Rizwan Qureshi (rizwan.qureshi@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/16610
commit f363eabb96181e840033fd20db4af62afed23d24 Author: Naresh G Solanki naresh.solanki@intel.com Date: Thu Sep 15 18:14:28 2016 +0530
driver/intel/fsp1_1: Utilise soc/intel/common for adding vbt.bin
Remove fsp1.1 driver code that adds vbt.bin & use soc/intel/common instead to add vbt.bin in cbfs. Also, VBT blob is added to CBFS as RAW type hence when walking the CBFS to find vbt.bin, search with type as RAW.
Change-Id: I08f2556a34f83a0ea2b67b003e51dcace994361b Signed-off-by: Naresh G Solanki naresh.solanki@intel.com Signed-off-by: Rizwan Qureshi rizwan.qureshi@intel.com --- src/drivers/intel/fsp1_1/Kconfig | 6 +----- src/drivers/intel/fsp1_1/Makefile.inc | 7 ------- src/drivers/intel/fsp1_1/fsp_gop.c | 3 +-- 3 files changed, 2 insertions(+), 14 deletions(-)
diff --git a/src/drivers/intel/fsp1_1/Kconfig b/src/drivers/intel/fsp1_1/Kconfig index 59b4797..17a5caf 100644 --- a/src/drivers/intel/fsp1_1/Kconfig +++ b/src/drivers/intel/fsp1_1/Kconfig @@ -98,6 +98,7 @@ config FSP_USES_UPD config GOP_SUPPORT bool "Enable GOP support" default n + select ADD_VBT_DATA_FILE
config USE_GENERIC_FSP_CAR_INC bool @@ -106,11 +107,6 @@ config USE_GENERIC_FSP_CAR_INC The chipset can select this to use a generic cache_as_ram.inc file that should be good for all FSP based platforms.
-config VBT_FILE - string "GOP Video BIOS table binary path" - depends on GOP_SUPPORT - default "3rdparty/blobs/mainboard/$(MAINBOARDDIR)/vbt.bin" - config CHECKLIST_DATA_FILE_LOCATION string default "src/vendorcode/intel/fsp/fsp1_1/checklist" diff --git a/src/drivers/intel/fsp1_1/Makefile.inc b/src/drivers/intel/fsp1_1/Makefile.inc index 3820a5d..4ea23f3 100644 --- a/src/drivers/intel/fsp1_1/Makefile.inc +++ b/src/drivers/intel/fsp1_1/Makefile.inc @@ -44,13 +44,6 @@ CPPFLAGS_common += -Isrc/drivers/intel/fsp1_1/include
cpu_incs-$(CONFIG_USE_GENERIC_FSP_CAR_INC) += $(src)/drivers/intel/fsp1_1/cache_as_ram.inc
- -# Add the GOP Video BIOS Table to the cbfs image -cbfs-files-$(CONFIG_GOP_SUPPORT) += vbt.bin -vbt.bin-file := $(call strip_quotes,$(CONFIG_VBT_FILE)) -vbt.bin-type := optionrom - - # Add the FSP binary to the cbfs image ifeq ($(CONFIG_HAVE_FSP_BIN),y) cbfs-files-y += fsp.bin diff --git a/src/drivers/intel/fsp1_1/fsp_gop.c b/src/drivers/intel/fsp1_1/fsp_gop.c index f531d76..6d905b2 100644 --- a/src/drivers/intel/fsp1_1/fsp_gop.c +++ b/src/drivers/intel/fsp1_1/fsp_gop.c @@ -29,8 +29,7 @@ const optionrom_vbt_t *fsp_get_vbt(uint32_t *vbt_len) } vbt;
/* Locate the vbt file in cbfs */ - vbt.data = cbfs_boot_map_with_leak("vbt.bin", CBFS_TYPE_OPTIONROM, - &vbt_size); + vbt.data = cbfs_boot_map_with_leak("vbt.bin", CBFS_TYPE_RAW, &vbt_size); if (!vbt.data) { printk(BIOS_INFO, "FSP_INFO: VBT data file (vbt.bin) not found in CBFS");
