Andrey Petrov (andrey.petrov@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/13319
commit 0db56c521f62138e2246b557f30bdcd824bc5b04 Author: Alexandru Gagniuc alexandrux.gagniuc@intel.com Date: Tue Oct 27 10:27:30 2015 -0700
arch/x86: Add option to disable default mmap_boot implementation
On certain platforms, the boot media is either not memory-mapped, or not mapped at the stop of 4G. This makes the default mmap_boot implementation unsuitable. Add an option to allow such platforms to define their own mapping implementation.
Change-Id: I8293126fd9cc1fd3d75072f7811e659765348e4a Signed-off-by: Alexandru Gagniuc alexandrux.gagniuc@intel.com --- src/arch/x86/Kconfig | 10 ++++++++++ src/arch/x86/Makefile.inc | 8 ++++---- 2 files changed, 14 insertions(+), 4 deletions(-)
diff --git a/src/arch/x86/Kconfig b/src/arch/x86/Kconfig index 204a9be..89e142a 100644 --- a/src/arch/x86/Kconfig +++ b/src/arch/x86/Kconfig @@ -83,6 +83,16 @@ config RAMBASE hex default 0x100000
+# Traditionally BIOS region on SPI flash boot media was memory mapped right below +# 4G and it was the last region in the IFD. This way translation between CPU +# address space to flash address was trivial. However some IFDs on newer SoCs +# have BIOS region sandwiched between descriptor and other regions. Turning off +# this option enables soc code to provide custom mmap_boot.c which can be used to +# implement complex translation. +config X86_TOP4G_BOOTMEDIA_MAP + bool + default y + # This is something you almost certainly don't want to mess with. # How many SIPIs do we send when starting up APs and cores? # The answer in 2000 or so was '2'. Nowadays, on many systems, diff --git a/src/arch/x86/Makefile.inc b/src/arch/x86/Makefile.inc index 21084d3..56e2ad0 100644 --- a/src/arch/x86/Makefile.inc +++ b/src/arch/x86/Makefile.inc @@ -105,7 +105,7 @@ ifeq ($(CONFIG_ARCH_BOOTBLOCK_X86_32)$(CONFIG_ARCH_BOOTBLOCK_X86_64),y) bootblock-y += boot.c bootblock-y += memcpy.c bootblock-y += memset.c -bootblock-y += mmap_boot.c +bootblock-$(CONFIG_X86_TOP4G_BOOTMEDIA_MAP) += mmap_boot.c
bootblock-y += id.S $(call src-to-obj,bootblock,$(dir)/id.S): $(obj)/build.h @@ -354,7 +354,7 @@ romstage-$(CONFIG_ARCH_RAMSTAGE_X86_32) += cpu_common.c romstage-y += memset.c romstage-y += memcpy.c romstage-y += memmove.c -romstage-y += mmap_boot.c +romstage-$(CONFIG_X86_TOP4G_BOOTMEDIA_MAP) += mmap_boot.c
romstage-$(CONFIG_COLLECT_TIMESTAMPS) += timestamp.c
@@ -384,7 +384,7 @@ ramstage-y += memset.c ramstage-y += memcpy.c ramstage-y += memmove.c ramstage-y += ebda.c -ramstage-y += mmap_boot.c +ramstage-$(CONFIG_X86_TOP4G_BOOTMEDIA_MAP) += mmap_boot.c ramstage-$(CONFIG_COOP_MULTITASKING) += thread.c ramstage-$(CONFIG_COOP_MULTITASKING) += thread_switch.S ramstage-$(CONFIG_COLLECT_TIMESTAMPS) += timestamp.c @@ -392,7 +392,7 @@ ramstage-$(CONFIG_COLLECT_TIMESTAMPS) += timestamp.c smm-y += memset.c smm-y += memcpy.c smm-y += memmove.c -smm-y += mmap_boot.c +smm-$(CONFIG_X86_TOP4G_BOOTMEDIA_MAP) += mmap_boot.c
ifeq ($(CONFIG_ARCH_RAMSTAGE_X86_32),y) rmodules_x86_32-y += memset.c
