Attention is currently required from: Martin Roth, Frans Hendriks, Wim Vervoorn. Arthur Heymans has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/52133 )
Change subject: drivers/tpm/Kconfig: Rename TPM_INIT to TPM_INIT_RAMSTAGE ......................................................................
Rename the Kconfig parameter to more accurately reflect what it does. TPM can be initialised in a different stage too, for instance with VBOOT it is done in verstage.
Change-Id: Ic0126b356e8430c04c7c9fd46d4e20022a648738 Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- M src/drivers/tpm/Kconfig M src/drivers/tpm/Makefile.inc M src/mainboard/facebook/fbg1701/Kconfig M src/mainboard/facebook/monolith/Kconfig 4 files changed, 4 insertions(+), 4 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/33/52133/1
diff --git a/src/drivers/tpm/Kconfig b/src/drivers/tpm/Kconfig index baf760b..96c855b 100644 --- a/src/drivers/tpm/Kconfig +++ b/src/drivers/tpm/Kconfig @@ -1,4 +1,4 @@ -config TPM_INIT +config TPM_INIT_RAMSTAGE bool default y if TPM1 || TPM2 depends on !VBOOT diff --git a/src/drivers/tpm/Makefile.inc b/src/drivers/tpm/Makefile.inc index af6e5a21..9833eb4 100644 --- a/src/drivers/tpm/Makefile.inc +++ b/src/drivers/tpm/Makefile.inc @@ -1,4 +1,4 @@ -ramstage-$(CONFIG_TPM_INIT) += tpm.c +ramstage-$(CONFIG_TPM_INIT_RAMSTAGE) += tpm.c
ifeq ($(CONFIG_TPM_PPI),y) ramstage-$(CONFIG_HAVE_ACPI_TABLES) += ppi.c diff --git a/src/mainboard/facebook/fbg1701/Kconfig b/src/mainboard/facebook/fbg1701/Kconfig index e01f979..1e6c32c 100644 --- a/src/mainboard/facebook/fbg1701/Kconfig +++ b/src/mainboard/facebook/fbg1701/Kconfig @@ -88,7 +88,7 @@ bool default y
-config TPM_INIT +config TPM_INIT_RAMSTAGE bool "TPM Setup in RAMSTAGE" default n
diff --git a/src/mainboard/facebook/monolith/Kconfig b/src/mainboard/facebook/monolith/Kconfig index ddbc27e..127cd50 100644 --- a/src/mainboard/facebook/monolith/Kconfig +++ b/src/mainboard/facebook/monolith/Kconfig @@ -68,7 +68,7 @@ int default 2
-config TPM_INIT +config TPM_INIT_RAMSTAGE bool default n
