Joel Kitching has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/31441
Change subject: update vboot submodule to upstream master ......................................................................
* 3rdparty/vboot a32c930e...1e177741 (11):
vboot: rename VB2_DISABLE_DEVELOPER_MODE vboot: rename VB2_SD_DEV_MODE_ENABLED futility: updater: Improve error message when key conflicts vboot_reference: add const to char* params in cgpt crossystem: support recoverysw_cur with new gpiod API cgpt: add -D support to CgptEdit futility: updater: Correct HWID digest when preserving HWID image_signing: Add cr50 firmware signing support. Add cgpt_find to libvboothost tests: add valid key.versions files for all test keysets futility: updater: Add '--fast' for quick development
Change-Id: I18ca1e30eadc571a240835317e39823bf8d3fc9d Signed-off-by: Joel Kitching kitching@google.com --- M 3rdparty/vboot 1 file changed, 1 insertion(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/41/31441/1
diff --git a/3rdparty/vboot b/3rdparty/vboot index a32c930..1e17774 160000 --- a/3rdparty/vboot +++ b/3rdparty/vboot @@ -1 +1 @@ -Subproject commit a32c930e8c46424a3bba3c296fd78b3e60f50aeb +Subproject commit 1e177741c3a9bfb8bd69a92b6d3bf4b25655a71f
Joel Kitching has abandoned this change. ( https://review.coreboot.org/c/coreboot/+/31441 )
Abandoned
Should create via util/scripts/update_submodules instead
