Vladimir Serbinenko (phcoder@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/5271
commit d24c8b756adcec34eaffba6456de4513aa89b0d7 Author: Vladimir Serbinenko phcoder@gmail.com Date: Wed Feb 19 22:20:14 2014 +0100
New port Packard Bell LM85.
Change-Id: I8c1548470c605d06825fe35579879e806bf33542 Signed-off-by: Vladimir Serbinenko phcoder@gmail.com --- src/mainboard/Kconfig | 3 + src/mainboard/packardbell/Kconfig | 19 ++ src/mainboard/packardbell/ms2290/Kconfig | 59 ++++ src/mainboard/packardbell/ms2290/Makefile.inc | 21 ++ src/mainboard/packardbell/ms2290/acpi/ac.asl | 50 ++++ src/mainboard/packardbell/ms2290/acpi/battery.asl | 155 ++++++++++ src/mainboard/packardbell/ms2290/acpi/ec.asl | 136 +++++++++ src/mainboard/packardbell/ms2290/acpi/gpe.asl | 25 ++ .../packardbell/ms2290/acpi/mainboard.asl | 0 .../packardbell/ms2290/acpi/nehalem_pci_irqs.asl | 86 ++++++ src/mainboard/packardbell/ms2290/acpi/platform.asl | 147 +++++++++ src/mainboard/packardbell/ms2290/acpi/superio.asl | 1 + src/mainboard/packardbell/ms2290/acpi/thermal.asl | 48 +++ src/mainboard/packardbell/ms2290/acpi/video.asl | 115 +++++++ src/mainboard/packardbell/ms2290/acpi_tables.c | 283 +++++++++++++++++ src/mainboard/packardbell/ms2290/board_info.txt | 6 + src/mainboard/packardbell/ms2290/cmos.default | 7 + src/mainboard/packardbell/ms2290/cmos.layout | 131 ++++++++ src/mainboard/packardbell/ms2290/devicetree.cb | 104 +++++++ src/mainboard/packardbell/ms2290/dsdt.asl | 91 ++++++ src/mainboard/packardbell/ms2290/fadt.c | 160 ++++++++++ src/mainboard/packardbell/ms2290/gma.c | 272 +++++++++++++++++ src/mainboard/packardbell/ms2290/hda_verb.h | 90 ++++++ src/mainboard/packardbell/ms2290/mainboard.c | 178 +++++++++++ src/mainboard/packardbell/ms2290/romstage.c | 333 +++++++++++++++++++++ src/mainboard/packardbell/ms2290/smi.h | 0 src/mainboard/packardbell/ms2290/smihandler.c | 113 +++++++ 27 files changed, 2633 insertions(+)
diff --git a/src/mainboard/Kconfig b/src/mainboard/Kconfig index d823b22..0e6f96b 100644 --- a/src/mainboard/Kconfig +++ b/src/mainboard/Kconfig @@ -106,6 +106,8 @@ config VENDOR_NOKIA bool "Nokia" config VENDOR_NVIDIA bool "NVIDIA" +config VENDOR_PACKARDBELL + bool "Packard Bell" config VENDOR_PCENGINES bool "PC Engines" config VENDOR_RCA @@ -196,6 +198,7 @@ source "src/mainboard/nec/Kconfig" source "src/mainboard/newisys/Kconfig" source "src/mainboard/nokia/Kconfig" source "src/mainboard/nvidia/Kconfig" +source "src/mainboard/packardbell/Kconfig" source "src/mainboard/pcengines/Kconfig" source "src/mainboard/rca/Kconfig" source "src/mainboard/roda/Kconfig" diff --git a/src/mainboard/packardbell/Kconfig b/src/mainboard/packardbell/Kconfig new file mode 100644 index 0000000..d0712ae --- /dev/null +++ b/src/mainboard/packardbell/Kconfig @@ -0,0 +1,19 @@ +if VENDOR_PACKARDBELL + +choice + prompt "Mainboard model" + +config BOARD_PACKARDBELL_MS2290 + bool "EasyNote LM85 (MS2290)" + help + EasyNote LM85 laptop + +endchoice + +source "src/mainboard/packardbell/ms2290/Kconfig" + +config MAINBOARD_VENDOR + string + default "Packard Bell" + +endif # VENDOR_PACKARDBELL diff --git a/src/mainboard/packardbell/ms2290/Kconfig b/src/mainboard/packardbell/ms2290/Kconfig new file mode 100644 index 0000000..114c1a8 --- /dev/null +++ b/src/mainboard/packardbell/ms2290/Kconfig @@ -0,0 +1,59 @@ +if BOARD_PACKARDBELL_MS2290 + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + select ARCH_X86 + select NORTHBRIDGE_INTEL_NEHALEM + select SOUTHBRIDGE_INTEL_IBEXPEAK + select HAVE_OPTION_TABLE + select HAVE_CMOS_DEFAULT + select GFXUMA + select BOARD_ROMSIZE_KB_4096 + select HAVE_ACPI_TABLES + select HAVE_ACPI_RESUME + select EARLY_CBMEM_INIT + select MAINBOARD_HAS_NATIVE_VGA_INIT + select EC_ACPI + select MAINBOARD_HAS_NATIVE_VGA_INIT_TEXTMODECFG + +config MAINBOARD_DIR + string + default packardbell/ms2290 + +config MAINBOARD_PART_NUMBER + string + default "EasyNote LM85" + +config MAINBOARD_VERSION + string + default "V1.20" + +config MAINBOARD_VENDOR + string + default "Packard Bell" + +config MMCONF_BASE_ADDRESS + hex + default 0xe0000000 + +config IRQ_SLOT_COUNT + int + default 18 + +config USBDEBUG_HCD_INDEX + int + default 2 + +config DRAM_RESET_GATE_GPIO + int + default 60 + +config MAX_CPUS + int + default 4 + +config CPU_ADDR_BITS + int + default 36 + +endif diff --git a/src/mainboard/packardbell/ms2290/Makefile.inc b/src/mainboard/packardbell/ms2290/Makefile.inc new file mode 100644 index 0000000..a9db8d8 --- /dev/null +++ b/src/mainboard/packardbell/ms2290/Makefile.inc @@ -0,0 +1,21 @@ +## +## This file is part of the coreboot project. +## +## Copyright (C) 2007-2008 coresystems GmbH +## +## This program is free software; you can redistribute it and/or modify +## it under the terms of the GNU General Public License as published by +## the Free Software Foundation; version 2 of the License. +## +## This program is distributed in the hope that it will be useful, +## but WITHOUT ANY WARRANTY; without even the implied warranty of +## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +## GNU General Public License for more details. +## +## You should have received a copy of the GNU General Public License +## along with this program; if not, write to the Free Software +## Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA +## + +smm-$(CONFIG_HAVE_SMI_HANDLER) += smihandler.c +ramstage-y += gma.c diff --git a/src/mainboard/packardbell/ms2290/acpi/ac.asl b/src/mainboard/packardbell/ms2290/acpi/ac.asl new file mode 100644 index 0000000..2ef1598 --- /dev/null +++ b/src/mainboard/packardbell/ms2290/acpi/ac.asl @@ -0,0 +1,50 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (c) 2011 Sven Schnelle svens@stackframe.org + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of + * the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +Device(AC) +{ + Name(_HID, "ACPI0003") + Name(_UID, 0x00) + Name(_PCL, Package() { _SB } ) + + Method(_PSR, 0, NotSerialized) + { + return (HPAC) + } + + Method(_STA, 0, NotSerialized) + { + Return (0x0f) + } +} + +/* AC status change */ +Method(_Q50, 0, NotSerialized) +{ + Notify (AC, 0x80) +} + +/* AC status change */ +Method(_Q51, 0, NotSerialized) +{ + Notify (AC, 0x80) +} + diff --git a/src/mainboard/packardbell/ms2290/acpi/battery.asl b/src/mainboard/packardbell/ms2290/acpi/battery.asl new file mode 100644 index 0000000..1ca2cf1 --- /dev/null +++ b/src/mainboard/packardbell/ms2290/acpi/battery.asl @@ -0,0 +1,155 @@ +/* Arg0: Battery + * Arg1: Battery Status Package + * Arg2: charging + * Arg3: discharging + */ +Method(BSTA, 4, NotSerialized) +{ + Acquire(ECLK, 0xffff) + Store(0, Local0) + + Store(0, PAGE) + + Store(BAPR, Local2) + + if (Arg2) // charging + { + Or(2, Local0, Local0) + + If (LGreaterEqual (Local2, 0x8000)) { + Store(0, Local2) + } + } + + if (Arg3) // discharging + { + Or(1, Local0, Local0) + Subtract(0x10000, Local2, Local2) + } + + Store(Local0, Index(Arg1, 0x00)) + + Store(0, PAGE) + Store(BARC, Index(Arg1, 2)) + Store(Local2, Index(Arg1, 1)) + + Store(0, PAGE) + Store(BAVO, Index(Arg1, 3)) + Release(ECLK) + Return (Arg1) +} + +Method(BINF, 2, NotSerialized) +{ + Acquire(ECLK, 0xffff) + Store(0, PAGE) + Store(BAFC, Local2) + Store(1, PAGE) + Store(BADC, Local1) + + Store(Local1, Index(Arg0, 1)) // Design Capacity + Store(Local2, Index(Arg0, 2)) // Last full charge capacity + Store(1, PAGE) + Store(BADV, Index(Arg0, 4)) // Design Voltage + Divide (Local2, 20, Local0, Index(Arg0, 5)) // Warning capacity + + Store(1, PAGE) + Store (BASN, Local0) + Name (SERN, Buffer (0x06) { " " }) + Store (4, Local1) + While (Local0) + { + Divide (Local0, 0x0A, Local2, Local0) + Add (Local2, 48, Index (SERN, Local1)) + Decrement (Local1) + } + Store (SERN, Index (Arg0, 10)) // Serial Number + + Name (TYPE, Buffer() { 0, 0, 0, 0, 0 }) + Store(4, PAGE) + Store(BATY, TYPE) + Store(TYPE, Index (Arg0, 11)) // Battery type + Store(5, PAGE) + Store(BAOE, Index (Arg0, 12)) // OEM information + Store(2, PAGE) + Store(BANA, Index (Arg0, 9)) // Model number + Release(ECLK) + Return (Arg0) +} + +Device (BAT0) +{ + Name (_HID, EisaId ("PNP0C0A")) + Name (_UID, 0x00) + Name (_PCL, Package () { _SB }) + + Name (BATS, Package () + { + 0x00, // 0: PowerUnit: Report in mWh + 0xFFFFFFFF, // 1: Design cap + 0xFFFFFFFF, // 2: Last full charge cap + 0x01, // 3: Battery Technology + 10800, // 4: Design Voltage (mV) + 0x00, // 5: Warning design capacity + 200, // 6: Low design capacity + 1, // 7: granularity1 + 1, // 8: granularity2 + "", // 9: Model number + "", // A: Serial number + "", // B: Battery Type + "" // C: OEM information + }) + + Method (_BIF, 0, NotSerialized) + { + Return (BINF(BATS, 0)) + } + + Name (BATI, Package () + { + 0, // Battery State + // Bit 0 - discharge + // Bit 1 - charge + // Bit 2 - critical state + 0, // Battery present Rate + 0, // Battery remaining capacity + 0 // Battery present voltage + }) + + Method (_BST, 0, NotSerialized) + { + if (B0PR) { + Return (BSTA(0, BATI, B0CH, B0DI)) + } else { + Return (BATS) + } + } + + Method (_STA, 0, NotSerialized) + { + if (B0PR) { + Return (0x1f) + } else { + Return (0x0f) + } + } +} + +/* Battery attach/detach */ +Method(_Q40, 0, NotSerialized) +{ + Notify(BAT0, 0x81) +} +Method(_Q41, 0, NotSerialized) +{ + Notify(BAT0, 0x81) +} + +Method(_Q48, 0, NotSerialized) +{ + Notify(BAT0, 0x80) +} +Method(_Q4C, 0, NotSerialized) +{ + Notify(BAT0, 0x80) +} diff --git a/src/mainboard/packardbell/ms2290/acpi/ec.asl b/src/mainboard/packardbell/ms2290/acpi/ec.asl new file mode 100644 index 0000000..3735f20 --- /dev/null +++ b/src/mainboard/packardbell/ms2290/acpi/ec.asl @@ -0,0 +1,136 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (c) 2011 Sven Schnelle svens@stackframe.org + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of + * the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +Device(EC) +{ + Name (_HID, EISAID("PNP0C09")) + Name (_UID, 0) + + Name (_GPE, 0x17) + Mutex (ECLK, 0) + + OperationRegion(ERAM, EmbeddedControl, 0x00, 0x100) + Field (ERAM, ByteAcc, NoLock, Preserve) + { + Offset (0x8), + PAGE, 8, /* Information Page Selector */ + Offset (0x70), + , 1, + LIDS, 1, + , 3, + HPAC, 1, + Offset (0x88), + B0PR, 1, /* Battery 0 present */ + B0CH, 1, /* Battery 0 charging */ + B0DI, 1, /* Battery 0 discharging */ + Offset (0xA8), + TMP0, 8, + TMP1, 8, + } + + Device(LID) + { + Name(_HID, "PNP0C0D") + Method(_LID, 0, NotSerialized) + { + return (LIDS) + } + } + + Method(_Q52, 0, NotSerialized) + { + Notify(LID, 0x80) + } + + Method(_Q53, 0, NotSerialized) + { + Notify(^LID, 0x80) + } + + /* PAGE = 0 */ + Field (ERAM, ByteAcc, NoLock, Preserve) + { + Offset (0xe0), + BARC, 16, /* Battery remaining capacity */ + BAFC, 16, /* Battery full charge capacity */ + , 16, + BAPR, 16, /* Battery present rate */ + BAVO, 16, /* Battery Voltage */ + } + + /* PAGE = 1 */ + Field (ERAM, ByteAcc, NoLock, Preserve) + { + Offset (0xe0), + BADC, 16, /* Design Capacity */ + BADV, 16, /* Design voltage */ + BASN, 16 + } + + /* PAGE = 2 */ + Field (ERAM, ByteAcc, NoLock, Preserve) + { + Offset (0xe0), + BANA, 128, /* Battery name */ + } + + /* PAGE = 4 */ + Field (ERAM, ByteAcc, NoLock, Preserve) + { + Offset (0xe0), + BATY, 128, /* Battery type */ + } + + /* PAGE = 5 */ + Field (ERAM, ByteAcc, NoLock, Preserve) + { + Offset (0xe0), + BAOE, 128, /* Battery OEM info */ + } + + Method (_CRS, 0) + { + Name (ECMD, ResourceTemplate() + { + IO (Decode16, 0x62, 0x62, 1, 1) + IO (Decode16, 0x66, 0x66, 1, 1) + }) + Return (ECMD) + } + Method (_INI, 0, NotSerialized) + { + } + + /* Decrease brightness. */ + Method(_Q1D, 0, NotSerialized) + { + _SB.PCI0.GFX0.LCD0.DECB() + } + /* Increase brightness. */ + Method(_Q1C, 0, NotSerialized) + { + _SB.PCI0.GFX0.LCD0.INCB() + } + +#include "battery.asl" +#include "ac.asl" +#include "thermal.asl" +} diff --git a/src/mainboard/packardbell/ms2290/acpi/gpe.asl b/src/mainboard/packardbell/ms2290/acpi/gpe.asl new file mode 100644 index 0000000..30fb365 --- /dev/null +++ b/src/mainboard/packardbell/ms2290/acpi/gpe.asl @@ -0,0 +1,25 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (c) 2011 Sven Schnelle svens@stackframe.org + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of + * the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include "smi.h" +Scope (_GPE) +{ +} diff --git a/src/mainboard/packardbell/ms2290/acpi/mainboard.asl b/src/mainboard/packardbell/ms2290/acpi/mainboard.asl new file mode 100644 index 0000000..e69de29 diff --git a/src/mainboard/packardbell/ms2290/acpi/nehalem_pci_irqs.asl b/src/mainboard/packardbell/ms2290/acpi/nehalem_pci_irqs.asl new file mode 100644 index 0000000..1f782c8 --- /dev/null +++ b/src/mainboard/packardbell/ms2290/acpi/nehalem_pci_irqs.asl @@ -0,0 +1,86 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2013 Vladimir Serbinenko + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of + * the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +/* This is board specific information: IRQ routing. + */ + + +// PCI Interrupt Routing +Method(_PRT) +{ + If (PICM) { + Return (Package() { + Package() { 0x0001ffff, 0, 0, 0x10 }, + Package() { 0x0002ffff, 0, 0, 0x10 }, // VGA + Package() { 0x0003ffff, 0, 0, 0x10 }, + Package() { 0x0016ffff, 0, 0, 0x10 }, // ME + Package() { 0x0016ffff, 1, 0, 0x11 }, // ME + Package() { 0x0016ffff, 2, 0, 0x12 }, // ME + Package() { 0x0016ffff, 3, 0, 0x13 }, // ME + Package() { 0x0019ffff, 0, 0, 0x14 }, // Ethernet + Package() { 0x001affff, 0, 0, 0x14 }, // USB + Package() { 0x001affff, 1, 0, 0x15 }, // USB + Package() { 0x001affff, 2, 0, 0x16 }, // USB + Package() { 0x001affff, 3, 0, 0x17 }, // USB + Package() { 0x001bffff, 1, 0, 0x11 }, // Audio + Package() { 0x001cffff, 0, 0, 0x10 }, // PCI bridge + Package() { 0x001cffff, 1, 0, 0x11 }, // PCI bridge + Package() { 0x001cffff, 2, 0, 0x12 }, // PCI bridge + Package() { 0x001cffff, 3, 0, 0x13 }, // PCI bridge + Package() { 0x001dffff, 0, 0, 0x10 }, // USB + Package() { 0x001dffff, 1, 0, 0x11 }, // USB + Package() { 0x001dffff, 2, 0, 0x12 }, // USB + Package() { 0x001dffff, 3, 0, 0x13 }, // USB + Package() { 0x001fffff, 0, 0, 0x17 }, // LPC + Package() { 0x001fffff, 1, 0, 0x10 }, // IDE + Package() { 0x001fffff, 2, 0, 0x11 }, // SATA + Package() { 0x001fffff, 3, 0, 0x13 } // SMBUS + }) + } Else { + Return (Package() { + Package() { 0x0001ffff, 0, _SB.PCI0.LPCB.LNKA, 0 }, + Package() { 0x0002ffff, 0, _SB.PCI0.LPCB.LNKA, 0 }, // VGA + Package() { 0x0003ffff, 0, _SB.PCI0.LPCB.LNKA, 0 }, + Package() { 0x0016ffff, 0, _SB.PCI0.LPCB.LNKA, 0 }, // ME + Package() { 0x0016ffff, 1, _SB.PCI0.LPCB.LNKB, 0 }, // ME + Package() { 0x0016ffff, 2, _SB.PCI0.LPCB.LNKC, 0 }, // ME + Package() { 0x0016ffff, 3, _SB.PCI0.LPCB.LNKD, 0 }, // ME + Package() { 0x0019ffff, 0, _SB.PCI0.LPCB.LNKE, 0 }, // Ethernet + Package() { 0x001affff, 0, _SB.PCI0.LPCB.LNKE, 0 }, // USB + Package() { 0x001affff, 1, _SB.PCI0.LPCB.LNKF, 0 }, // USB + Package() { 0x001affff, 2, _SB.PCI0.LPCB.LNKG, 0 }, // USB + Package() { 0x001affff, 3, _SB.PCI0.LPCB.LNKH, 0 }, // USB + Package() { 0x001bffff, 1, _SB.PCI0.LPCB.LNKB, 0 }, // Audio + Package() { 0x001cffff, 0, _SB.PCI0.LPCB.LNKA, 0 }, // PCI + Package() { 0x001cffff, 1, _SB.PCI0.LPCB.LNKB, 0 }, // PCI + Package() { 0x001cffff, 2, _SB.PCI0.LPCB.LNKC, 0 }, // PCI + Package() { 0x001cffff, 3, _SB.PCI0.LPCB.LNKD, 0 }, // PCI + Package() { 0x001dffff, 0, _SB.PCI0.LPCB.LNKA, 0 }, // USB + Package() { 0x001dffff, 1, _SB.PCI0.LPCB.LNKB, 0 }, // USB + Package() { 0x001dffff, 2, _SB.PCI0.LPCB.LNKC, 0 }, // USB + Package() { 0x001dffff, 3, _SB.PCI0.LPCB.LNKD, 0 }, // USB + Package() { 0x001fffff, 0, _SB.PCI0.LPCB.LNKH, 0 }, // LPC + Package() { 0x001fffff, 1, _SB.PCI0.LPCB.LNKA, 0 }, // IDE + Package() { 0x001fffff, 2, _SB.PCI0.LPCB.LNKB, 0 }, // SATA + Package() { 0x001fffff, 3, _SB.PCI0.LPCB.LNKD, 0 } // SMBus + }) + } +} diff --git a/src/mainboard/packardbell/ms2290/acpi/platform.asl b/src/mainboard/packardbell/ms2290/acpi/platform.asl new file mode 100644 index 0000000..3ca9dc5 --- /dev/null +++ b/src/mainboard/packardbell/ms2290/acpi/platform.asl @@ -0,0 +1,147 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007-2009 coresystems GmbH + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of + * the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +/* These come from the dynamically created CPU SSDT */ +External(PDC0) +External(PDC1) + +/* The APM port can be used for generating software SMIs */ + +OperationRegion (APMP, SystemIO, 0xb2, 2) +Field (APMP, ByteAcc, NoLock, Preserve) +{ + APMC, 8, /* APM command */ + APMS, 8 /* APM status */ +} + +/* SMI I/O Trap */ +Method(TRAP, 1, Serialized) +{ + Store (Arg0, SMIF) /* SMI Function */ + Store (0, TRP0) /* Generate trap */ + Return (SMIF) /* Return value of SMI handler */ +} + +/* The _PIC method is called by the OS to choose between interrupt + * routing via the i8259 interrupt controller or the APIC. + * + * _PIC is called with a parameter of 0 for i8259 configuration and + * with a parameter of 1 for Local Apic/IOAPIC configuration. + */ + +Method(_PIC, 1) +{ + /* Remember the OS' IRQ routing choice. */ + Store(Arg0, PICM) +} + +/* The _PTS method (Prepare To Sleep) is called before the OS is + * entering a sleep state. The sleep state number is passed in Arg0 + */ + +Method(_PTS,1) +{ +} + +/* The _WAK method is called on system wakeup */ + +Method(_WAK,1) +{ + /* Not implemented. */ + Return(Package(){0,0}) +} + +/* System Bus */ + +Scope(_SB) +{ + /* This method is placed on the top level, so we can make sure it's the + * first executed _INI method. + */ + Method(_INI, 0) + { + /* The DTS data in NVS is probably not up to date. + * Update temperature values and make sure AP thermal + * interrupts can happen + */ + + /* TRAP(71) */ /* TODO */ + + /* Determine the Operating System and save the value in OSYS. + * We have to do this in order to be able to work around + * certain windows bugs. + * + * OSYS value | Operating System + * -----------+------------------ + * 2000 | Windows 2000 + * 2001 | Windows XP(+SP1) + * 2002 | Windows XP SP2 + * 2006 | Windows Vista + * ???? | Windows 7 + */ + + /* Let's assume we're running at least Windows 2000 */ + Store (2000, OSYS) + + If (CondRefOf(_OSI, Local0)) { + If (_OSI("Windows 2001")) { + Store (2001, OSYS) + } + + If (_OSI("Windows 2001 SP1")) { + Store (2001, OSYS) + } + + If (_OSI("Windows 2001 SP2")) { + Store (2002, OSYS) + } + + If (_OSI("Windows 2001.1")) { + Store (2001, OSYS) + } + + If (_OSI("Windows 2001.1 SP1")) { + Store (2001, OSYS) + } + + If (_OSI("Windows 2006")) { + Store (2006, OSYS) + } + + If (_OSI("Windows 2006.1")) { + Store (2006, OSYS) + } + + If (_OSI("Windows 2006 SP1")) { + Store (2006, OSYS) + } + + If (_OSI("Windows 2009")) { + Store (2009, OSYS) + } + + If (_OSI("Windows 2012")) { + Store (2012, OSYS) + } + } + } +} + diff --git a/src/mainboard/packardbell/ms2290/acpi/superio.asl b/src/mainboard/packardbell/ms2290/acpi/superio.asl new file mode 100644 index 0000000..a2657f1 --- /dev/null +++ b/src/mainboard/packardbell/ms2290/acpi/superio.asl @@ -0,0 +1 @@ +#include "../../../../drivers/pc80/ps2_controller.asl" diff --git a/src/mainboard/packardbell/ms2290/acpi/thermal.asl b/src/mainboard/packardbell/ms2290/acpi/thermal.asl new file mode 100644 index 0000000..735171b --- /dev/null +++ b/src/mainboard/packardbell/ms2290/acpi/thermal.asl @@ -0,0 +1,48 @@ +Scope(_TZ) +{ + Name (MEBT, 0) + + Method(C2K, 1, NotSerialized) + { + Multiply(Arg0, 10, Local0) + Add (Local0, 2732, Local0) + if (LLessEqual(Local0, 2732)) { + Return (3000) + } + + if (LGreater(Local0, 4012)) { + Return (3000) + } + Return (Local0) + } + + ThermalZone(THM0) + { + Method(_CRT, 0, NotSerialized) { + Return (C2K(127)) + } + Method(_TMP) { + /* Avoid tripping alarm if ME isn't booted at all yet */ + If (LAnd (LNot (MEBT), LEqual (_SB.PCI0.LPCB.EC.TMP0, 128))) { + Return (C2K(40)) + } + Store (1, MEBT) + Return (C2K(_SB.PCI0.LPCB.EC.TMP0)) + } + } + + ThermalZone(THM1) + { + Method(_CRT, 0, NotSerialized) { + Return (C2K(99)) + } + + Method(_PSV, 0, NotSerialized) { + Return (C2K(94)) + } + + Method(_TMP) { + Return (C2K(_SB.PCI0.LPCB.EC.TMP1)) + } + } +} diff --git a/src/mainboard/packardbell/ms2290/acpi/video.asl b/src/mainboard/packardbell/ms2290/acpi/video.asl new file mode 100644 index 0000000..12a268b --- /dev/null +++ b/src/mainboard/packardbell/ms2290/acpi/video.asl @@ -0,0 +1,115 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (c) 2011 Sven Schnelle svens@stackframe.org + * Copyright (c) 2013 Vladimir Serbinenko + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of + * the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include "smi.h" + +Scope (_SB.PCI0.GFX0) +{ + Device (LCD0) + { + Name (_ADR, 0x0400) + Name (BRCT, 0) + + Name (BRIG, Package (0x12) + { + 0x61, + 0x61, + 0x2, + 0x4, + 0x5, + 0x7, + 0x9, + 0xb, + 0xd, + 0x11, + 0x14, + 0x17, + 0x1c, + 0x20, + 0x27, + 0x31, + 0x41, + 0x61, + }) + + Method (_BCL, 0, NotSerialized) + { + Store (1, BRCT) + Return (BRIG) + } + + Method (_BCM, 1, NotSerialized) + { + Store (ShiftLeft (Arg0, 4), ^^BCLV) + Store (0x80000000, ^^CR1) + Store (0x061a061a, ^^CR2) + } + Method (_BQC, 0, NotSerialized) + { + Store (^^BCLV, Local0) + ShiftRight (Local0, 4, Local0) + Return (Local0) + } + + Method(BRID, 1, NotSerialized) + { + Store (Match (BRIG, MEQ, Arg0, MTR, Zero, 2), Local0) + If (LEqual (Local0, Ones)) + { + Return (0x11) + } + Return (Local0) + } + + /* Using Notify is the right way. But Windows doesn't handle + it well. So use both method in a way to avoid double action. + */ + Method (DECB, 0, NotSerialized) + { + If (BRCT) + { + Notify (LCD0, 0x87) + } Else { + Store (BRID (_BQC ()), Local0) + If (LNotEqual (Local0, 2)) + { + Decrement (Local0) + } + _BCM (DerefOf (Index (BRIG, Local0))) + } + } + Method (INCB, 0, NotSerialized) + { + If (BRCT) + { + Notify (LCD0, 0x86) + } Else { + Store (BRID (_BQC ()), Local0) + If (LNotEqual (Local0, 0x11)) + { + Increment (Local0) + } + _BCM (DerefOf (Index (BRIG, Local0))) + } + } + } +} diff --git a/src/mainboard/packardbell/ms2290/acpi_tables.c b/src/mainboard/packardbell/ms2290/acpi_tables.c new file mode 100644 index 0000000..165de0d --- /dev/null +++ b/src/mainboard/packardbell/ms2290/acpi_tables.c @@ -0,0 +1,283 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007-2009 coresystems GmbH + * Copyright (C) 2013 Vladimir Serbinenko phcoder@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of + * the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <string.h> +#include <console/console.h> +#include <arch/io.h> +#include <arch/ioapic.h> +#include <arch/acpi.h> +#include <arch/acpigen.h> +#include <arch/smp/mpspec.h> +#include <device/device.h> +#include <device/pci.h> +#include <device/pci_ids.h> +#include "southbridge/intel/ibexpeak/nvs.h" + +extern const unsigned char AmlCode[]; +#if CONFIG_HAVE_ACPI_SLIC +unsigned long acpi_create_slic(unsigned long current); +#endif + +static void acpi_create_gnvs(global_nvs_t * gnvs) +{ + memset((void *)gnvs, 0, sizeof(*gnvs)); + gnvs->apic = 1; + gnvs->mpen = 1; /* Enable Multi Processing */ + gnvs->pcnt = dev_count_cpu(); + + /* IGD Displays */ + gnvs->ndid = 3; + gnvs->did[0] = 0x80000100; + gnvs->did[1] = 0x80000240; + gnvs->did[2] = 0x80000410; + gnvs->did[3] = 0x80000410; + gnvs->did[4] = 0x00000005; +} + +unsigned long acpi_fill_madt(unsigned long current) +{ + /* Local APICs */ + current = acpi_create_madt_lapics(current); + + /* IOAPIC */ + current += acpi_create_madt_ioapic((acpi_madt_ioapic_t *) current, + 1, IO_APIC_ADDR, 0); + + /* INT_SRC_OVR */ + current += acpi_create_madt_irqoverride((acpi_madt_irqoverride_t *) + current, 0, 0, 2, + MP_IRQ_POLARITY_DEFAULT | + MP_IRQ_TRIGGER_DEFAULT); + current += acpi_create_madt_irqoverride((acpi_madt_irqoverride_t *) + current, 0, 9, 9, + MP_IRQ_POLARITY_HIGH | + MP_IRQ_TRIGGER_LEVEL); + + /* LAPIC_NMI */ + current += acpi_create_madt_lapic_nmi((acpi_madt_lapic_nmi_t *) + current, 0, + MP_IRQ_POLARITY_HIGH | + MP_IRQ_TRIGGER_EDGE, 0x01); + current += acpi_create_madt_lapic_nmi((acpi_madt_lapic_nmi_t *) + current, 1, MP_IRQ_POLARITY_HIGH | + MP_IRQ_TRIGGER_EDGE, 0x01); + current += acpi_create_madt_lapic_nmi((acpi_madt_lapic_nmi_t *) + current, 2, MP_IRQ_POLARITY_HIGH | + MP_IRQ_TRIGGER_EDGE, 0x01); + current += acpi_create_madt_lapic_nmi((acpi_madt_lapic_nmi_t *) + current, 3, MP_IRQ_POLARITY_HIGH | + MP_IRQ_TRIGGER_EDGE, 0x01); + return current; +} + +unsigned long acpi_fill_ssdt_generator(unsigned long current, + const char *oem_table_id) +{ + generate_cpu_entries(); + return (unsigned long)(acpigen_get_current()); +} + +unsigned long acpi_fill_slit(unsigned long current) +{ + /* Not implemented */ + return current; +} + +unsigned long acpi_fill_srat(unsigned long current) +{ + /* No NUMA, no SRAT */ + return current; +} + +void smm_setup_structures(void *gnvs, void *tcg, void *smi1); + +#define ALIGN_CURRENT current = (ALIGN(current, 16)) +unsigned long write_acpi_tables(unsigned long start) +{ + unsigned long current; + int i; + acpi_rsdp_t *rsdp; + acpi_rsdt_t *rsdt; + acpi_xsdt_t *xsdt; + acpi_hpet_t *hpet; + acpi_madt_t *madt; + acpi_mcfg_t *mcfg; + acpi_fadt_t *fadt; + acpi_facs_t *facs; +#if CONFIG_HAVE_ACPI_SLIC + acpi_header_t *slic; +#endif + acpi_header_t *ssdt; + acpi_header_t *dsdt; + void *gnvs; + + current = start; + + /* Align ACPI tables to 16byte */ + ALIGN_CURRENT; + + printk(BIOS_INFO, "ACPI: Writing ACPI tables at %lx.\n", start); + + /* We need at least an RSDP and an RSDT Table */ + rsdp = (acpi_rsdp_t *) current; + current += sizeof(acpi_rsdp_t); + ALIGN_CURRENT; + rsdt = (acpi_rsdt_t *) current; + current += sizeof(acpi_rsdt_t); + ALIGN_CURRENT; + xsdt = (acpi_xsdt_t *) current; + current += sizeof(acpi_xsdt_t); + ALIGN_CURRENT; + + /* clear all table memory */ + memset((void *)start, 0, current - start); + + acpi_write_rsdp(rsdp, rsdt, xsdt); + acpi_write_rsdt(rsdt); + acpi_write_xsdt(xsdt); + + /* + * We explicitly add these tables later on: + */ + printk(BIOS_DEBUG, "ACPI: * HPET\n"); + + hpet = (acpi_hpet_t *) current; + current += sizeof(acpi_hpet_t); + ALIGN_CURRENT; + acpi_create_hpet(hpet); + acpi_add_table(rsdp, hpet); + + /* If we want to use HPET Timers Linux wants an MADT */ + printk(BIOS_DEBUG, "ACPI: * MADT\n"); + + madt = (acpi_madt_t *) current; + acpi_create_madt(madt); + current += madt->header.length; + ALIGN_CURRENT; + acpi_add_table(rsdp, madt); + + printk(BIOS_DEBUG, "ACPI: * MCFG\n"); + mcfg = (acpi_mcfg_t *) current; + acpi_create_mcfg(mcfg); + current += mcfg->header.length; + ALIGN_CURRENT; + acpi_add_table(rsdp, mcfg); + + printk(BIOS_DEBUG, "ACPI: * FACS\n"); + facs = (acpi_facs_t *) current; + current += sizeof(acpi_facs_t); + ALIGN_CURRENT; + acpi_create_facs(facs); + + dsdt = (acpi_header_t *) current; + memcpy(dsdt, &AmlCode, sizeof(acpi_header_t)); + current += dsdt->length; + memcpy(dsdt, &AmlCode, dsdt->length); + + /* Fix up global NVS region for SMI handler. The GNVS region lives + * in the (high) table area. The low memory map looks like this: + * + * 0x00000000 - 0x000003ff Real Mode IVT + * 0x00000400 - 0x000004ff BDA (somewhat unused) + * 0x00000500 - 0x0000052f Moved GDT + * 0x00000530 - 0x00000b64 coreboot table + * 0x0007c000 - 0x0007dfff OS boot sector (unused?) + * 0x0007e000 - 0x0007ffff free to use (so no good for acpi+smi) + * 0x00080000 - 0x0009fbff usable ram + * 0x0009fc00 - 0x0009ffff EBDA (unused?) + * 0x000a0000 - 0x000bffff VGA memory + * 0x000c0000 - 0x000cffff VGA option rom + * 0x000d0000 - 0x000dffff free for other option roms? + * 0x000e0000 - 0x000fffff SeaBIOS? (if payload is SeaBIOS it + overwrites those tables when + loading but uses tables at the RAM + end to put the tables again in suitable + place) + * 0x000f0000 - 0x000f03ff PIRQ table + * 0x000f0400 - 0x000f66?? ACPI tables + * 0x000f66?? - 0x000f???? DMI tables + */ + + ALIGN_CURRENT; + + /* Pack GNVS into the ACPI table area */ + for (i = 0; i < dsdt->length; i++) { + if (*(u32 *) (((u32) dsdt) + i) == 0xC0DEBABE) { + printk(BIOS_DEBUG, + "ACPI: Patching up global NVS in DSDT at offset 0x%04x -> 0x%08x\n", + i, (u32) current); + *(u32 *) (((u32) dsdt) + i) = current; + break; + } + } + + /* And fill it */ + acpi_create_gnvs((global_nvs_t *) current); + + /* Keep pointer around */ + gnvs = (void *)current; + + current += 0x100; + ALIGN_CURRENT; + + /* And tell SMI about it */ + smm_setup_structures(gnvs, NULL, NULL); + + /* We patched up the DSDT, so we need to recalculate the checksum */ + dsdt->checksum = 0; + dsdt->checksum = acpi_checksum((void *)dsdt, dsdt->length); + + printk(BIOS_DEBUG, "ACPI: * DSDT @ %p Length %x\n", dsdt, + dsdt->length); + +#if CONFIG_HAVE_ACPI_SLIC + printk(BIOS_DEBUG, "ACPI: * SLIC\n"); + slic = (acpi_header_t *) current; + current += acpi_create_slic(current); + ALIGN_CURRENT; + acpi_add_table(rsdp, slic); +#endif + + printk(BIOS_DEBUG, "ACPI: * FADT\n"); + fadt = (acpi_fadt_t *) current; + current += sizeof(acpi_fadt_t); + ALIGN_CURRENT; + + acpi_create_fadt(fadt, facs, dsdt); + acpi_add_table(rsdp, fadt); + + printk(BIOS_DEBUG, "ACPI: * SSDT\n"); + ssdt = (acpi_header_t *) current; + acpi_create_ssdt_generator(ssdt, ACPI_TABLE_CREATOR); + current += ssdt->length; + acpi_add_table(rsdp, ssdt); + ALIGN_CURRENT; + + printk(BIOS_DEBUG, "current = %lx\n", current); + printk(BIOS_INFO, "ACPI: done.\n"); + + /* Enable Dummy DCC ON# for DVI */ + printk(BIOS_DEBUG, "Laptop handling...