Attention is currently required from: Andrey Pronin, Raul Rangel, Christian Walter, Karthik Ramasubramanian. Hello build bot (Jenkins), Andrey Pronin, Raul Rangel, Christian Walter, Karthik Ramasubramanian,
https://review.coreboot.org/c/coreboot/+/59479
Change subject: drivers/tpm: Add firmware-power-managed DSD property ......................................................................
Introduce firmware-power-managed DSD ACPI property for TPM devices. This property can be checked by the kernel TPM driver to override how the TPM power states are managed. This is a tri-state flag, true, false, or unset. So an enum used to keep the flag is unset by default.
When firmware-power-managed is true, the kernel driver will not send a shutdown during s2idle/s0i3 suspend.
BUG=b:200578885 BRANCH=None TEST=Shutdown is triggered on s0ix suspend on guybrush with patched kernel
Change-Id: Ia48ead856fc0c6e637a2e07a5ecc58423f599c5b Signed-off-by: Rob Barnes robbarnes@google.com --- M src/drivers/i2c/tpm/chip.c M src/drivers/i2c/tpm/chip.h 2 files changed, 23 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/79/59479/4
