd07 100644 --- a/src/mainboard/lenovo/g505s/cmos.layout +++ b/src/mainboard/lenovo/g505s/cmos.layout @@ -8,16 +8,10 @@ 0 384 r 0 reserved_memory 384 1 e 4 boot_option 388 4 h 0 reboot_counter -395 1 e 1 hw_scrubber -396 1 e 1 interleave_chip_selects -397 2 e 8 max_mem_clock -399 1 e 2 multi_core #400 8 r 8 reserved for century byte 408 1 e 1 power_on_after_fail 412 4 e 6 debug_level 444 1 e 1 nmi -445 1 e 1 iommu -456 1 e 1 ECC_memory 728 256 h 0 user_data 984 16 h 0 check_sum # Reserve the extended AMD configuration registers @@ -28,18 +22,12 @@ #ID value text 1 0 Disable 1 1 Enable -2 0 Enable -2 1 Disable 4 0 Fallback 4 1 Normal 6 5 Notice 6 6 Info 6 7 Debug 6 8 Spew -8 0 400Mhz -8 1 333Mhz -8 2 266Mhz -8 3 200Mhz
checksums
diff --git a/src/mainboard/lippert/frontrunner-af/cmos.layout b/src/mainboard/lippert/frontrunner-af/cmos.layout index d26d6aa..f6031ec 100644 --- a/src/mainboard/lippert/frontrunner-af/cmos.layout +++ b/src/mainboard/lippert/frontrunner-af/cmos.layout @@ -8,15 +8,9 @@ 0 384 r 0 reserved_memory 384 1 e 4 boot_option 388 4 h 0 reboot_counter -395 1 e 1 hw_scrubber -396 1 e 1 interleave_chip_selects -397 2 e 8 max_mem_clock -399 1 e 2 multi_core 400 1 e 1 power_on_after_fail 412 4 e 6 debug_level 444 1 e 1 nmi -445 1 e 1 iommu -456 1 e 1 ECC_memory 728 256 h 0 user_data 984 16 h 0 check_sum # Reserve the extended AMD configuration registers @@ -27,18 +21,12 @@ #ID value text 1 0 Disable 1 1 Enable -2 0 Enable -2 1 Disable 4 0 Fallback 4 1 Normal 6 5 Notice 6 6 Info 6 7 Debug 6 8 Spew -8 0 400Mhz -8 1 333Mhz -8 2 266Mhz -8 3 200Mhz
checksums
diff --git a/src/mainboard/msi/ms7721/cmos.layout b/src/mainboard/msi/ms7721/cmos.layout index d26d6aa..f6031ec 100644 --- a/src/mainboard/msi/ms7721/cmos.layout +++ b/src/mainboard/msi/ms7721/cmos.layout @@ -8,15 +8,9 @@ 0 384 r 0 reserved_memory 384 1 e 4 boot_option 388 4 h 0 reboot_counter -395 1 e 1 hw_scrubber -396 1 e 1 interleave_chip_selects -397 2 e 8 max_mem_clock -399 1 e 2 multi_core 400 1 e 1 power_on_after_fail 412 4 e 6 debug_level 444 1 e 1 nmi -445 1 e 1 iommu -456 1 e 1 ECC_memory 728 256 h 0 user_data 984 16 h 0 check_sum # Reserve the extended AMD configuration registers @@ -27,18 +21,12 @@ #ID value text 1 0 Disable 1 1 Enable -2 0 Enable -2 1 Disable 4 0 Fallback 4 1 Normal 6 5 Notice 6 6 Info 6 7 Debug 6 8 Spew -8 0 400Mhz -8 1 333Mhz -8 2 266Mhz -8 3 200Mhz
checksums
diff --git a/src/mainboard/pcengines/apu1/cmos.default b/src/mainboard/pcengines/apu1/cmos.default index 0906d5a..06b0433 100644 --- a/src/mainboard/pcengines/apu1/cmos.default +++ b/src/mainboard/pcengines/apu1/cmos.default @@ -1,3 +1,2 @@ boot_option=Fallback -multi_core=Enable debug_level=Debug diff --git a/src/mainboard/pcengines/apu1/cmos.layout b/src/mainboard/pcengines/apu1/cmos.layout index dd3cd91..e36dd6b 100644 --- a/src/mainboard/pcengines/apu1/cmos.layout +++ b/src/mainboard/pcengines/apu1/cmos.layout @@ -5,7 +5,6 @@ 384 4 r 0 reboot_bits # leave 3 bits to make checksummed area start byte-aligned 392 1 e 2 boot_option -393 1 e 1 multi_core 400 4 e 4 debug_level # leave 7 bits to make checksummed area end byte-aligned 408 16 h 0 check_sum @@ -13,9 +12,6 @@ enumerations