\n"); + outb(inb(0x60f) & ~(1 << 5), 0x60f); + + return current; +} diff --git a/src/mainboard/packardbell/ms2290/board_info.txt b/src/mainboard/packardbell/ms2290/board_info.txt new file mode 100644 index 0000000..7df53c3 --- /dev/null +++ b/src/mainboard/packardbell/ms2290/board_info.txt @@ -0,0 +1,6 @@ +Board name: EasyNote LM85 (MS2290) +Category: laptop +ROM package: SOIC-8 +ROM protocol: SPI +ROM socketed: n +Flashrom support: n diff --git a/src/mainboard/packardbell/ms2290/cmos.default b/src/mainboard/packardbell/ms2290/cmos.default new file mode 100644 index 0000000..5820bfa --- /dev/null +++ b/src/mainboard/packardbell/ms2290/cmos.default @@ -0,0 +1,7 @@ +boot_option=Fallback +last_boot=Fallback +baud_rate=115200 +debug_level=Spew +power_on_after_fail=Enable +nmi=Enable +sata_mode=AHCI diff --git a/src/mainboard/packardbell/ms2290/cmos.layout b/src/mainboard/packardbell/ms2290/cmos.layout new file mode 100644 index 0000000..0f753b2 --- /dev/null +++ b/src/mainboard/packardbell/ms2290/cmos.layout @@ -0,0 +1,131 @@ +## +## This file is part of the coreboot project. +## +## Copyright (C) 2007-2008 coresystems GmbH +## Copyright (C) 2013 Vladimir Serbinenko +## +## This program is free software; you can redistribute it and/or modify +## it under the terms of the GNU General Public License as published by +## the Free Software Foundation; version 2 of the License. +## +## This program is distributed in the hope that it will be useful, +## but WITHOUT ANY WARRANTY; without even the implied warranty of +## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +## GNU General Public License for more details. +## +## You should have received a copy of the GNU General Public License +## along with this program; if not, write to the Free Software +## Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA +## + +# ----------------------------------------------------------------- +entries + +#start-bit length config config-ID name +#0 8 r 0 seconds +#8 8 r 0 alarm_seconds +#16 8 r 0 minutes +#24 8 r 0 alarm_minutes +#32 8 r 0 hours +#40 8 r 0 alarm_hours +#48 8 r 0 day_of_week +#56 8 r 0 day_of_month +#64 8 r 0 month +#72 8 r 0 year +# ----------------------------------------------------------------- +# Status Register A +#80 4 r 0 rate_select +#84 3 r 0 REF_Clock +#87 1 r 0 UIP +# ----------------------------------------------------------------- +# Status Register B +#88 1 r 0 auto_switch_DST +#89 1 r 0 24_hour_mode +#90 1 r 0 binary_values_enable +#91 1 r 0 square-wave_out_enable +#92 1 r 0 update_finished_enable +#93 1 r 0 alarm_interrupt_enable +#94 1 r 0 periodic_interrupt_enable +#95 1 r 0 disable_clock_updates +# ----------------------------------------------------------------- +# Status Register C +#96 4 r 0 status_c_rsvd +#100 1 r 0 uf_flag +#101 1 r 0 af_flag +#102 1 r 0 pf_flag +#103 1 r 0 irqf_flag +# ----------------------------------------------------------------- +# Status Register D +#104 7 r 0 status_d_rsvd +#111 1 r 0 valid_cmos_ram +# ----------------------------------------------------------------- +# Diagnostic Status Register +#112 8 r 0 diag_rsvd1 + +# ----------------------------------------------------------------- +0 120 r 0 reserved_memory +#120 264 r 0 unused + +# ----------------------------------------------------------------- +# RTC_BOOT_BYTE (coreboot hardcoded) +384 1 e 4 boot_option +385 1 e 4 last_boot +388 4 r 0 reboot_bits +#390 2 r 0 unused? + +# ----------------------------------------------------------------- +# coreboot config options: console +392 3 e 5 baud_rate +395 4 e 6 debug_level +#399 1 r 0 unused + +# coreboot config options: southbridge +408 1 e 1 nmi +409 2 e 7 power_on_after_fail +411 1 e 9 sata_mode + +# coreboot config options: check sums +984 16 h 0 check_sum +#1000 24 r 0 amd_reserved + +# ----------------------------------------------------------------- + +enumerations + +#ID value text +1 0 Disable +1 1 Enable +2 0 Enable +2 1 Disable +4 0 Fallback +4 1 Normal +5 0 115200 +5 1 57600 +5 2 38400 +5 3 19200 +5 4 9600 +5 5 4800 +5 6 2400 +5 7 1200 +6 1 Emergency +6 2 Alert +6 3 Critical +6 4 Error +6 5 Warning +6 6 Notice +6 7 Info +6 8 Debug +6 9 Spew +7 0 Disable +7 1 Enable +7 2 Keep +8 0 Secondary +8 1 Primary +9 0 AHCI +9 1 Compatible +# ----------------------------------------------------------------- +checksums + +checksum 392 415 984 + + diff --git a/src/mainboard/packardbell/ms2290/devicetree.cb b/src/mainboard/packardbell/ms2290/devicetree.cb new file mode 100644 index 0000000..a57a2c1 --- /dev/null +++ b/src/mainboard/packardbell/ms2290/devicetree.cb @@ -0,0 +1,104 @@ +## +## This file is part of the coreboot project. +## +## Copyright (C) 2007-2009 coresystems GmbH +## Copyright (C) 2011 Sven Schnelle svens@stackframe.org +## +## This program is free software; you can redistribute it and/or +## modify it under the terms of the GNU General Public License as +## published by the Free Software Foundation; version 2 of +## the License. +## +## This program is distributed in the hope that it will be useful, +## but WITHOUT ANY WARRANTY; without even the implied warranty of +## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +## GNU General Public License for more details. +## +## You should have received a copy of the GNU General Public License +## along with this program; if not, write to the Free Software +## Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, +## MA 02110-1301 USA +## + +chip northbridge/intel/nehalem + + register "gpu_dp_b_hotplug" = "0x04" + register "gpu_dp_c_hotplug" = "0x04" + register "gpu_dp_d_hotplug" = "0x04" + + # Enable Panel as LVDS and configure power delays + register "gpu_panel_port_select" = "0" # LVDS + register "gpu_panel_power_cycle_delay" = "6" + register "gpu_panel_power_up_delay" = "300" + register "gpu_panel_power_down_delay" = "300" + register "gpu_panel_power_backlight_on_delay" = "3000" + register "gpu_panel_power_backlight_off_delay" = "3000" + register "gpu_cpu_backlight" = "0x58d" + register "gpu_pch_backlight" = "0x061a061a" + register "gpu_use_spread_spectrum_clock" = "0" + register "gpu_lvds_dual_channel" = "1" + register "gpu_link_frequency_270_mhz" = "1" + register "gpu_lvds_num_lanes" = "4" + + device cpu_cluster 0 on + chip cpu/intel/model_2065x + device lapic 0 on end + end + end + + device domain 0 on + device pci 00.0 on # Host bridge + subsystemid 0x1025 0x0379 + end + device pci 02.0 on # VGA controller + subsystemid 0x1025 0x0379 + end + chip southbridge/intel/ibexpeak + register "pirqa_routing" = "0x0b" + register "pirqb_routing" = "0x0b" + register "pirqc_routing" = "0x0b" + register "pirqd_routing" = "0x0b" + register "pirqe_routing" = "0x0b" + register "pirqf_routing" = "0x0b" + register "pirqg_routing" = "0x0b" + register "pirqh_routing" = "0x0b" + + # GPI routing + # 0 No effect (default) + # 1 SMI# (if corresponding ALT_GPI_SMI_EN bit is also set) + # 2 SCI (if corresponding GPIO_EN bit is also set) + register "gpi7_routing" = "2" + register "gpi8_routing" = "2" + + register "sata_port_map" = "0x11" + + register "gpe0_en" = "0x01800046" + register "alt_gp_smi_en" = "0x0000" + register "gen1_dec" = "0x040069" + + device pci 1a.0 on # USB2 EHCI + subsystemid 0x1025 0x0379 + end + + device pci 1b.0 on # Audio Controller + subsystemid 0x1025 0x0379 + end + + device pci 1c.0 on end # PCIe Port #1 + device pci 1c.1 on end # PCIe Port #1 + + device pci 1d.0 on # USB2 EHCI + subsystemid 0x1025 0x0379 + end + device pci 1f.0 on # PCI-LPC bridge + subsystemid 0x1025 0x0379 + end + device pci 1f.2 on # IDE/SATA + subsystemid 0x1025 0x0379 + end + device pci 1f.3 on # SMBUS + subsystemid 0x1025 0x0379 + end + end + end +end diff --git a/src/mainboard/packardbell/ms2290/dsdt.asl b/src/mainboard/packardbell/ms2290/dsdt.asl new file mode 100644 index 0000000..85542bf --- /dev/null +++ b/src/mainboard/packardbell/ms2290/dsdt.asl @@ -0,0 +1,91 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007-2009 coresystems GmbH + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of + * the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +DefinitionBlock( + "dsdt.aml", + "DSDT", + 0x03, /* DSDT revision: ACPI v3.0 */ + "COREv4", /* OEM id */ + "COREBOOT", /* OEM table id */ + 0x20140108 /* OEM revision */ +) +{ + /* Some generic macros */ + #include "acpi/platform.asl" + + /* global NVS and variables */ + #include <southbridge/intel/bd82x6x/acpi/globalnvs.asl> + + /* General Purpose Events */ + #include "acpi/gpe.asl" + + /* mainboard specific devices */ + #include "acpi/mainboard.asl" + + #include <cpu/intel/model_206ax/acpi/cpu.asl> + + Scope (_SB) { + Device (PCI0) + { + #include <northbridge/intel/nehalem/acpi/nehalem.asl> + #include <southbridge/intel/bd82x6x/acpi/pch.asl> + } + Device (UNCR) + { + Name (_BBN, 0xFF) + Name (_ADR, 0x00) + Name (RID, 0x00) + Name (_HID, EisaId ("PNP0A03")) + Name (_CRS, ResourceTemplate () + { + WordBusNumber (ResourceProducer, MinFixed, MaxFixed, PosDecode, + 0x0000, /* Granularity */ + 0x00FF, /* Range Minimum */ + 0x00FF, /* Range Maximum */ + 0x0000, /* Translation Offset */ + 0x0001, /* Length */ + ,, ) + }) + Device (SAD) + { + Name (_ADR, 0x01) + Name (RID, 0x00) + OperationRegion (SADC, PCI_Config, 0x00, 0x0100) + Field (SADC, DWordAcc, NoLock, Preserve) + { + Offset (0x40), + PAM0, 8, + PAM1, 8, + PAM2, 8, + PAM3, 8, + PAM4, 8, + PAM5, 8, + PAM6, 8 + } + } + } + } + + #include "acpi/video.asl" + + /* Chipset specific sleep states */ + #include <southbridge/intel/i82801gx/acpi/sleepstates.asl> +} diff --git a/src/mainboard/packardbell/ms2290/fadt.c b/src/mainboard/packardbell/ms2290/fadt.c new file mode 100644 index 0000000..0639026 --- /dev/null +++ b/src/mainboard/packardbell/ms2290/fadt.c @@ -0,0 +1,160 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007-2008 coresystems GmbH + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of + * the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <string.h> +#include <device/pci.h> +#include <arch/acpi.h> +#include <cpu/x86/smm.h> + +/* FIXME: This needs to go into a separate .h file + * to be included by the ich7 smi handler, ich7 smi init + * code and the mainboard fadt. + */ + +void acpi_create_fadt(acpi_fadt_t * fadt, acpi_facs_t * facs, void *dsdt) +{ + acpi_header_t *header = &(fadt->header); + u16 pmbase = + pci_read_config16(dev_find_slot(0, PCI_DEVFN(0x1f, 0)), + 0x40) & 0xfffe; + + memset((void *)fadt, 0, sizeof(acpi_fadt_t)); + memcpy(header->signature, "FACP", 4); + header->length = sizeof(acpi_fadt_t); + header->revision = 3; + memcpy(header->oem_id, OEM_ID, 6); + memcpy(header->oem_table_id, ACPI_TABLE_CREATOR, 8); + memcpy(header->asl_compiler_id, ASLC, 4); + header->asl_compiler_revision = 0; + + fadt->firmware_ctrl = (unsigned long)facs; + fadt->dsdt = (unsigned long)dsdt; + fadt->model = 0x00; + fadt->preferred_pm_profile = PM_MOBILE; + fadt->sci_int = 0x9; + fadt->smi_cmd = APM_CNT; + fadt->acpi_enable = APM_CNT_ACPI_ENABLE; + fadt->acpi_disable = APM_CNT_ACPI_DISABLE; + fadt->s4bios_req = 0x0; + fadt->pstate_cnt = APM_CNT_PST_CONTROL; + + fadt->pm1a_evt_blk = pmbase; + fadt->pm1b_evt_blk = 0x0; + fadt->pm1a_cnt_blk = pmbase + 0x4; + fadt->pm1b_cnt_blk = 0x0; + fadt->pm2_cnt_blk = pmbase + 0x50; + fadt->pm_tmr_blk = pmbase + 0x8; + fadt->gpe0_blk = pmbase + 0x20; + fadt->gpe1_blk = 0; + + fadt->pm1_evt_len = 4; + fadt->pm1_cnt_len = 2; + fadt->pm2_cnt_len = 1; + fadt->pm_tmr_len = 4; + fadt->gpe0_blk_len = 0x10; + fadt->gpe1_blk_len = 0; + fadt->gpe1_base = 0; + fadt->cst_cnt = APM_CNT_CST_CONTROL; + fadt->p_lvl2_lat = 1; + fadt->p_lvl3_lat = 0x23; + fadt->flush_size = 0; + fadt->flush_stride = 0; + fadt->duty_offset = 1; + fadt->duty_width = 3; + fadt->day_alrm = 0xd; + fadt->mon_alrm = 0x00; + fadt->century = 0x32; + fadt->iapc_boot_arch = 0x00; + fadt->flags = ACPI_FADT_WBINVD | ACPI_FADT_C1_SUPPORTED | + ACPI_FADT_SLEEP_BUTTON | ACPI_FADT_S4_RTC_WAKE | + ACPI_FADT_DOCKING_SUPPORTED; + + fadt->reset_reg.space_id = 0; + fadt->reset_reg.bit_width = 0; + fadt->reset_reg.bit_offset = 0; + fadt->reset_reg.resv = 0; + fadt->reset_reg.addrl = 0x0; + fadt->reset_reg.addrh = 0x0; + + fadt->reset_value = 0; + fadt->x_firmware_ctl_l = (unsigned long)facs; + fadt->x_firmware_ctl_h = 0; + fadt->x_dsdt_l = (unsigned long)dsdt; + fadt->x_dsdt_h = 0; + + fadt->x_pm1a_evt_blk.space_id = 1; + fadt->x_pm1a_evt_blk.bit_width = 32; + fadt->x_pm1a_evt_blk.bit_offset = 0; + fadt->x_pm1a_evt_blk.resv = 0; + fadt->x_pm1a_evt_blk.addrl = pmbase; + fadt->x_pm1a_evt_blk.addrh = 0x0; + + fadt->x_pm1b_evt_blk.space_id = 0; + fadt->x_pm1b_evt_blk.bit_width = 0; + fadt->x_pm1b_evt_blk.bit_offset = 0; + fadt->x_pm1b_evt_blk.resv = 0; + fadt->x_pm1b_evt_blk.addrl = 0x0; + fadt->x_pm1b_evt_blk.addrh = 0x0; + + fadt->x_pm1a_cnt_blk.space_id = 1; + fadt->x_pm1a_cnt_blk.bit_width = 32; + fadt->x_pm1a_cnt_blk.bit_offset = 0; + fadt->x_pm1a_cnt_blk.resv = 0; + fadt->x_pm1a_cnt_blk.addrl = pmbase + 0x4; + fadt->x_pm1a_cnt_blk.addrh = 0x0; + + fadt->x_pm1b_cnt_blk.space_id = 0; + fadt->x_pm1b_cnt_blk.bit_width = 0; + fadt->x_pm1b_cnt_blk.bit_offset = 0; + fadt->x_pm1b_cnt_blk.resv = 0; + fadt->x_pm1b_cnt_blk.addrl = 0x0; + fadt->x_pm1b_cnt_blk.addrh = 0x0; + + fadt->x_pm2_cnt_blk.space_id = 1; + fadt->x_pm2_cnt_blk.bit_width = 8; + fadt->x_pm2_cnt_blk.bit_offset = 0; + fadt->x_pm2_cnt_blk.resv = 0; + fadt->x_pm2_cnt_blk.addrl = pmbase + 0x50; + fadt->x_pm2_cnt_blk.addrh = 0x0; + + fadt->x_pm_tmr_blk.space_id = 1; + fadt->x_pm_tmr_blk.bit_width = 32; + fadt->x_pm_tmr_blk.bit_offset = 0; + fadt->x_pm_tmr_blk.resv = 0; + fadt->x_pm_tmr_blk.addrl = pmbase + 0x8; + fadt->x_pm_tmr_blk.addrh = 0x0; + + fadt->x_gpe0_blk.space_id = 1; + fadt->x_gpe0_blk.bit_width = 128; + fadt->x_gpe0_blk.bit_offset = 0; + fadt->x_gpe0_blk.resv = 0; + fadt->x_gpe0_blk.addrl = pmbase + 0x20; + fadt->x_gpe0_blk.addrh = 0x0; + + fadt->x_gpe1_blk.space_id = 0; + fadt->x_gpe1_blk.bit_width = 0; + fadt->x_gpe1_blk.bit_offset = 0; + fadt->x_gpe1_blk.resv = 0; + fadt->x_gpe1_blk.addrl = 0x0; + fadt->x_gpe1_blk.addrh = 0x0; + + header->checksum = acpi_checksum((void *)fadt, header->length); +} diff --git a/src/mainboard/packardbell/ms2290/gma.c b/src/mainboard/packardbell/ms2290/gma.c new file mode 100644 index 0000000..540d858 --- /dev/null +++ b/src/mainboard/packardbell/ms2290/gma.c @@ -0,0 +1,272 @@ +#include <arch/io.h> +#include <device/device.h> +#include <device/pci.h> +#include <device/pci_ids.h> +#include <device/pci_ops.h> + +#include "northbridge/intel/nehalem/nehalem.h" + +/* This array contains the information on flat panel. When using native + graphics init coreboot copies it to where VGA Option ROM would be so + that OS can find it and able to use internal display. This contains no + executable code and is just information on the panel. + */ + +unsigned char fake_vbt[] = { +0x24, 0x56, 0x42, 0x54, 0x20, 0x49, 0x52, 0x4f, 0x4e, 0x4c, 0x41, 0x4b, 0x45, 0x2d, 0x4d, 0x4f, +0x42, 0x49, 0x4c, 0x45, 0x64, 0x00, 0x30, 0x00, 0xc3, 0x10, 0xa4, 0x00, 0x30, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x42, 0x49, 0x4f, 0x53, 0x5f, 0x44, 0x41, 0x54, 0x41, 0x5f, 0x42, 0x4c, 0x4f, 0x43, 0x4b, 0x20, +0x9b, 0x00, 0x16, 0x00, 0x93, 0x10, 0xfe, 0xea, 0x00, 0x00, 0x64, 0x01, 0x01, 0x0f, 0x0d, 0x31, +0x39, 0x39, 0x34, 0x49, 0x6e, 0x74, 0x65, 0x6c, 0x28, 0x52, 0x29, 0x49, 0x72, 0x6f, 0x6e, 0x6c, +0x61, 0x6b, 0x65, 0x20, 0x4d, 0x6f, 0x62, 0x69, 0x6c, 0x65, 0x20, 0x50, 0x43, 0x49, 0x20, 0x41, +0x63, 0x63, 0x65, 0x6c, 0x65, 0x72, 0x61, 0x74, 0x65, 0x64, 0x20, 0x53, 0x56, 0x47, 0x41, 0x20, +0x42, 0x49, 0x4f, 0x53, 0x0d, 0x0a, 0x42, 0x75, 0x69, 0x6c, 0x64, 0x20, 0x4e, 0x75, 0x6d, 0x62, +0x65, 0x72, 0x3a, 0x20, 0x69, 0x6c, 0x6d, 0x31, 0x39, 0x39, 0x34, 0x31, 0x2e, 0x6a, 0x76, 0x37, +0x20, 0x50, 0x43, 0x20, 0x31, 0x34, 0x2e, 0x33, 0x34, 0x20, 0x20, 0x30, 0x35, 0x2f, 0x32, 0x36, +0x2f, 0x32, 0x30, 0x31, 0x30, 0x20, 0x20, 0x31, 0x39, 0x3a, 0x32, 0x32, 0x3a, 0x30, 0x33, 0x0d, +0x0a, 0x44, 0x45, 0x43, 0x4f, 0x4d, 0x50, 0x49, 0x4c, 0x41, 0x54, 0x49, 0x4f, 0x4e, 0x20, 0x4f, +0x52, 0x20, 0x44, 0x49, 0x53, 0x41, 0x53, 0x53, 0x45, 0x4d, 0x42, 0x4c, 0x59, 0x20, 0x50, 0x52, +0x4f, 0x48, 0x49, 0x42, 0x49, 0x54, 0x45, 0x44, 0x0d, 0x0a, 0x00, 0x00, 0x00, 0x00, 0x43, 0x6f, +0x70, 0x79, 0x72, 0x69, 0x67, 0x68, 0x74, 0x20, 0x28, 0x43, 0x29, 0x20, 0x32, 0x30, 0x30, 0x30, +0x2d, 0x32, 0x30, 0x30, 0x33, 0x20, 0x49, 0x6e, 0x74, 0x65, 0x6c, 0x20, 0x43, 0x6f, 0x72, 0x70, +0x2e, 0x20, 0x41, 0x6c, 0x6c, 0x20, 0x52, 0x69, 0x67, 0x68, 0x74, 0x73, 0x20, 0x52, 0x65, 0x73, +0x65, 0x72, 0x76, 0x65, 0x64, 0x2e, 0x0d, 0x0a, 0x0d, 0x0a, 0x00, 0x00, 0xc0, 0x03, 0x08, 0x04, +0x01, 0x00, 0x00, 0x01, 0x05, 0x00, 0x07, 0x01, 0x00, 0x01, 0x01, 0xfe, 0x20, 0x00, 0x01, 0x01, +0x08, 0x08, 0x04, 0x04, 0x09, 0x08, 0x0c, 0x08, 0x05, 0x04, 0x0d, 0x08, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x0d, +0x01, 0x02, 0x04, 0x00, 0x00, 0x21, 0x08, 0x00, 0x22, 0x10, 0x00, 0x4c, 0x46, 0x50, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0xc0, 0xd1, 0x04, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x00, 0xd2, 0x60, 0x00, 0x20, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0xe4, 0x01, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x00, 0x05, +0x00, 0x00, 0x20, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x20, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x20, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x01, +0x00, 0x00, 0x04, 0x1c, 0x00, 0x30, 0x32, 0x34, 0x36, 0x38, 0x3a, 0x3c, 0x40, 0x42, 0x44, 0x46, +0x48, 0x4a, 0x4c, 0x50, 0x52, 0x54, 0x56, 0x58, 0x5a, 0x5c, 0x80, 0x81, 0x82, 0x83, 0x84, 0x1a, +0x00, 0xfe, 0xac, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x01, +0x01, 0x00, 0x00, 0x00, 0x0e, 0x01, 0x20, 0x00, 0xf4, 0x07, 0x1e, 0x00, 0x8e, 0x04, 0x28, 0x00, +0xbb, 0x04, 0x02, 0x00, 0xc5, 0x04, 0x38, 0x00, 0x06, 0x05, 0xc8, 0x00, 0x54, 0x07, 0x30, 0x00, +0x87, 0x07, 0x18, 0x00, 0xa2, 0x07, 0x18, 0x00, 0xbd, 0x07, 0x18, 0x00, 0xc0, 0x08, 0x08, 0x00, +0x04, 0x09, 0x12, 0x00, 0x16, 0x09, 0x12, 0x00, 0x28, 0x09, 0x12, 0x00, 0x3a, 0x09, 0x12, 0x00, +0x4f, 0x09, 0x0a, 0x00, 0x59, 0x09, 0x0a, 0x00, 0x63, 0x09, 0x0a, 0x00, 0x6d, 0x09, 0x0a, 0x00, +0x7a, 0x09, 0x0a, 0x00, 0x84, 0x09, 0x0a, 0x00, 0x8e, 0x09, 0x0a, 0x00, 0x98, 0x09, 0x0a, 0x00, +0xaa, 0x09, 0x0a, 0x00, 0xb4, 0x09, 0x0a, 0x00, 0xbe, 0x09, 0x0a, 0x00, 0xc8, 0x09, 0x0a, 0x00, +0xd2, 0x09, 0x0a, 0x00, 0xdc, 0x09, 0x0a, 0x00, 0xe6, 0x09, 0x0a, 0x00, 0xf0, 0x09, 0x0a, 0x00, +0xfa, 0x09, 0x0a, 0x00, 0x04, 0x0a, 0x0a, 0x00, 0x0e, 0x0a, 0x0a, 0x00, 0x18, 0x0a, 0x0a, 0x00, +0x22, 0x0a, 0x0a, 0x00, 0x2c, 0x0a, 0x0a, 0x00, 0x36, 0x0a, 0x0a, 0x00, 0x40, 0x0a, 0x0a, 0x00, +0x06, 0xa5, 0x01, 0xfc, 0xff, 0x02, 0x14, 0x60, 0x0c, 0x00, 0x80, 0x00, 0x80, 0x04, 0x40, 0x60, +0x0c, 0x00, 0x07, 0x0d, 0x03, 0x00, 0x44, 0x60, 0x0c, 0x00, 0x07, 0x0d, 0x03, 0x00, 0x18, 0x60, +0x0c, 0x00, 0x80, 0x00, 0x80, 0x04, 0x48, 0x60, 0x0c, 0x00, 0x07, 0x0d, 0x03, 0x00, 0x4c, 0x60, +0x0c, 0x00, 0x07, 0x0d, 0x03, 0x00, 0x80, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x01, +0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x11, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, +0x04, 0x00, 0x00, 0x00, 0x00, 0x80, 0x9c, 0x01, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x9c, 0x11, +0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x00, 0x7f, 0x02, 0x1f, 0x03, 0x04, 0x00, +0x06, 0x00, 0x87, 0x02, 0x17, 0x03, 0x08, 0x00, 0x06, 0x00, 0x8f, 0x02, 0xef, 0x02, 0x0c, 0x00, +0x06, 0x00, 0xdf, 0x01, 0x0c, 0x02, 0x10, 0x00, 0x06, 0x00, 0xe7, 0x01, 0x04, 0x02, 0x14, 0x00, +0x06, 0x00, 0xe9, 0x01, 0xeb, 0x01, 0x1c, 0x00, 0x06, 0x00, 0xdf, 0x01, 0x7f, 0x02, 0x00, 0x10, +0x06, 0x00, 0x7f, 0x02, 0x1f, 0x03, 0x04, 0x10, 0x06, 0x00, 0x87, 0x02, 0x17, 0x03, 0x08, 0x10, +0x06, 0x00, 0x8f, 0x02, 0xef, 0x02, 0x0c, 0x10, 0x06, 0x00, 0xdf, 0x01, 0x0c, 0x02, 0x10, 0x10, +0x06, 0x00, 0xe7, 0x01, 0x04, 0x02, 0x14, 0x10, 0x06, 0x00, 0xe9, 0x01, 0xeb, 0x01, 0x1c, 0x10, +0x06, 0x00, 0xdf, 0x01, 0x7f, 0x02, 0x00, 0x00, 0x0e, 0x00, 0x7f, 0x02, 0x1f, 0x03, 0x04, 0x00, +0x0e, 0x00, 0x87, 0x02, 0x17, 0x03, 0x08, 0x00, 0x0e, 0x00, 0x8f, 0x02, 0xef, 0x02, 0x0c, 0x00, +0x0e, 0x00, 0xdf, 0x01, 0x0c, 0x02, 0x10, 0x00, 0x0e, 0x00, 0xe7, 0x01, 0x04, 0x02, 0x14, 0x00, +0x0e, 0x00, 0xe9, 0x01, 0xeb, 0x01, 0x00, 0x10, 0x0e, 0x00, 0x7f, 0x02, 0x1f, 0x03, 0x04, 0x10, +0x0e, 0x00, 0x87, 0x02, 0x17, 0x03, 0x08, 0x10, 0x0e, 0x00, 0x8f, 0x02, 0xef, 0x02, 0x0c, 0x10, +0x0e, 0x00, 0xdf, 0x01, 0x0c, 0x02, 0x10, 0x10, 0x0e, 0x00, 0xe7, 0x01, 0x04, 0x02, 0x14, 0x10, +0x0e, 0x00, 0xe9, 0x01, 0xeb, 0x01, 0x00, 0x50, 0x04, 0x00, 0x22, 0x06, 0x24, 0xc2, 0x08, 0x00, +0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x10, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, +0x04, 0x00, 0x8e, 0x29, 0x00, 0x80, 0x00, 0x11, 0x0e, 0x00, 0x18, 0x00, 0x00, 0x00, 0x00, 0x40, +0x06, 0x00, 0x18, 0x00, 0x00, 0x00, 0x40, 0x11, 0x0e, 0x00, 0x18, 0x00, 0x00, 0x00, 0x50, 0x11, +0x0e, 0x00, 0x18, 0x00, 0x00, 0x00, 0x60, 0x11, 0x0e, 0x00, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0x07, 0x07, 0x00, 0xfe, 0xff, 0xce, 0x18, 0x00, +0xff, 0xff, 0x08, 0x3d, 0x00, 0xfc, 0xff, 0x02, 0x40, 0xf0, 0x04, 0x00, 0x01, 0x00, 0x00, 0x01, +0x44, 0xf0, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x48, 0xf0, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, +0x4c, 0xf0, 0x04, 0x00, 0x00, 0x00, 0x03, 0x03, 0x50, 0xf0, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, +0x54, 0xf0, 0x04, 0x00, 0x01, 0x00, 0x00, 0x00, 0x58, 0xf0, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, +0xff, 0xff, 0x0a, 0xcb, 0x00, 0x0a, 0x80, 0x02, 0xe0, 0x01, 0xff, 0xff, 0xff, 0xda, 0xff, 0xff, +0x20, 0x03, 0x58, 0x02, 0xff, 0x03, 0xfe, 0x07, 0xff, 0xff, 0x00, 0x04, 0x00, 0x03, 0xff, 0x1b, +0xfe, 0x07, 0xff, 0xff, 0x80, 0x04, 0x60, 0x03, 0xff, 0xff, 0xff, 0x07, 0xff, 0xff, 0x00, 0x05, +0x58, 0x02, 0xff, 0xff, 0xff, 0xbf, 0xff, 0xff, 0x00, 0x05, 0xd0, 0x02, 0xff, 0x1b, 0xff, 0xbf, +0xff, 0xff, 0x00, 0x05, 0x00, 0x03, 0xff, 0x9b, 0xff, 0xbf, 0xff, 0xff, 0x00, 