Attention is currently required from: Jason Nien, Jon Murphy, Martin Roth.
Hello Jason Nien, Karthik Ramasubramanian, Martin Roth, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/85294?usp=email
Change subject: mb/google/zork: Update FP enable ......................................................................
Add/update FP enable/disable based on SKU ID. This is meant to resolve a UMA issue with devices that had the FPMCU populated on non-fp devices. Since the FPMCU is present, and the firmware enables the power GPIO's based on variant, not SKU, the devices were reporting data on fingerprint errantly. Specify the SKUs which should not have a FP sensor and default to true to maintain the legacy behavior for undefined devices and limit risk. Variants which do not have FP SKUs will be unaffected.
BUG=b:354769653 TEST=Flash to zork, test FP. Disable test SKU, flash on zork, test FP.
To test, run `ectool --name=cros_fp version` in the shell When enabled, the fpmcu fw version should be displayed. When disabled, an error should be displayed because the fpmcu is inaccessible.
Change-Id: Ic6dc71013a1c0d5ee5263109eed87a1b31800232 Signed-off-by: Jon Murphy jpmurphy@google.com --- M src/mainboard/google/zork/variants/berknip/variant.c M src/mainboard/google/zork/variants/morphius/variant.c 2 files changed, 112 insertions(+), 23 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/94/85294/3
