Felix Held has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/59934 )
Change subject: [TESTME] sb/amd/pi/hudson/early_init: fix setting SPI_USE_SPI100 in SPI100_ENABLE ......................................................................
Use a read modify write sequence when setting the SPI_USE_SPI100 bit in the SPI100_ENABLE register. This avoids clearing other bits in the register which might cause instabilities. Haven't checked the reference code, but the register descriptions suggested that the register in Mullins behaves similar to the one in Stoneyridge.
TEST=None
Signed-off-by: Felix Held felix-coreboot@felixheld.de Change-Id: Ifbd960a9509542b28f03326a3066995540260bef --- M src/southbridge/amd/pi/hudson/early_setup.c 1 file changed, 2 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/34/59934/1
diff --git a/src/southbridge/amd/pi/hudson/early_setup.c b/src/southbridge/amd/pi/hudson/early_setup.c index 20597d4..2617985 100644 --- a/src/southbridge/amd/pi/hudson/early_setup.c +++ b/src/southbridge/amd/pi/hudson/early_setup.c @@ -215,7 +215,8 @@ (fast << SPI_FAST_SPEED_NEW_SH) | (alt << SPI_ALT_SPEED_NEW_SH) | (tpm << SPI_TPM_SPEED_NEW_SH)); - write16((void *)(base + SPI100_ENABLE), SPI_USE_SPI100); + write16((void *)(base + SPI100_ENABLE), SPI_USE_SPI100 | + read16((void *)(base + SPI100_ENABLE))); }
void hudson_disable_4dw_burst(void)
