the following patch was just integrated into master: commit e32b6e71967c4a8deaa31955dc49009631d1f495 Author: Lee Leahy leroy.p.leahy@intel.com Date: Wed Dec 17 13:05:26 2014 -0800
libpayload: PCI bus scan - Eliminate endless loop
Don't attempt to scan the PCI bus if the bridge is disabled. When the PCI bridge is not setup and enabled, it is possible for the secondary bus register to contain the value zero (0). In this case the usb_scan_pci_bus routine gets into an infinite recursive loop which ends only when the heap or stack is exhausted. This patch verifies that the PCI bridge is enabled by verifying that it is enabled for either memory or I/O operations. When enabled, the secondary bus is scanned.
BRANCH=none BUG=None TEST=Build and run on Samus
Change-Id: I6826dc1d73b7c24729de5ac7c4d3534922ca73c5 Signed-off-by: Patrick Georgi pgeorgi@chromium.org Original-Commit-Id: 63d04b47934761351b54c847a2692bdef81ce54f Original-Change-Id: I855240c52fa3eba841e6754816ebbcb824abc4cd Original-Signed-off-by: Lee Leahy Leroy.P.Leahy@intel.com Original-Reviewed-on: https://chromium-review.googlesource.com/236382 Original-Commit-Queue: Leroy P Leahy leroy.p.leahy@intel.com Original-Tested-by: Leroy P Leahy leroy.p.leahy@intel.com Original-Reviewed-by: Giri P Mudusuru giri.p.mudusuru@intel.com Original-Reviewed-by: Duncan Laurie dlaurie@chromium.org Reviewed-on: http://review.coreboot.org/8734 Tested-by: build bot (Jenkins) Reviewed-by: Stefan Reinauer stefan.reinauer@coreboot.org
See http://review.coreboot.org/8734 for details.