0x05, 0xc0, 0x03, +0xff, 0x9b, 0xff, 0x07, 0xff, 0xff, 0x00, 0x05, 0x00, 0x04, 0xff, 0x1b, 0xfe, 0x07, 0xff, 0xff, +0x56, 0x05, 0x00, 0x03, 0xff, 0x9b, 0xff, 0x07, 0xff, 0xff, 0x40, 0x06, 0x84, 0x03, 0xff, 0x1b, +0xfe, 0x07, 0xff, 0xff, 0x40, 0x06, 0xb0, 0x04, 0xff, 0x1b, 0xfe, 0x07, 0xff, 0xff, 0x00, 0x07, +0x40, 0x05, 0xff, 0xff, 0xff, 0x07, 0xff, 0xff, 0x40, 0x07, 0x70, 0x05, 0xff, 0xff, 0xff, 0x07, +0xff, 0xff, 0x80, 0x07, 0x38, 0x04, 0xff, 0x1b, 0xff, 0x07, 0xff, 0xff, 0x80, 0x07, 0xb0, 0x04, +0xff, 0xdb, 0xff, 0x07, 0xff, 0xff, 0x80, 0x07, 0xa0, 0x05, 0xff, 0x9b, 0xff, 0x07, 0xff, 0xff, +0x00, 0x08, 0x00, 0x06, 0xff, 0xdb, 0xff, 0x07, 0xff, 0xff, 0x78, 0x05, 0x1a, 0x04, 0xff, 0x9b, +0xff, 0x07, 0xff, 0xff, 0x90, 0x06, 0xb1, 0x03, 0xff, 0x1b, 0xff, 0x07, 0xff, 0xff, 0x00, 0x00, +0x0b, 0xc7, 0x00, 0x21, 0x40, 0x00, 0x00, 0x00, 0x03, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x72, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00, 0x09, 0x06, 0x03, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x05, 0x72, 0x1d, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x50, 0x00, 0x00, 0x00, 0x03, 0x20, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0x00, 0x00, 0x00, 0x03, 0x20, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x03, 0x20, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x03, 0x20, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0c, 0x11, 0x00, 0x4e, 0x56, 0x05, +0x00, 0x03, 0x10, 0x3c, 0x84, 0x0e, 0x00, 0x00, 0x00, 0x00, 0x00, 0x55, 0x00, 0x01, 0x0d, 0x03, +0x00, 0x78, 0x01, 0x0a, 0x0e, 0x09, 0x00, 0x01, 0xc5, 0x06, 0x5a, 0x00, 0x21, 0x07, 0x2d, 0x00, +0x0f, 0x8b, 0x00, 0x09, 0x0a, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x09, +0x05, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x84, +0x00, 0x10, 0x00, 0x03, 0x01, 0x08, 0x00, 0x04, 0x08, 0x00, 0x01, 0x00, 0x00, 0x04, 0x00, 0x00, +0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x03, 0x01, 0x00, 0x00, 0x01, 0x08, 0x00, 0x00, 0x08, 0x00, +0x02, 0x00, 0x00, 0x01, 0x04, 0x00, 0x04, 0x00, 0x00, 0x04, 0x08, 0x00, 0x00, 0x00, 0x00, 0x08, +0x00, 0x03, 0x01, 0x00, 0x00, 0x01, 0x08, 0x00, 0x00, 0x08, 0x00, 0x02, 0x00, 0x00, 0x01, 0x04, +0x00, 0x04, 0x00, 0x00, 0x04, 0x08, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x03, 0x01, 0x00, 0x00, +0x01, 0x08, 0x00, 0x00, 0x08, 0x00, 0x02, 0x00, 0x00, 0x01, 0x04, 0x00, 0x04, 0x00, 0x00, 0x04, +0x08, 0x00, 0x00, 0x00, 0x00, 0x11, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x12, 0x0c, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x13, +0x20, 0x00, 0x0f, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x14, 0x9e, 0x00, 0x06, 0x1a, 0x03, 0x99, 0x00, 0x05, 0x20, 0x03, 0x07, 0x3c, 0xa9, +0x20, 0x00, 0x90, 0x51, 0x20, 0x1c, 0x30, 0x08, 0x88, 0x93, 0x00, 0x00, 0x20, 0x53, 0x00, 0x00, +0x00, 0x01, 0x99, 0xa0, 0x05, 0x84, 0x03, 0x07, 0x3c, 0xab, 0x22, 0xa0, 0xa0, 0x50, 0x84, 0x1a, +0x30, 0x30, 0x20, 0x36, 0x00, 0x2f, 0xbe, 0x10, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x07, 0x3c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x3c, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x3c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, +0x3c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x16, 0x4b, 0x00, 0x00, 0x00, 0x03, 0x07, 0x00, 0x00, 0x00, 0x00, 0x08, 0x01, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x84, 0x0e, 0x00, 0x00, 0x4c, 0x46, 0x50, +0x5f, 0x50, 0x61, 0x6e, 0x65, 0x6c, 0x4e, 0x61, 0x6d, 0x65, 0x4c, 0x46, 0x50, 0x5f, 0x50, 0x61, +0x6e, 0x65, 0x6c, 0x4e, 0x61, 0x6d, 0x65, 0x4c, 0x46, 0x50, 0x5f, 0x50, 0x61, 0x6e, 0x65, 0x6c, +0x4e, 0x61, 0x6d, 0x65, 0x4c, 0x46, 0x50, 0x5f, 0x50, 0x61, 0x6e, 0x65, 0x6c, 0x4e, 0x61, 0x6d, +0x65, 0x17, 0x48, 0x00, 0x64, 0x19, 0x00, 0x40, 0x41, 0x00, 0x26, 0x30, 0x18, 0x88, 0x36, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x30, 0x2a, 0x00, 0x98, 0x51, 0x00, 0x30, 0x40, 0x30, 0x70, +0x13, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1e, 0xa8, 0x2f, 0x78, 0xe0, 0x51, 0x1a, 0x26, 0x40, +0x58, 0x98, 0x13, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1e, 0x48, 0x3f, 0x40, 0x30, 0x62, 0xb0, +0x32, 0x40, 0x40, 0xc0, 0x13, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1e, 0x18, 0x28, 0x00, 0x36, +0x7f, 0x03, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x0c, 0x36, 0x7f, 0x05, 0x00, 0x02, 0x00, 0x00, +0x00, 0x00, 0x0c, 0x36, 0x7f, 0x01, 0x90, 0x03, 0x00, 0x00, 0x00, 0x00, 0x0c, 0x36, 0x7f, 0x06, +0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x0c, 0x19, 0x28, 0x00, 0x19, 0x00, 0xfa, 0x00, 0xfa, 0x00, +0x19, 0x00, 0x90, 0x01, 0x20, 0x00, 0x20, 0x00, 0x20, 0x00, 0x20, 0x00, 0xc8, 0x00, 0x40, 0x00, +0x40, 0x00, 0x40, 0x00, 0x40, 0x00, 0x2c, 0x01, 0x40, 0x00, 0x40, 0x00, 0x40, 0x00, 0x40, 0x00, +0x2c, 0x01, 0x1a, 0x02, 0x00, 0x00, 0x00, 0x1b, 0xc8, 0x00, 0xd0, 0x07, 0x0a, 0x00, 0xd0, 0x07, +0xf4, 0x01, 0x88, 0x13, 0xd0, 0x07, 0x0a, 0x00, 0xd0, 0x07, 0xf4, 0x01, 0x88, 0x13, 0xd0, 0x07, +0x0a, 0x00, 0xd0, 0x07, 0xf4, 0x01, 0x88, 0x13, 0xd0, 0x07, 0x0a, 0x00, 0xd0, 0x07, 0xf4, 0x01, +0x88, 0x13, 0xd0, 0x07, 0x0a, 0x00, 0xd0, 0x07, 0xf4, 0x01, 0x88, 0x13, 0xd0, 0x07, 0x0a, 0x00, +0xd0, 0x07, 0xf4, 0x01, 0x88, 0x13, 0xd0, 0x07, 0x0a, 0x00, 0xd0, 0x07, 0xf4, 0x01, 0x88, 0x13, +0xd0, 0x07, 0x0a, 0x00, 0xd0, 0x07, 0xf4, 0x01, 0x88, 0x13, 0xd0, 0x07, 0x0a, 0x00, 0xd0, 0x07, +0xf4, 0x01, 0x88, 0x13, 0xd0, 0x07, 0x0a, 0x00, 0xd0, 0x07, 0xf4, 0x01, 0x88, 0x13, 0xd0, 0x07, +0x0a, 0x00, 0xd0, 0x07, 0xf4, 0x01, 0x88, 0x13, 0xd0, 0x07, 0x0a, 0x00, 0xd0, 0x07, 0xf4, 0x01, +0x88, 0x13, 0xd0, 0x07, 0x0a, 0x00, 0xd0, 0x07, 0xf4, 0x01, 0x88, 0x13, 0xd0, 0x07, 0x0a, 0x00, +0xd0, 0x07, 0xf4, 0x01, 0x88, 0x13, 0xd0, 0x07, 0x0a, 0x00, 0xd0, 0x07, 0xf4, 0x01, 0x88, 0x13, +0xd0, 0x07, 0x0a, 0x00, 0xd0, 0x07, 0xf4, 0x01, 0x88, 0x13, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x28, 0x18, 0x00, 0x02, 0x00, 0x73, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x29, 0x94, 0x00, +0x03, 0x27, 0x0b, 0x20, 0x4d, 0x0b, 0x12, 0x5f, 0x0b, 0x0a, 0x69, 0x0b, 0x20, 0x8f, 0x0b, 0x12, +0xa1, 0x0b, 0x0a, 0xab, 0x0b, 0x20, 0xd1, 0x0b, 0x12, 0xe3, 0x0b, 0x0a, 0xed, 0x0b, 0x20, 0x13, +0x0c, 0x12, 0x25, 0x0c, 0x0a, 0x2f, 0x0c, 0x20, 0x55, 0x0c, 0x12, 0x67, 0x0c, 0x0a, 0x71, 0x0c, +0x20, 0x97, 0x0c, 0x12, 0xa9, 0x0c, 0x0a, 0xb3, 0x0c, 0x20, 0xd9, 0x0c, 0x12, 0xeb, 0x0c, 0x0a, +0xf5, 0x0c, 0x20, 0x1b, 0x0d, 0x12, 0x2d, 0x0d, 0x0a, 0x37, 0x0d, 0x20, 0x5d, 0x0d, 0x12, 0x6f, +0x0d, 0x0a, 0x79, 0x0d, 0x20, 0x9f, 0x0d, 0x12, 0xb1, 0x0d, 0x0a, 0xbb, 0x0d, 0x20, 0xe1, 0x0d, +0x12, 0xf3, 0x0d, 0x0a, 0xfd, 0x0d, 0x20, 0x23, 0x0e, 0x12, 0x35, 0x0e, 0x0a, 0x3f, 0x0e, 0x20, +0x65, 0x0e, 0x12, 0x77, 0x0e, 0x0a, 0x81, 0x0e, 0x20, 0xa7, 0x0e, 0x12, 0xb9, 0x0e, 0x0a, 0xc3, +0x0e, 0x20, 0xe9, 0x0e, 0x12, 0xfb, 0x0e, 0x0a, 0x05, 0x0f, 0x20, 0x2b, 0x0f, 0x12, 0x3d, 0x0f, +0x0a, 0x47, 0x0f, 0x0d, 0x2a, 0xf0, 0x04, 0x80, 0x02, 0xe0, 0x01, 0x80, 0x11, 0x0e, 0x00, 0x00, +0x03, 0x00, 0x00, 0x08, 0x72, 0x0c, 0x00, 0xd0, 0x07, 0x58, 0x02, 0x0c, 0x72, 0x0c, 0x00, 0xd0, +0x07, 0xf4, 0x01, 0x10, 0x72, 0x0c, 0x00, 0x05, 0x0f, 0x27, 0x00, 0xff, 0xff, 0xd6, 0x09, 0x80, +0x90, 0x20, 0xe0, 0x1d, 0x10, 0x08, 0x60, 0x22, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1e, 0x36, +0x7f, 0x01, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x0c, 0x20, 0x03, 0x58, 0x02, 0x80, 0x11, 0x0e, +0x00, 0x00, 0x03, 0x00, 0x00, 0x08, 0x72, 0x0c, 0x00, 0xd0, 0x07, 0x58, 0x02, 0x0c, 0x72, 0x0c, +0x00, 0xd0, 0x07, 0xf4, 0x01, 0x10, 0x72, 0x0c, 0x00, 0x05, 0x0f, 0x27, 0x00, 0xff, 0xff, 0xa0, +0x0f, 0x20, 0x00, 0x31, 0x58, 0x1c, 0x20, 0x28, 0x80, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x1e, 0x36, 0x7f, 0x02, 0x00, 0x02, 0x00, 0x00, 0x00, 0x00, 0x0c, 0x40, 0x06, 0x84, 0x03, 0x80, +0x11, 0x0e, 0x00, 0x3c, 0x03, 0x30, 0x00, 0x08, 0x72, 0x0c, 0x00, 0xb8, 0x0b, 0x2c, 0x01, 0x0c, +0x72, 0x0c, 0x00, 0xb8, 0x0b, 0x2c, 0x01, 0x10, 0x72, 0x0c, 0x00, 0x06, 0x0f, 0x27, 0x00, 0xff, +0xff, 0x2f, 0x26, 0x40, 0xb8, 0x60, 0x84, 0x0c, 0x30, 0x30, 0x30, 0x23, 0x00, 0x7e, 0xd7, 0x10, +0x00, 0x00, 0x19, 0x30, 0xe4, 0x89, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x13, 0x00, 0x05, 0x00, +0x04, 0x80, 0x11, 0x0e, 0x00, 0x3c, 0x03, 0x00, 0x00, 0x08, 0x72, 0x0c, 0x00, 0xd0, 0x07, 0x58, +0x02, 0x0c, 0x72, 0x0c, 0x00, 0xd0, 0x07, 0xf4, 0x01, 0x10, 0x72, 0x0c, 0x00, 0x05, 0x0f, 0x27, +0x00, 0xff, 0xff, 0x30, 0x2a, 0x00, 0x98, 0x51, 0x00, 0x30, 0x40, 0x30, 0x70, 0x13, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x1e, 0x36, 0x7f, 0x05, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x0c, 0x78, +0x05, 0x1a, 0x04, 0x80, 0x11, 0x0e, 0x00, 0x3c, 0x03, 0x00, 0x00, 0x08, 0x72, 0x0c, 0x00, 0xd0, +0x07, 0x58, 0x02, 0x0c, 0x72, 0x0c, 0x00, 0xd0, 0x07, 0xf4, 0x01, 0x10, 0x72, 0x0c, 0x00, 0x05, +0x0f, 0x27, 0x00, 0xff, 0xff, 0x30, 0x2a, 0x78, 0x20, 0x51, 0x1a, 0x10, 0x40, 0x10, 0x70, 0x13, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1e, 0x36, 0x7f, 0x01, 0x90, 0x05, 0x00, 0x00, 0x00, 0x00, +0x0c, 0x78, 0x05, 0x1a, 0x04, 0x80, 0x11, 0x0e, 0x00, 0x3c, 0x03, 0x00, 0x00, 0x08, 0x72, 0x0c, +0x00, 0xd0, 0x07, 0x58, 0x02, 0x0c, 0x72, 0x0c, 0x00, 0xd0, 0x07, 0xf4, 0x01, 0x10, 0x72, 0x0c, +0x00, 0x05, 0x0f, 0x27, 0x00, 0xff, 0xff, 0xa8, 0x2f, 0x78, 0xe0, 0x51, 0x1a, 0x26, 0x40, 0x58, +0x98, 0x13, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1e, 0x36, 0x7f, 0x01, 0x90, 0x06, 0x00, 0x00, +0x00, 0x00, 0x0c, 0x40, 0x06, 0xb0, 0x04, 0x80, 0x11, 0x0e, 0x00, 0x3c, 0x03, 0x00, 0x00, 0x08, +0x72, 0x0c, 0x00, 0xd0, 0x07, 0x58, 0x02, 0x0c, 0x72, 0x0c, 0x00, 0xd0, 0x07, 0xf4, 0x01, 0x10, +0x72, 0x0c, 0x00, 0x05, 0x0f, 0x27, 0x00, 0xff, 0xff, 0x48, 0x3f, 0x40, 0x30, 0x62, 0xb0, 0x32, +0x40, 0x40, 0xc0, 0x13, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1e, 0x36, 0x7f, 0x06, 0x00, 0x07, +0x00, 0x00, 0x00, 0x00, 0x0c, 0x00, 0x05, 0x00, 0x03, 0x80, 0x11, 0x0e, 0x00, 0x00, 0x03, 0x00, +0x00, 0x08, 0x72, 0x0c, 0x00, 0xd0, 0x07, 0x58, 0x02, 0x0c, 0x72, 0x0c, 0x00, 0xd0, 0x07, 0xf4, +0x01, 0x10, 0x72, 0x0c, 0x00, 0x05, 0x0f, 0x27, 0x00, 0xff, 0xff, 0xa9, 0x1a, 0x00, 0xa0, 0x50, +0x00, 0x0a, 0x30, 0x30, 0x20, 0x2a, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1e, 0x36, 0x7f, 0x03, +0x90, 0x08, 0x00, 0x00, 0x00, 0x00, 0x01, 0x90, 0x06, 0x1a, 0x04, 0x80, 0x11, 0x0e, 0x00, 0x3c, +0x03, 0x00, 0x00, 0x08, 0x72, 0x0c, 