Angel Pons has submitted this change. ( https://review.coreboot.org/c/coreboot/+/50025 )
Change subject: mb/emulation/qemu-q35: Define and use MMCONF_BUS_NUMBER ......................................................................
Also refactor the machine type checks to avoid code duplication.
Tested, still boots to payload with 256, 128 and 64 busses.
Change-Id: Ib394ba605bbfeee75aa645e989c23034cceff348 Signed-off-by: Angel Pons th3fanbus@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/50025 Reviewed-by: Nico Huber nico.h@gmx.de Reviewed-by: Arthur Heymans arthur@aheymans.xyz Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/mainboard/emulation/qemu-q35/Kconfig M src/mainboard/emulation/qemu-q35/Makefile.inc M src/mainboard/emulation/qemu-q35/acpi_tables.c M src/mainboard/emulation/qemu-q35/bootblock.c M src/mainboard/emulation/qemu-q35/mainboard.c M src/mainboard/emulation/qemu-q35/memmap.c M src/mainboard/emulation/qemu-q35/q35.h M src/mainboard/emulation/qemu-q35/romstage.c 8 files changed, 44 insertions(+), 38 deletions(-)
Approvals: build bot (Jenkins): Verified Nico Huber: Looks good to me, approved Arthur Heymans: Looks good to me, approved
diff --git a/src/mainboard/emulation/qemu-q35/Kconfig b/src/mainboard/emulation/qemu-q35/Kconfig index 9958caf..4bbfd57 100644 --- a/src/mainboard/emulation/qemu-q35/Kconfig +++ b/src/mainboard/emulation/qemu-q35/Kconfig @@ -63,6 +63,10 @@ config MMCONF_BASE_ADDRESS default 0xb0000000
+config MMCONF_BUS_NUMBER + int + default 256 + # fw_cfg tables can be larger than the default when TPM is enabled config MAX_ACPI_TABLE_SIZE_KB int diff --git a/src/mainboard/emulation/qemu-q35/Makefile.inc b/src/mainboard/emulation/qemu-q35/Makefile.inc index 4bd91f0..99980e3 100644 --- a/src/mainboard/emulation/qemu-q35/Makefile.inc +++ b/src/mainboard/emulation/qemu-q35/Makefile.inc @@ -1,4 +1,5 @@ bootblock-y += bootblock.c +bootblock-y += memmap.c
romstage-y += ../qemu-i440fx/fw_cfg.c romstage-y += ../qemu-i440fx/memmap.c diff --git a/src/mainboard/emulation/qemu-q35/acpi_tables.c b/src/mainboard/emulation/qemu-q35/acpi_tables.c index 03d357c..90bab2f 100644 --- a/src/mainboard/emulation/qemu-q35/acpi_tables.c +++ b/src/mainboard/emulation/qemu-q35/acpi_tables.c @@ -10,7 +10,6 @@
#include "../qemu-i440fx/fw_cfg.h" #include "../qemu-i440fx/acpi.h" -#include "q35.h"
void mainboard_fill_fadt(acpi_fadt_t *fadt) { @@ -40,18 +39,8 @@
unsigned long acpi_fill_mcfg(unsigned long current) { - struct device *dev; - u32 reg; - - dev = dev_find_device(0x8086, 0x29c0, 0); - if (!dev) - return current; - - reg = pci_read_config32(dev, D0F0_PCIEXBAR_LO); - if ((reg & 0x07) != 0x01) /* require enabled + 256MB size */ - return current; - - current += acpi_create_mcfg_mmconfig((acpi_mcfg_mmconfig_t *) current, - reg & 0xf0000000, 0x0, 0x0, 255); + current += acpi_create_mcfg_mmconfig((acpi_mcfg_mmconfig_t *)current, + CONFIG_MMCONF_BASE_ADDRESS, 0, 0, + CONFIG_MMCONF_BUS_NUMBER - 1); return current; } diff --git a/src/mainboard/emulation/qemu-q35/bootblock.c b/src/mainboard/emulation/qemu-q35/bootblock.c index 7303680..cdca27a 100644 --- a/src/mainboard/emulation/qemu-q35/bootblock.c +++ b/src/mainboard/emulation/qemu-q35/bootblock.c @@ -10,8 +10,6 @@
