Denis Carikli (GNUtoo@no-log.org) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/3585
commit 6aaf65b28434bf40aaf5c1258bc16cbff6ab1c99 Author: Denis 'GNUtoo' Carikli GNUtoo@no-log.org Date: Mon Jul 1 08:39:51 2013 +0200
Makefile: fix config.h leaking to the next build when using CONFIG_UPDATE_IMAGE.
When we build a first image with the fallback/ prefix, with the CONFIG_MAINBOARD_DO_NATIVE_VGA_INIT option, and without CONFIG_UPDATE_IMAGE, the image builds fine, and build/coreboot.rom is generated.
Then if when we run "make menuconfig" and select CONFIG_UPDATE_IMAGE along with different options( here we will unselect the CONFIG_MAINBOARD_DO_NATIVE_VGA_INIT ), we then have a build failure like that: build/generated/coreboot_ram.o: In function `gma_func0_init': [...]/src/northbridge/intel/i945/gma.c:62: undefined reference to `i915lightup' build/generated/coreboot_ram.o: In function `lb_framebuffer': [...]/src/lib/coreboot_table.c:176: undefined reference to `vbe_mode_info_valid' [...]/src/lib/coreboot_table.c:182: undefined reference to `fill_lb_framebuffer' collect2: error: ld returned 1 exit status despite of having #if CONFIG_MAINBOARD_DO_NATIVE_VGA_INIT and #endif surrounding the usage of i915lightup in [...]/src/northbridge/intel/i945/gma.c It is due to the fact that build/config.h has #define CONFIG_MAINBOARD_DO_NATIVE_VGA_INIT 1 in it, despite of having selected CONFIG_MAINBOARD_DO_NATIVE_VGA_INIT only in the first build(the one with the /fallback prefix).
Change-Id: I345c2359876918eba1019f25d86d1392f4ee85e1 Signed-off-by: Denis 'GNUtoo' Carikli GNUtoo@no-log.org --- Makefile | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/Makefile b/Makefile index dec32e5..fbe68fa 100644 --- a/Makefile +++ b/Makefile @@ -82,7 +82,10 @@ HOSTCXXFLAGS := -g DOXYGEN := doxygen DOXYGEN_OUTPUT_DIR := doxygen
-all: real-all +all: clean-config real-all + +clean-config: + rm -f $(obj)/config.h
# This include must come _before_ the pattern rules below! # Order _does_ matter for pattern rules.
