Werner Zeh has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/61827 )
Change subject: mb/siemens/mc_apl{2,4,5,6}: Enable recovery MRC cache ......................................................................
The mainboards mc_apl{2,4,5,6} use VBOOT for verification and can be in a recovery state for different reasons. In this case we still want the MRC cache to be around to avoid the DRAM retraining on every boot.
This patch enables the Kconfig switch HAS_RECOVERY_MRC_CACHE which makes the already available MRC recovery region in FMAP useable.
Test=Boot mc_apl2 in recovery mode and make sure the recovery MRC cache is used.
Change-Id: I2ea4993f05dd87a0e637f55e84b4fc06f5e29ecc Signed-off-by: Werner Zeh werner.zeh@siemens.com --- M src/mainboard/siemens/mc_apl1/variants/mc_apl2/Kconfig M src/mainboard/siemens/mc_apl1/variants/mc_apl4/Kconfig M src/mainboard/siemens/mc_apl1/variants/mc_apl5/Kconfig M src/mainboard/siemens/mc_apl1/variants/mc_apl6/Kconfig 4 files changed, 4 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/27/61827/1
diff --git a/src/mainboard/siemens/mc_apl1/variants/mc_apl2/Kconfig b/src/mainboard/siemens/mc_apl1/variants/mc_apl2/Kconfig index 3e062a4..af1a572 100644 --- a/src/mainboard/siemens/mc_apl1/variants/mc_apl2/Kconfig +++ b/src/mainboard/siemens/mc_apl1/variants/mc_apl2/Kconfig @@ -11,6 +11,7 @@ select MAINBOARD_HAS_LPC_TPM select TPM_ON_FAST_SPI select TPM_MEASURED_BOOT + select HAS_RECOVERY_MRC_CACHE
config CBFS_SIZE default 0xb4e000 diff --git a/src/mainboard/siemens/mc_apl1/variants/mc_apl4/Kconfig b/src/mainboard/siemens/mc_apl1/variants/mc_apl4/Kconfig index 6cf02ab..53729c2 100644 --- a/src/mainboard/siemens/mc_apl1/variants/mc_apl4/Kconfig +++ b/src/mainboard/siemens/mc_apl1/variants/mc_apl4/Kconfig @@ -10,6 +10,7 @@ select TPM_ON_FAST_SPI select DRIVERS_I2C_PTN3460 select TPM_MEASURED_BOOT + select HAS_RECOVERY_MRC_CACHE
config UART_FOR_CONSOLE default 1 diff --git a/src/mainboard/siemens/mc_apl1/variants/mc_apl5/Kconfig b/src/mainboard/siemens/mc_apl1/variants/mc_apl5/Kconfig index 877470f..00d65ce 100644 --- a/src/mainboard/siemens/mc_apl1/variants/mc_apl5/Kconfig +++ b/src/mainboard/siemens/mc_apl1/variants/mc_apl5/Kconfig @@ -14,6 +14,7 @@ select TPM_ON_FAST_SPI select DRIVERS_I2C_PTN3460 select TPM_MEASURED_BOOT + select HAS_RECOVERY_MRC_CACHE
config CBFS_SIZE default 0xb4e000 diff --git a/src/mainboard/siemens/mc_apl1/variants/mc_apl6/Kconfig b/src/mainboard/siemens/mc_apl1/variants/mc_apl6/Kconfig index 812c4af..af8d058 100644 --- a/src/mainboard/siemens/mc_apl1/variants/mc_apl6/Kconfig +++ b/src/mainboard/siemens/mc_apl1/variants/mc_apl6/Kconfig @@ -13,6 +13,7 @@ select MAINBOARD_HAS_LPC_TPM select TPM_ON_FAST_SPI select TPM_MEASURED_BOOT + select HAS_RECOVERY_MRC_CACHE
config VBOOT select VBOOT_VBNV_FLASH