static void bootblock_northbridge_init(void) { - uint32_t reg; - /* * The "io" variant of the config access is explicitly used to * setup the PCIEXBAR because CONFIG(MMCONF_SUPPORT) is set to @@ -24,16 +22,12 @@ * The PCIEXBAR is assumed to live in the memory mapped IO space under * 4GiB. */ - reg = 0; - pci_io_write_config32(HOST_BRIDGE, D0F0_PCIEXBAR_HI, reg); - reg = CONFIG_MMCONF_BASE_ADDRESS | 1; /* 256MiB - 0-255 buses. */ - pci_io_write_config32(HOST_BRIDGE, D0F0_PCIEXBAR_LO, reg); + const uint32_t pciexbar = make_pciexbar(); + pci_io_write_config32(HOST_BRIDGE, D0F0_PCIEXBAR_HI, 0); + pci_io_write_config32(HOST_BRIDGE, D0F0_PCIEXBAR_LO, pciexbar);
- /* MCFG is now active. If it's not qemu was started for machine PC */ - if (CONFIG(BOOTBLOCK_CONSOLE) && - (pci_read_config32(HOST_BRIDGE, D0F0_PCIEXBAR_LO) != - (CONFIG_MMCONF_BASE_ADDRESS | 1))) - die("You must run qemu for machine Q35 (-M q35)"); + if (CONFIG(BOOTBLOCK_CONSOLE)) + mainboard_machine_check(); }
static void bootblock_southbridge_init(void) diff --git a/src/mainboard/emulation/qemu-q35/mainboard.c b/src/mainboard/emulation/qemu-q35/mainboard.c index 0911671..540db04 100644 --- a/src/mainboard/emulation/qemu-q35/mainboard.c +++ b/src/mainboard/emulation/qemu-q35/mainboard.c @@ -41,9 +41,7 @@ { pci_dev_read_resources(dev);
- /* reserve mmconfig */ - fixed_mem_resource(dev, 2, CONFIG_MMCONF_BASE_ADDRESS >> 10, 0x10000000 >> 10, - IORESOURCE_RESERVE); + mmconf_resource(dev, 2);
if (CONFIG(ARCH_RAMSTAGE_X86_64)) { /* Reserve page tables in DRAM. FIXME: Remove once x86_64 page tables reside in CBMEM */ diff --git a/src/mainboard/emulation/qemu-q35/memmap.c b/src/mainboard/emulation/qemu-q35/memmap.c index 10b35d7..f3ce42c 100644 --- a/src/mainboard/emulation/qemu-q35/memmap.c +++ b/src/mainboard/emulation/qemu-q35/memmap.c @@ -2,6 +2,7 @@
#define __SIMPLE_DEVICE__
+#include <assert.h> #include <console/console.h> #include <cpu/x86/smm.h> #include <device/pci_ops.h> @@ -10,6 +11,28 @@
#include "q35.h"
+static uint32_t encode_pciexbar_length(void) +{ + switch (CONFIG_MMCONF_BUS_NUMBER) { + case 256: return 0 << 1; + case 128: return 1 << 1; + case 64: return 2 << 1; + default: return dead_code_t(uint32_t); + } +} + +uint32_t make_pciexbar(void) +{ + return CONFIG_MMCONF_BASE_ADDRESS | encode_pciexbar_length() | 1; +} + +/* Check that MCFG is active. If it's not, QEMU was started for machine PC */ +void mainboard_machine_check(void) +{ + if (pci_read_config32(HOST_BRIDGE, D0F0_PCIEXBAR_LO) != make_pciexbar()) + die("You must run qemu for machine Q35 (-M q35)"); +} + /* QEMU-specific register */ #define EXT_TSEG_MBYTES 0x50
diff --git a/src/mainboard/emulation/qemu-q35/q35.h b/src/mainboard/emulation/qemu-q35/q35.h index dcdd172..ae0fa38 100644 --- a/src/mainboard/emulation/qemu-q35/q35.h +++ b/src/mainboard/emulation/qemu-q35/q35.h @@ -4,6 +4,7 @@ #define __MAINBOARD_EMU_Q35_H__
#include <device/pci_type.h> +#include <types.h>
#define HOST_BRIDGE PCI_DEV(0, 0, 0)
@@ -23,4 +24,8 @@ #define TSEG_SZ_MASK (3 << 1) #define H_SMRAME (1 << 7)
+uint32_t make_pciexbar(void); + +void mainboard_machine_check(void); + #endif diff --git a/src/mainboard/emulation/qemu-q35/romstage.c b/src/mainboard/emulation/qemu-q35/romstage.c index e9637e8..c9bc339 100644 --- a/src/mainboard/emulation/qemu-q35/romstage.c +++ b/src/mainboard/emulation/qemu-q35/romstage.c @@ -8,20 +8,12 @@
#include "q35.h"
-static void mainboard_machine_check(void) -{ - /* Check that MCFG is active. If it's not qemu was started for machine PC */ - if (!CONFIG(BOOTBLOCK_CONSOLE) && - (pci_read_config32(HOST_BRIDGE, D0F0_PCIEXBAR_LO) != - (CONFIG_MMCONF_BASE_ADDRESS | 1))) - die("You must run qemu for machine Q35 (-M q35)"); -} - void mainboard_romstage_entry(void) { i82801ix_early_init();
- mainboard_machine_check(); + if (!CONFIG(BOOTBLOCK_CONSOLE)) + mainboard_machine_check();
cbmem_recovery(0); }
