Kyösti Mälkki (kyosti.malkki@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/7859
commit ed1d0244e480cd7586bae94538d58c3a37b48da3 Author: Kyösti Mälkki kyosti.malkki@gmail.com Date: Wed Dec 31 19:29:02 2014 +0200
CBMEM: Move cbmemc_reinit()
This replaces need for separate cbmemc_reinit() calls made via CAR_MIGRATE() and in ramstage.
Change-Id: If7b4d855c75df58b173f26ef3c90a4a7563166d3 Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- src/arch/x86/boot/cbmem.c | 4 ++++ src/lib/cbmem.c | 2 -- src/lib/cbmem_common.c | 5 +++++ src/lib/dynamic_cbmem.c | 2 -- src/mainboard/google/nyan/romstage.c | 5 ----- src/mainboard/google/nyan_big/romstage.c | 5 ----- src/mainboard/google/nyan_blaze/romstage.c | 5 ----- src/mainboard/via/epia-m850/romstage.c | 1 - src/soc/intel/fsp_baytrail/romstage/romstage.c | 1 - 9 files changed, 9 insertions(+), 21 deletions(-)
diff --git a/src/arch/x86/boot/cbmem.c b/src/arch/x86/boot/cbmem.c index bbf70a2..b53745b 100644 --- a/src/arch/x86/boot/cbmem.c +++ b/src/arch/x86/boot/cbmem.c @@ -22,6 +22,7 @@
/* FIXME: Remove after CBMEM_INIT_HOOKS. */ #include <cpu/x86/gdt.h> +#include <console/cbmem_console.h>
#if !CONFIG_DYNAMIC_CBMEM void get_cbmem_table(uint64_t *base, uint64_t *size) @@ -75,6 +76,9 @@ void *cbmem_top(void) void cbmem_run_init_hooks(void) { #if !defined(__PRE_RAM__) + /* Relocate CBMEM console. */ + cbmemc_reinit(); + move_gdt(); #endif } diff --git a/src/lib/cbmem.c b/src/lib/cbmem.c index 5f834b7..ba6560c 100644 --- a/src/lib/cbmem.c +++ b/src/lib/cbmem.c @@ -23,7 +23,6 @@ #include <bootstate.h> #include <cbmem.h> #include <console/console.h> -#include <console/cbmem_console.h> #include <arch/early_variables.h> #if CONFIG_HAVE_ACPI_RESUME && !defined(__PRE_RAM__) #include <arch/acpi.h> @@ -256,7 +255,6 @@ static void init_cbmem_post_device(void *unused) #else cbmem_recovery(0); #endif - cbmemc_reinit(); }
BOOT_STATE_INIT_ENTRIES(cbmem_bscb) = { diff --git a/src/lib/cbmem_common.c b/src/lib/cbmem_common.c index 438fd7f..1630628 100644 --- a/src/lib/cbmem_common.c +++ b/src/lib/cbmem_common.c @@ -20,6 +20,9 @@ #include <cbmem.h> #include <stdlib.h>
+/* FIXME: Remove after CBMEM_INIT_HOOKS. */ +#include <console/cbmem_console.h> + #ifndef __PRE_RAM__
static const struct cbmem_id_to_name cbmem_ids[] = { CBMEM_ID_TO_NAME_TABLE }; @@ -52,6 +55,8 @@ void cbmem_print_entry(int n, u32 id, u64 base, u64 size) #if !IS_ENABLED(CONFIG_ARCH_X86) void cbmem_run_init_hooks(void) { + /* Relocate CBMEM console. */ + cbmemc_reinit(); }
void __attribute__((weak)) cbmem_fail_resume(void) diff --git a/src/lib/dynamic_cbmem.c b/src/lib/dynamic_cbmem.c index ce4e625..a5f2fc2 100644 --- a/src/lib/dynamic_cbmem.c +++ b/src/lib/dynamic_cbmem.c @@ -21,7 +21,6 @@ #include <bootmem.h> #include <console/console.h> #include <cbmem.h> -#include <console/cbmem_console.h> #include <string.h> #include <stdlib.h> #include <arch/early_variables.h> @@ -426,7 +425,6 @@ void *cbmem_entry_start(const struct cbmem_entry *entry) static void init_cbmem_pre_device(void *unused) { cbmem_initialize(); - cbmemc_reinit(); }