0x00, 0xd0, 0x07, 0x58, 0x02, 0x0c, 0x72, 0x0c, 0x00, 0xd0, +0x07, 0xf4, 0x01, 0x10, 0x72, 0x0c, 0x00, 0x05, 0x0f, 0x27, 0x00, 0xff, 0xff, 0x7c, 0x2e, 0x90, +0xa0, 0x60, 0x1a, 0x1e, 0x40, 0x30, 0x20, 0x36, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1e, 0x36, +0x7f, 0x04, 0x90, 0x09, 0x00, 0x00, 0x00, 0x00, 0x0c, 0x80, 0x07, 0xb0, 0x04, 0x80, 0x11, 0x0e, +0x00, 0x3c, 0x03, 0x00, 0x00, 0x08, 0x72, 0x0c, 0x00, 0xd0, 0x07, 0x58, 0x02, 0x0c, 0x72, 0x0c, +0x00, 0xd0, 0x07, 0xf4, 0x01, 0x10, 0x72, 0x0c, 0x00, 0x05, 0x0f, 0x27, 0x00, 0xff, 0xff, 0x28, +0x3c, 0x80, 0xa0, 0x70, 0xb0, 0x23, 0x40, 0x30, 0x20, 0x2a, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, +0x1e, 0x36, 0x7f, 0x05, 0x90, 0x0a, 0x00, 0x00, 0x00, 0x00, 0x0c, 0x00, 0x04, 0x00, 0x03, 0x80, +0x11, 0x0e, 0x00, 0x00, 0x03, 0x00, 0x00, 0x08, 0x72, 0x0c, 0x00, 0xd0, 0x07, 0x58, 0x02, 0x0c, +0x72, 0x0c, 0x00, 0xd0, 0x07, 0xf4, 0x01, 0x10, 0x72, 0x0c, 0x00, 0x05, 0x0f, 0x27, 0x00, 0xff, +0xff, 0x64, 0x19, 0x00, 0x40, 0x41, 0x00, 0x26, 0x30, 0x18, 0x88, 0x36, 0x00, 0x00, 0x00, 0x00, +0x00, 0x00, 0x1e, 0x36, 0x7f, 0x03, 0x00, 0x0b, 0x00, 0x00, 0x00, 0x00, 0x0c, 0x00, 0x04, 0x00, +0x03, 0x80, 0x11, 0x0e, 0x00, 0x00, 0x03, 0x00, 0x00, 0x08, 0x72, 0x0c, 0x00, 0xd0, 0x07, 0x58, +0x02, 0x0c, 0x72, 0x0c, 0x00, 0xd0, 0x07, 0xf4, 0x01, 0x10, 0x72, 0x0c, 0x00, 0x05, 0x0f, 0x27, +0x00, 0xff, 0xff, 0x64, 0x19, 0x00, 0x40, 0x41, 0x00, 0x26, 0x30, 0x18, 0x88, 0x36, 0x00, 0x00, +0x00, 0x00, 0x00, 0x00, 0x1e, 0x36, 0x7f, 0x03, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x0c, 0x00, +0x04, 0x00, 0x03, 0x80, 0x11, 0x0e, 0x00, 0x00, 0x03, 0x00, 0x00, 0x08, 0x72, 0x0c, 0x00, 0xd0, +0x07, 0x58, 0x02, 0x0c, 0x72, 0x0c, 0x00, 0xd0, 0x07, 0xf4, 0x01, 0x10, 0x72, 0x0c, 0x00, 0x05, +0x0f, 0x27, 0x00, 0xff, 0xff, 0x64, 0x19, 0x00, 0x40, 0x41, 0x00, 0x26, 0x30, 0x18, 0x88, 0x36, +0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1e, 0x36, 0x7f, 0x03, 0x00, 0x0d, 0x00, 0x00, 0x00, 0x00, +0x0c, 0x00, 0x05, 0x20, 0x03, 0x80, 0x11, 0x0e, 0x00, 0x00, 0x03, 0x00, 0x00, 0x08, 0x72, 0x0c, +0x00, 0xd0, 0x07, 0x58, 0x02, 0x0c, 0x72, 0x0c, 0x00, 0xd0, 0x07, 0xf4, 0x01, 0x10, 0x72, 0x0c, +0x00, 0x05, 0x0f, 0x27, 0x00, 0xff, 0xff, 0xea, 0x1a, 0x00, 0xa0, 0x50, 0x20, 0x17, 0x30, 0x0c, +0x30, 0x43, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1e, 0x36, 0x7f, 0x03, 0x90, 0x0e, 0x00, 0x00, +0x00, 0x00, 0x0c, 0x00, 0x05, 0x58, 0x02, 0x80, 0x11, 0x0e, 0x00, 0x00, 0x03, 0x00, 0x00, 0x08, +0x72, 0x0c, 0x00, 0xd0, 0x07, 0x58, 0x02, 0x0c, 0x72, 0x0c, 0x00, 0xd0, 0x07, 0xf4, 0x01, 0x10, +0x72, 0x0c, 0x00, 0x05, 0x0f, 0x27, 0x00, 0xff, 0xff, 0x06, 0x18, 0x00, 0x70, 0x51, 0x58, 0x15, +0x20, 0x38, 0x80, 0x13, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1e, 0x36, 0x7f, 0x03, 0x00, 0x0f, +0x00, 0x00, 0x00, 0x00, 0x0c, 0x00, 0x08, 0x00, 0x06, 0x80, 0x11, 0x0e, 0x00, 0x3c, 0x03, 0x00, +0x00, 0x08, 0x72, 0x0c, 0x00, 0xd0, 0x07, 0x58, 0x02, 0x0c, 0x72, 0x0c, 0x00, 0xd0, 0x07, 0xf4, +0x01, 0x10, 0x72, 0x0c, 0x00, 0x05, 0x0f, 0x27, 0x00, 0xff, 0xff, 0x29, 0x40, 0x00, 0x60, 0x80, +0x00, 0x13, 0x60, 0x10, 0x10, 0x11, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1e, 0x36, 0x7f, 0x03, +0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x0c, 0x4c, 0x46, 0x50, 0x5f, 0x50, 0x61, 0x6e, 0x65, 0x6c, +0x4e, 0x61, 0x6d, 0x65, 0x4c, 0x46, 0x50, 0x5f, 0x50, 0x61, 0x6e, 0x65, 0x6c, 0x4e, 0x61, 0x6d, +0x65, 0x4c, 0x46, 0x50, 0x5f, 0x50, 0x61, 0x6e, 0x65, 0x6c, 0x4e, 0x61, 0x6d, 0x65, 0x4c, 0x46, +0x50, 0x5f, 0x50, 0x61, 0x6e, 0x65, 0x6c, 0x4e, 0x61, 0x6d, 0x65, 0x4c, 0x46, 0x50, 0x5f, 0x50, +0x61, 0x6e, 0x65, 0x6c, 0x4e, 0x61, 0x6d, 0x65, 0x4c, 0x46, 0x50, 0x5f, 0x50, 0x61, 0x6e, 0x65, +0x6c, 0x4e, 0x61, 0x6d, 0x65, 0x4c, 0x46, 0x50, 0x5f, 0x50, 0x61, 0x6e, 0x65, 0x6c, 0x4e, 0x61, +0x6d, 0x65, 0x4c, 0x46, 0x50, 0x5f, 0x50, 0x61, 0x6e, 0x65, 0x6c, 0x4e, 0x61, 0x6d, 0x65, 0x4c, +0x46, 0x50, 0x5f, 0x50, 0x61, 0x6e, 0x65, 0x6c, 0x4e, 0x61, 0x6d, 0x65, 0x4c, 0x46, 0x50, 0x5f, +0x50, 0x61, 0x6e, 0x65, 0x6c, 0x4e, 0x61, 0x6d, 0x65, 0x4c, 0x46, 0x50, 0x5f, 0x50, 0x61, 0x6e +}; diff --git a/src/mainboard/packardbell/ms2290/hda_verb.h b/src/mainboard/packardbell/ms2290/hda_verb.h new file mode 100644 index 0000000..1e3ccc4 --- /dev/null +++ b/src/mainboard/packardbell/ms2290/hda_verb.h @@ -0,0 +1,90 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2014 Vladimir Serbinenko. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of the License, + * or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +static const u32 mainboard_cim_verb_data[] = { + /* coreboot specific header */ + 0x10ec0272, /* Codec Vendor / Device ID: Realtek ALC272X */ + 0x10250379, /* Subsystem ID */ + 0x00000006, /* Number of 4 dword sets */ + + /* NID 0x01: Subsystem ID. */ + 0x00172079, + 0x00172103, + 0x00172225, + 0x00172310, + + /* NID 0x14. */ + 0x01471C10, + 0x01471D01, + 0x01471E13, + 0x01471F99, + + /* NID 0x18. */ + 0x01871C30, + 0x01871D18, + 0x01871EA1, + 0x01871F03, + + /* NID 0x19. */ + 0x01971C20, + 0x01971D09, + 0x01971EA3, + 0x01971F99, + + /* NID 0x1D. */ + 0x01D71C2D, + 0x01D71D99, + 0x01D71E17, + 0x01D71F40, + + /* NID 0x21. */ + 0x02171C1F, + 0x02171D10, + 0x02171E21, + 0x02171F03, + + 0x80862804, /* Codec Vendor / Device ID: Intel Ibexpeak HDMI. */ + 0x80860101, /* Subsystem ID */ + 0x00000004, /* Number of 4 dword sets */ + + /* NID 0x01, HDA Codec Subsystem ID Verb Table: 0x17aa21b5 */ + 0x30172001, + 0x30172101, + 0x30172286, + 0x30172380, + + /* NID 0x04. */ + 0x30471C10, + 0x30471D00, + 0x30471E56, + 0x30471F18, + + /* NID 0x05. */ + 0x30571C20, + 0x30571D00, + 0x30571E56, + 0x30571F58, + + /* NID 0x06. */ + 0x30671C30, + 0x30671D00, + 0x30671E56, + 0x30671F58, +}; diff --git a/src/mainboard/packardbell/ms2290/mainboard.c b/src/mainboard/packardbell/ms2290/mainboard.c new file mode 100644 index 0000000..86f7c90 --- /dev/null +++ b/src/mainboard/packardbell/ms2290/mainboard.c @@ -0,0 +1,178 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007-2009 coresystems GmbH + * Copyright (C) 2011 Sven Schnelle svens@stackframe.org + * Copyright (C) 2013 Vladimir Serbinenko phcoder@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of + * the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <console/console.h> +#include <device/device.h> +#include <arch/io.h> +#include <delay.h> +#include <device/pci_def.h> +#include <device/pci_ops.h> +#include <device/pci_ids.h> +#include <arch/io.h> +#include <northbridge/intel/nehalem/nehalem.h> +#include <southbridge/intel/bd82x6x/pch.h> +#include <ec/acpi/ec.h> + +#include <pc80/mc146818rtc.h> +#include "hda_verb.h" +#include <arch/x86/include/arch/acpigen.h> +#if CONFIG_PCI_OPTION_ROM_RUN_YABEL || CONFIG_PCI_OPTION_ROM_RUN_REALMODE +#include <x86emu/regs.h> +#include <arch/interrupt.h> +#endif +#include <pc80/keyboard.h> +#include <cpu/x86/lapic.h> +#include <device/pci.h> +#include <smbios.h> + +static acpi_cstate_t cst_entries[] = { + {1, 1, 1000, {0x7f, 1, 2, {0}, 1, 0}}, + {2, 1, 500, {0x01, 8, 0, {0}, DEFAULT_PMBASE + LV2, 0}}, + {2, 17, 250, {0x01, 8, 0, {0}, DEFAULT_PMBASE + LV3, 0}}, +}; + +int get_cst_entries(acpi_cstate_t ** entries) +{ + *entries = cst_entries; + return ARRAY_SIZE(cst_entries); +} + +#if CONFIG_PCI_OPTION_ROM_RUN_YABEL || CONFIG_PCI_OPTION_ROM_RUN_REALMODE + +static int int15_handler(void) +{ + switch ((X86_EAX & 0xffff)) { + /* Get boot display. */ + case 0x5f35: + X86_EAX = 0x5f; + /* The flags are: + 1 - VGA + 4 - DisplayPort + 8 - LCD + */ + X86_ECX = 0x8; + + return 1; + case 0x5f40: + X86_EAX = 0x5f; + X86_ECX = 0x2; + return 1; + default: + printk(BIOS_WARNING, "Unknown INT15 function %04x!\n", + X86_EAX & 0xffff); + return 0; + } +} +#endif + +/* Audio Setup */ + +extern const u32 *cim_verb_data; +extern u32 cim_verb_data_size; + +static void verb_setup(void) +{ + cim_verb_data = mainboard_cim_verb_data; + cim_verb_data_size = sizeof(mainboard_cim_verb_data); +} + +static void mainboard_enable(device_t dev) +{ + u16 pmbase; + + printk(BIOS_SPEW, "starting SPI configuration\n"); + + /* Configure SPI. */ + RCBA32(0x3800) = 0x07ff0500; + RCBA32(0x3804) = 0x3f046008; + RCBA32(0x3808) = 0x0058efc0; + RCBA32(0x384c) = 0x92000000; + RCBA32(0x3850) = 0x00000a0b; + RCBA32(0x3858) = 0x07ff0500; + RCBA32(0x385c) = 0x04ff0003; + RCBA32(0x3860) = 0x00020001; + RCBA32(0x3864) = 0x00000fff; + RCBA32(0x3874) = 0; + RCBA32(0x3890) = 0xf8400000; + RCBA32(0x3894) = 0x143b5006; + RCBA32(0x3898) = 0x05200302; + RCBA32(0x389c) = 0x0601209f; + RCBA32(0x38b0) = 0x00000004; + RCBA32(0x38b4) = 0x03040002; + RCBA32(0x38c0) = 0x00000007; + RCBA32(0x38c8) = 0x00002005; + RCBA32(0x38c4) = 0x00802005; + RCBA32(0x3804) = 0x3f04e008; + + printk(BIOS_SPEW, "SPI configured\n"); + + int i; + unsigned char dmp[256] = { + 0x00, 0x20, 0x00, 0x00, 0x00, 0x02, 0x89, 0xe4, 0x30, 0x00, 0x40, 0x14, 0x00, 0x00, 0x00, 0x11, + 0x03, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0a, 0x00, 0xf4, 0x01, 0x00, 0x00, 0x01, + 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x80, 0x80, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x19, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x62, 0x01, 0x04, 0x00, 0x08, 0x73, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, + 0x42, 0x07, 0x09, 0x09, 0xf0, 0x00, 0x00, 0xf0, 0xa9, 0x00, 0x00, 0x06, 0x00, 0x00, 0xff, 0x00, + 0x00, 0x01, 0x00, 0x04, 0xff, 0xff, 0x00, 0x00, 0x00, 0xb1, 0x00, 0x00, 0x00, 0x00, 0x04, 0x0b, + 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x28, 0x1b, 0x21, 0x00, 0x2c, 0x3b, 0x13, 0x00, + 0x80, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x19, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x55, 0x5a, 0x57, 0x5c, 0x00, 0x00, 0x00, 0x7e, 0x00, 0x00, 0x00, 0x00, 0x45, 0x00, 0x00, 0x00, + 0x52, 0x10, 0x52, 0x10, 0x64, 0x00, 0x00, 0x00, 0x74, 0x30, 0x00, 0x60, 0x00, 0x00, 0xaf, 0x0b, + 0x30, 0x45, 0x2e, 0x30, 0x38, 0x41, 0x43, 0x2e, 0x30, 0x31, 0x2e, 0x31, 0x36, 0x20, 0x00, 0x00, + }; + + for (i = 0; i < 256; i++) + ec_write (i, dmp[i]); + + pmbase = pci_read_config32(dev_find_slot(0, PCI_DEVFN(0x1f, 0)), + PMBASE) & 0xff80; + + printk(BIOS_SPEW, " ... pmbase = 0x%04x\n", pmbase); + + outl(0, pmbase + SMI_EN); + + enable_lapic(); + pci_write_config32(dev_find_slot(0, PCI_DEVFN(0x1f, 0)), GPIO_BASE, + DEFAULT_GPIOBASE | 1); + pci_write_config8(dev_find_slot(0, PCI_DEVFN(0x1f, 