Mario Scheithauer has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/31802
Change subject: src/soc/intel/apollolake/cpu.c: Set up local APIC ......................................................................
Some Apollo Lake mainboards use SeaBIOS as payload. SeaBIOS requires the initialization of the programmable interrupt controller (PIC) for faultless operation. Therefore add setup_lapic() to configure the APIC.
Change-Id: I00b339ce1850729023db74da7f8845927a95dcc6 Signed-off-by: Mario Scheithauer mario.scheithauer@siemens.com --- M src/soc/intel/apollolake/cpu.c 1 file changed, 6 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/02/31802/1
diff --git a/src/soc/intel/apollolake/cpu.c b/src/soc/intel/apollolake/cpu.c index a08f1f0..7d42d6b 100644 --- a/src/soc/intel/apollolake/cpu.c +++ b/src/soc/intel/apollolake/cpu.c @@ -2,7 +2,7 @@ * This file is part of the coreboot project. * * Copyright (C) 2015-2017 Intel Corp. - * Copyright (C) 2017 Siemens AG, Inc. + * Copyright (C) 2017-2019 Siemens AG * (Written by Andrey Petrov andrey.petrov@intel.com for Intel Corp.) * (Written by Alexandru Gagniuc alexandrux.gagniuc@intel.com for Intel Corp.) * @@ -23,6 +23,7 @@ #include "chip.h" #include <cpu/cpu.h> #include <cpu/x86/cache.h> +#include <cpu/x86/lapic.h> #include <cpu/x86/mp.h> #include <cpu/intel/microcode.h> #include <cpu/intel/turbo.h> @@ -161,6 +162,10 @@ } x86_setup_mtrrs_with_detect(); x86_mtrr_check(); + + /* Enable the local CPU apics */ + if (IS_ENABLED(CONFIG_PAYLOAD_SEABIOS)) + setup_lapic(); }
#if !IS_ENABLED(CONFIG_SOC_INTEL_COMMON_BLOCK_CPU_MPINIT)
Patrick Rudolph has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/31802 )
Patch Set 1: Code-Review+1
Why not always initialize it?
Johannes Hahn has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/31802 )
Patch Set 1:
https://review.coreboot.org/#/c/31802/1/src/soc/intel/apollolake/cpu.c File src/soc/intel/apollolake/cpu.c:
https://review.coreboot.org/#/c/31802/1/src/soc/intel/apollolake/cpu.c@167 PS1, Line 167: CONFIG_PAYLOAD_SEABIOS May be you should remark that this KConfig switch is only set when integrating SeaBios during the coreboot build process implicitly. When building SeaBios explicitly and adding it as ELF executeable payload CONFIG_PAYLOAD_SEABIOS has to be set also explicitly.
Hello Johannes Hahn, Patrick Rudolph, Patrick Rudolph, build bot (Jenkins),
Change-Id: I00b339ce1850729023db74da7f8845927a95dcc6 Signed-off-by: Mario Scheithauer mario.scheithauer@siemens.com --- M src/soc/intel/apollolake/cpu.c 1 file changed, 5 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/02/31802/2
Mario Scheithauer has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/31802 )
Patch Set 1:
Johannes wrote it a little later...of course, you can also include SeaBIOS as an ELF executable and then we don’t have the switch. I removed the switch.
Patch Set 2:
May be you should remark that this KConfig switch is only set when integrating SeaBios during the co […]
You're right. I removed the switch.
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/31802 )
Patch Set 2:
(2 comments)
https://review.coreboot.org/#/c/31802/2//COMMIT_MSG Commit Message:
https://review.coreboot.org/#/c/31802/2//COMMIT_MSG@11 PS2, Line 11: faultless Please add the details on the error.
https://review.coreboot.org/#/c/31802/2//COMMIT_MSG@12 PS2, Line 12: Tested how?
Some Apollo Lake mainboards use SeaBIOS as payload. SeaBIOS requires the initialization of the programmable interrupt controller (PIC) for faultless operation. The PIC mode is need for USB support (e.g. keyboard, memory stick) and for some Option ROMs (e.g. PXE ROM). Therefore add setup_lapic() to configure the APIC.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/02/31802/3
Patch Set 3:
(2 comments)
Done
Tested how?
Hi Paul, I think with the addition in the description, the test clears itself as well.
Patch Set 3: Code-Review+2
Nico Huber has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/31802 )
Patch Set 3:
lol, I was about to mention that we usually do this on all cores and not just the BSP. The comments in `cpu/x86/ lapic/lapic.c` convinced me otherwise ;)
Patch Set 3:
https://review.coreboot.org/#/c/31802/3/src/soc/intel/apollolake/cpu.c File src/soc/intel/apollolake/cpu.c:
https://review.coreboot.org/#/c/31802/3/src/soc/intel/apollolake/cpu.c@5 PS3, Line 5: * Copyright (C) 2017-2019 Siemens AG This `2017-2019` implies that you claim to have added something in 2018, too.
Nico Huber has submitted this change and it was merged. ( https://review.coreboot.org/c/coreboot/+/31802 )
Change-Id: I00b339ce1850729023db74da7f8845927a95dcc6 Signed-off-by: Mario Scheithauer mario.scheithauer@siemens.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/31802 Reviewed-by: Patrick Rudolph siro@das-labor.org Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/soc/intel/apollolake/cpu.c 1 file changed, 5 insertions(+), 1 deletion(-)
Approvals: build bot (Jenkins): Verified Patrick Rudolph: Looks good to me, approved
diff --git a/src/soc/intel/apollolake/cpu.c b/src/soc/intel/apollolake/cpu.c index 741e08c..8f1d933 100644 --- a/src/soc/intel/apollolake/cpu.c +++ b/src/soc/intel/apollolake/cpu.c @@ -2,7 +2,7 @@ * This file is part of the coreboot project. * * Copyright (C) 2015-2017 Intel Corp. - * Copyright (C) 2017 Siemens AG, Inc. + * Copyright (C) 2017-2019 Siemens AG * (Written by Andrey Petrov andrey.petrov@intel.com for Intel Corp.) * (Written by Alexandru Gagniuc alexandrux.gagniuc@intel.com for Intel Corp.) * @@ -23,6 +23,7 @@ #include "chip.h" #include <cpu/cpu.h> #include <cpu/x86/cache.h> +#include <cpu/x86/lapic.h> #include <cpu/x86/mp.h> #include <cpu/intel/microcode.h> #include <cpu/intel/turbo.h> @@ -161,6 +162,9 @@ } x86_setup_mtrrs_with_detect(); x86_mtrr_check(); + + /* Enable the local CPU apics */ + setup_lapic(); }
#if !CONFIG(SOC_INTEL_COMMON_BLOCK_CPU_MPINIT)
Patch Set 4:
All right, I'll keep that in mind next time.