#<config-id> <value> <label> -## for multi_core -1 0 Enable -1 1 Disable ## for boot_option 2 0 Fallback 2 1 Normal diff --git a/src/mainboard/pcengines/apu2/cmos.layout b/src/mainboard/pcengines/apu2/cmos.layout index d7d5d12..42e0fea 100644 --- a/src/mainboard/pcengines/apu2/cmos.layout +++ b/src/mainboard/pcengines/apu2/cmos.layout @@ -8,15 +8,9 @@ 0 384 r 0 reserved_memory 384 1 e 4 boot_option 388 4 r 0 reboot_bits -395 1 e 1 hw_scrubber -396 1 e 1 interleave_chip_selects -397 2 e 8 max_mem_clock -399 1 e 2 multi_core 400 1 e 1 power_on_after_fail 412 4 e 6 debug_level 444 1 e 1 nmi -445 1 e 1 iommu -456 1 e 1 ECC_memory 728 256 h 0 user_data 984 16 h 0 check_sum # Reserve the extended AMD configuration registers @@ -27,18 +21,12 @@ #ID value text 1 0 Disable 1 1 Enable -2 0 Enable -2 1 Disable 4 0 Fallback 4 1 Normal 6 5 Notice 6 6 Info 6 7 Debug 6 8 Spew -8 0 400Mhz -8 1 333Mhz -8 2 266Mhz -8 3 200Mhz
checksums
Hello Michał Żygowski, Alexander Couzens, Patrick Rudolph, Piotr Król,
Change-Id: If0cb1d716fa0a7da249e72c7c006849371f49835 Signed-off-by: Angel Pons th3fanbus@gmail.com --- M src/mainboard/amd/inagua/cmos.layout M src/mainboard/amd/olivehill/cmos.layout M src/mainboard/amd/parmer/cmos.layout M src/mainboard/amd/persimmon/cmos.layout M src/mainboard/amd/south_station/cmos.layout M src/mainboard/amd/thatcher/cmos.layout M src/mainboard/amd/union_station/cmos.layout M src/mainboard/asrock/e350m1/cmos.layout M src/mainboard/asrock/imb-a180/cmos.layout M src/mainboard/asus/a88xm-e/cmos.layout M src/mainboard/asus/f2a85-m/cmos.layout M src/mainboard/bap/ode_e20XX/cmos.layout M src/mainboard/biostar/a68n_5200/cmos.layout M src/mainboard/biostar/am1ml/cmos.layout M src/mainboard/elmex/pcm205400/cmos.layout M src/mainboard/emulation/qemu-i440fx/cmos.default M src/mainboard/emulation/qemu-i440fx/cmos.layout M src/mainboard/emulation/qemu-q35/cmos.default M src/mainboard/emulation/qemu-q35/cmos.layout M src/mainboard/gizmosphere/gizmo/cmos.layout M src/mainboard/gizmosphere/gizmo2/cmos.layout M src/mainboard/hp/abm/cmos.layout M src/mainboard/jetway/nf81-t56n-lf/cmos.layout M src/mainboard/lenovo/g505s/cmos.layout M src/mainboard/lippert/frontrunner-af/cmos.layout M src/mainboard/msi/ms7721/cmos.layout M src/mainboard/pcengines/apu1/cmos.default M src/mainboard/pcengines/apu1/cmos.layout M src/mainboard/pcengines/apu2/cmos.layout 29 files changed, 0 insertions(+), 492 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/79/47179/2
Michael Niewöhner has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/47179 )
Patch Set 3:
check the cmos.default files, too, please
Angel Pons has abandoned this change. ( https://review.coreboot.org/c/coreboot/+/47179 )
Abandoned