BOOT_STATE_INIT_ENTRIES(cbmem_bscb) = { diff --git a/src/mainboard/google/nyan/romstage.c b/src/mainboard/google/nyan/romstage.c index 4e02365..749b87d 100644 --- a/src/mainboard/google/nyan/romstage.c +++ b/src/mainboard/google/nyan/romstage.c @@ -25,7 +25,6 @@ #include <device/device.h> #include <cbfs.h> #include <cbmem.h> -#include <console/cbmem_console.h> #include <console/console.h> #include <mainboard/google/nyan/reset.h> #include <romstage_handoff.h> @@ -224,10 +223,6 @@ static void __attribute__((noinline)) romstage(void) configure_ec_spi_bus(); configure_tpm_i2c_bus();
-#if CONFIG_CONSOLE_CBMEM - cbmemc_reinit(); -#endif - vboot_verify_firmware(romstage_handoff_find_or_add());
timestamp_add(TS_START_COPYRAM, timestamp_get()); diff --git a/src/mainboard/google/nyan_big/romstage.c b/src/mainboard/google/nyan_big/romstage.c index 4e02365..749b87d 100644 --- a/src/mainboard/google/nyan_big/romstage.c +++ b/src/mainboard/google/nyan_big/romstage.c @@ -25,7 +25,6 @@ #include <device/device.h> #include <cbfs.h> #include <cbmem.h> -#include <console/cbmem_console.h> #include <console/console.h> #include <mainboard/google/nyan/reset.h> #include <romstage_handoff.h> @@ -224,10 +223,6 @@ static void __attribute__((noinline)) romstage(void) configure_ec_spi_bus(); configure_tpm_i2c_bus();
timestamp_add(TS_START_COPYRAM, timestamp_get()); diff --git a/src/mainboard/google/nyan_blaze/romstage.c b/src/mainboard/google/nyan_blaze/romstage.c index 4e02365..749b87d 100644 --- a/src/mainboard/google/nyan_blaze/romstage.c +++ b/src/mainboard/google/nyan_blaze/romstage.c @@ -25,7 +25,6 @@ #include <device/device.h> #include <cbfs.h> #include <cbmem.h> -#include <console/cbmem_console.h> #include <console/console.h> #include <mainboard/google/nyan/reset.h> #include <romstage_handoff.h> @@ -224,10 +223,6 @@ static void __attribute__((noinline)) romstage(void) configure_ec_spi_bus(); configure_tpm_i2c_bus();
timestamp_add(TS_START_COPYRAM, timestamp_get()); diff --git a/src/mainboard/via/epia-m850/romstage.c b/src/mainboard/via/epia-m850/romstage.c index b6e3635..8912d13 100644 --- a/src/mainboard/via/epia-m850/romstage.c +++ b/src/mainboard/via/epia-m850/romstage.c @@ -31,7 +31,6 @@ #include <cpu/x86/bist.h> #include <string.h> #include <timestamp.h> -#include <console/cbmem_console.h>
#include <northbridge/via/vx900/early_vx900.h> #include <northbridge/via/vx900/raminit.h> diff --git a/src/soc/intel/fsp_baytrail/romstage/romstage.c b/src/soc/intel/fsp_baytrail/romstage/romstage.c index ad42e73..b0b8133 100644 --- a/src/soc/intel/fsp_baytrail/romstage/romstage.c +++ b/src/soc/intel/fsp_baytrail/romstage/romstage.c @@ -43,7 +43,6 @@ #include <version.h> #include <pc80/mc146818rtc.h> #include <device/pci_def.h> -#include <console/cbmem_console.h>
/* Return 0, 3, 4 or 5 to indicate the previous sleep state. */ uint32_t chipset_prev_sleep_state(uint32_t clear)
