Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/59297 )
Change subject: util/mb/google: Change comments in memory Makefile.inc templates ......................................................................
Begin comments with # instead of ## to match the Makefile.inc generated by spd_tools.
BUG=None TEST=None
Signed-off-by: Reka Norman rekanorman@google.com Change-Id: If2d716a7338fd5af8216b2bcd894fc88a9df137e Reviewed-on: https://review.coreboot.org/c/coreboot/+/59297 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Tim Wawrzynczak twawrzynczak@chromium.org --- M util/mainboard/google/brya0/template/memory/Makefile.inc M util/mainboard/google/dalboz/template/spd/Makefile.inc M util/mainboard/google/guybrush/template/memory/Makefile.inc M util/mainboard/google/trembyle/template/spd/Makefile.inc M util/mainboard/google/volteer/template/memory/Makefile.inc M util/mainboard/google/waddledee/template/memory/Makefile.inc M util/mainboard/google/waddledoo/template/memory/Makefile.inc 7 files changed, 21 insertions(+), 21 deletions(-)
diff --git a/util/mainboard/google/brya0/template/memory/Makefile.inc b/util/mainboard/google/brya0/template/memory/Makefile.inc index 6751a42..eace2e4 100644 --- a/util/mainboard/google/brya0/template/memory/Makefile.inc +++ b/util/mainboard/google/brya0/template/memory/Makefile.inc @@ -1,5 +1,5 @@ -## SPDX-License-Identifier: GPL-2.0-or-later -## This is an auto-generated file. Do not edit!! -## Add memory parts in mem_parts_used.txt and run spd_tools to regenerate. +# SPDX-License-Identifier: GPL-2.0-or-later +# This is an auto-generated file. Do not edit!! +# Add memory parts in mem_parts_used.txt and run spd_tools to regenerate.
SPD_SOURCES = placeholder diff --git a/util/mainboard/google/dalboz/template/spd/Makefile.inc b/util/mainboard/google/dalboz/template/spd/Makefile.inc index 6751a42..eace2e4 100644 --- a/util/mainboard/google/dalboz/template/spd/Makefile.inc +++ b/util/mainboard/google/dalboz/template/spd/Makefile.inc @@ -1,5 +1,5 @@ -## SPDX-License-Identifier: GPL-2.0-or-later -## This is an auto-generated file. Do not edit!! -## Add memory parts in mem_parts_used.txt and run spd_tools to regenerate. +# SPDX-License-Identifier: GPL-2.0-or-later +# This is an auto-generated file. Do not edit!! +# Add memory parts in mem_parts_used.txt and run spd_tools to regenerate.
SPD_SOURCES = placeholder diff --git a/util/mainboard/google/guybrush/template/memory/Makefile.inc b/util/mainboard/google/guybrush/template/memory/Makefile.inc index 6751a42..eace2e4 100644 --- a/util/mainboard/google/guybrush/template/memory/Makefile.inc +++ b/util/mainboard/google/guybrush/template/memory/Makefile.inc @@ -1,5 +1,5 @@ -## SPDX-License-Identifier: GPL-2.0-or-later -## This is an auto-generated file. Do not edit!! -## Add memory parts in mem_parts_used.txt and run spd_tools to regenerate. +# SPDX-License-Identifier: GPL-2.0-or-later +# This is an auto-generated file. Do not edit!! +# Add memory parts in mem_parts_used.txt and run spd_tools to regenerate.
SPD_SOURCES = placeholder diff --git a/util/mainboard/google/trembyle/template/spd/Makefile.inc b/util/mainboard/google/trembyle/template/spd/Makefile.inc index 6751a42..eace2e4 100644 --- a/util/mainboard/google/trembyle/template/spd/Makefile.inc +++ b/util/mainboard/google/trembyle/template/spd/Makefile.inc @@ -1,5 +1,5 @@ -## SPDX-License-Identifier: GPL-2.0-or-later -## This is an auto-generated file. Do not edit!! -## Add memory parts in mem_parts_used.txt and run spd_tools to regenerate. +# SPDX-License-Identifier: GPL-2.0-or-later +# This is an auto-generated file. Do not edit!! +# Add memory parts in mem_parts_used.txt and run spd_tools to regenerate.
SPD_SOURCES = placeholder diff --git a/util/mainboard/google/volteer/template/memory/Makefile.inc b/util/mainboard/google/volteer/template/memory/Makefile.inc index 6751a42..eace2e4 100644 --- a/util/mainboard/google/volteer/template/memory/Makefile.inc +++ b/util/mainboard/google/volteer/template/memory/Makefile.inc @@ -1,5 +1,5 @@ -## SPDX-License-Identifier: GPL-2.0-or-later -## This is an auto-generated file. Do not edit!! -## Add memory parts in mem_parts_used.txt and run spd_tools to regenerate. +# SPDX-License-Identifier: GPL-2.0-or-later +# This is an auto-generated file. Do not edit!! +# Add memory parts in mem_parts_used.txt and run spd_tools to regenerate.
SPD_SOURCES = placeholder diff --git a/util/mainboard/google/waddledee/template/memory/Makefile.inc b/util/mainboard/google/waddledee/template/memory/Makefile.inc index 6751a42..eace2e4 100644 --- a/util/mainboard/google/waddledee/template/memory/Makefile.inc +++ b/util/mainboard/google/waddledee/template/memory/Makefile.inc @@ -1,5 +1,5 @@ -## SPDX-License-Identifier: GPL-2.0-or-later -## This is an auto-generated file. Do not edit!! -## Add memory parts in mem_parts_used.txt and run spd_tools to regenerate. +# SPDX-License-Identifier: GPL-2.0-or-later +# This is an auto-generated file. Do not edit!! +# Add memory parts in mem_parts_used.txt and run spd_tools to regenerate.
SPD_SOURCES = placeholder diff --git a/util/mainboard/google/waddledoo/template/memory/Makefile.inc b/util/mainboard/google/waddledoo/template/memory/Makefile.inc index 6751a42..eace2e4 100644 --- a/util/mainboard/google/waddledoo/template/memory/Makefile.inc +++ b/util/mainboard/google/waddledoo/template/memory/Makefile.inc @@ -1,5 +1,5 @@ -## SPDX-License-Identifier: GPL-2.0-or-later -## This is an auto-generated file. Do not edit!! -## Add memory parts in mem_parts_used.txt and run spd_tools to regenerate. +# SPDX-License-Identifier: GPL-2.0-or-later +# This is an auto-generated file. Do not edit!! +# Add memory parts in mem_parts_used.txt and run spd_tools to regenerate.