0)), GPIO_CNTL, + 0x10); + +#if CONFIG_PCI_OPTION_ROM_RUN_YABEL || CONFIG_PCI_OPTION_ROM_RUN_REALMODE + /* Install custom int15 handler for VGA OPROM */ + mainboard_interrupt_handlers(0x15, &int15_handler); +#endif + + /* This sneaked in here, because EasyNote has no SuperIO chip. + */ + pc_keyboard_init(0); + verb_setup(); +} + +struct chip_operations mainboard_ops = { + .enable_dev = mainboard_enable, +}; diff --git a/src/mainboard/packardbell/ms2290/romstage.c b/src/mainboard/packardbell/ms2290/romstage.c new file mode 100644 index 0000000..6a18dd6 --- /dev/null +++ b/src/mainboard/packardbell/ms2290/romstage.c @@ -0,0 +1,333 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007-2009 coresystems GmbH + * Copyright (C) 2011 Sven Schnelle svens@stackframe.org + * Copyright (C) 2013 Vladimir Serbinenko phcoder@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of + * the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +/* __PRE_RAM__ means: use "unsigned" for device, not a struct. */ + +#include <stdint.h> +#include <string.h> +#include <arch/io.h> +#include <device/pci_def.h> +#include <device/pnp_def.h> +#include <cpu/x86/lapic.h> +#include <lib.h> +#include <pc80/mc146818rtc.h> +#include <console/console.h> +#include <cpu/x86/bist.h> +#include <ec/acpi/ec.h> +#include <delay.h> +#include <timestamp.h> +#include <cbmem.h> + +#include "arch/early_variables.h" +#include "southbridge/intel/ibexpeak/pch.h" +#include "northbridge/intel/nehalem/nehalem.h" + +#include "northbridge/intel/nehalem/raminit.h" +#include "southbridge/intel/ibexpeak/me.h" + +static void pch_enable_lpc(void) +{ + /* Enable EC, PS/2 Keyboard/Mouse */ + pci_write_config16(PCH_LPC_DEV, LPC_EN, + CNF2_LPC_EN | CNF1_LPC_EN | MC_LPC_EN | KBC_LPC_EN | + COMA_LPC_EN); + + pci_write_config32(PCH_LPC_DEV, LPC_GEN1_DEC, (0x68 & ~3) | 0x00040001); + + pci_write_config16(PCH_LPC_DEV, LPC_IO_DEC, 0x10); + + pci_write_config32(PCH_LPC_DEV, 0xd0, 0x0); + pci_write_config32(PCH_LPC_DEV, 0xdc, 0x8); + + pci_write_config8(PCH_LPC_DEV, GEN_PMCON_3, + (pci_read_config8(PCH_LPC_DEV, GEN_PMCON_3) & ~2) | 1); + + pci_write_config32(PCH_LPC_DEV, ETR3, + pci_read_config32(PCH_LPC_DEV, ETR3) & ~ETR3_CF9GR); +} + +static void rcba_config(void) +{ + static const u32 rcba_dump3[] = { + /* 30fc */ 0x00000000, + /* 3100 */ 0x04341200, 0x00000000, 0x40043214, 0x00014321, + /* 3110 */ 0x00000002, 0x30003214, 0x00000001, 0x00000002, + /* 3120 */ 0x00000000, 0x00002321, 0x00000000, 0x00000000, + /* 3130 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3140 */ 0x00003107, 0x76543210, 0x00000010, 0x00007654, + /* 3150 */ 0x00000004, 0x00000000, 0x00000000, 0x00003210, + /* 3160 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3170 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3180 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3190 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 31a0 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 31b0 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 31c0 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 31d0 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 31e0 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 31f0 */ 0x00000000, 0x00000000, 0x00000000, 0x03000000, + /* 3200 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3210 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3220 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3230 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3240 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3250 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3260 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3270 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3280 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3290 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 32a0 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 32b0 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 32c0 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 32d0 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 32e0 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 32f0 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3300 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3310 */ 0x02060100, 0x0000000f, 0x01020000, 0x80000000, + /* 3320 */ 0x00000000, 0x04000000, 0x00000000, 0x00000000, + /* 3330 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3340 */ 0x000fffff, 0x00000000, 0x00000000, 0x00000000, + /* 3350 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3360 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3370 */ 0x00000000, 0x00000000, 0x7f8fdfff, 0x00000000, + /* 3380 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3390 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 33a0 */ 0x00003900, 0x00000000, 0x00000000, 0x00000000, + /* 33b0 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 33c0 */ 0x00010000, 0x00000000, 0x00000000, 0x0001004b, + /* 33d0 */ 0x06000008, 0x00010000, 0x00000000, 0x00000000, + /* 33e0 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 33f0 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3400 */ 0x0000001c, 0x00000080, 0x00000000, 0x00000000, + /* 3410 */ 0x00000c61, 0x00000000, 0x16fc1fe1, 0xbf4f001f, + /* 3420 */ 0x00000000, 0x00060010, 0x0000001d, 0x00000000, + /* 3430 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3440 */ 0xdeaddeed, 0x00000000, 0x00000000, 0x00000000, + /* 3450 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3460 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3470 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3480 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3490 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 34a0 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 34b0 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 34c0 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 34d0 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 34e0 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 34f0 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3500 */ 0x20000557, 0x2000055f, 0x2000074b, 0x2000074b, + /* 3510 */ 0x20000557, 0x2000014b, 0x2000074b, 0x2000074b, + /* 3520 */ 0x2000074b, 0x2000074b, 0x2000055f, 0x2000055f, + /* 3530 */ 0x20000557, 0x2000055f, 0x00000000, 0x00000000, + /* 3540 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3550 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3560 */ 0x00000001, 0x000026a3, 0x00040002, 0x01000052, + /* 3570 */ 0x02000772, 0x16000f8f, 0x1800ff4f, 0x0001d630, + /* 3580 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3590 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 35a0 */ 0xfc000201, 0x3c000201, 0x00000000, 0x00000000, + /* 35b0 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 35c0 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 35d0 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 35e0 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 35f0 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3600 */ 0x0a001f00, 0x00000000, 0x00000000, 0x00000001, + /* 3610 */ 0x00010000, 0x00000000, 0x00000000, 0x00000000, + /* 3600 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3610 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3620 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3630 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3640 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3650 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3660 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3670 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3680 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3690 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 36a0 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 36b0 */ 0x00000000, 0x089c0018, 0x00000000, 0x00000000, + /* 36c0 */ 0x11111111, 0x00000000, 0x00000000, 0x00000000, + /* 36d0 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 36e0 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 36f0 */ 0x00000000, 0x00000000, 0x00000000, 0x00000000, + /* 3710 */ 0x00000000, 0x4e564d49, 0x00000000, 0x00000000, + }; + unsigned i; + for (i = 0; i < sizeof(rcba_dump3) / 4; i++) { + RCBA32(4 * i + 0x30fc) = rcba_dump3[i]; + (void)RCBA32(4 * i + 0x30fc); + } +} + +static inline void write_acpi32(u32 addr, u32 val) +{ + outl(val, DEFAULT_PMBASE | addr); +} + +static inline void write_acpi16(u32 addr, u16 val) +{ + outw(val, DEFAULT_PMBASE | addr); +} + +static inline u32 read_acpi32(u32 addr) +{ + return inl(DEFAULT_PMBASE | addr); +} + +static inline u16 read_acpi16(u32 addr) +{ + return inw(DEFAULT_PMBASE | addr); +} + +void main(unsigned long bist) +{ + u32 reg32; + int s3resume = 0; + const u8 spd_addrmap[4] = { 0x50, 0, 0x52, 0 }; + + timestamp_init(rdtsc ()); + + /* SERR pin is confused on reset. Clear NMI. */ + outb(4, 0x61); + outb(0, 0x61); + + timestamp_add_now(TS_START_ROMSTAGE); + + if (bist == 0) + enable_lapic(); + + nehalem_early_initialization(NEHALEM_MOBILE); + + pch_enable_lpc(); + + /* Enable GPIOs */ + pci_write_config32(PCH_LPC_DEV, GPIO_BASE, DEFAULT_GPIOBASE | 1); + pci_write_config8(PCH_LPC_DEV, GPIO_CNTL, 0x10); + outl (0x796bd9c3, DEFAULT_GPIOBASE); + outl (0x86fec7c2, DEFAULT_GPIOBASE + 4); + outl (0xe4e8d7fe, DEFAULT_GPIOBASE + 0xc); + outl (0, DEFAULT_GPIOBASE + 0x18); + outl (0x00004182, DEFAULT_GPIOBASE + 0x2c); + outl (0x123360f8, DEFAULT_GPIOBASE + 0x30); + outl (0x1f47bfa8, DEFAULT_GPIOBASE + 0x34); + outl (0xfffe7fb6, DEFAULT_GPIOBASE + 0x38); + + + /* This should probably go away. Until now it is required + * and mainboard specific + */ + rcba_config(); + + console_init(); + + /* Halt if there was a built in self test failure */ + report_bist_failure(bist); + + /* Read PM1_CNT */ + reg32 = inl(DEFAULT_PMBASE + 0x04); + printk(BIOS_DEBUG, "PM1_CNT: %08x\n", reg32); + if (((reg32 >> 10) & 7) == 5) { + u8 reg8; + reg8 = pci_read_config8(PCI_DEV(0, 0x1f, 0), 0xa2); + printk(BIOS_DEBUG, "a2: %02x\n", reg8); + if (!(reg8 & 0x20)) { + outl(reg32 & ~(7 << 10), DEFAULT_PMBASE + 0x04); + printk(BIOS_DEBUG, "Bad resume from S3 detected.\n"); + } else { + printk(BIOS_DEBUG, "Resume from S3 detected.\n"); + s3resume = 1; + } + } + + /* Enable SMBUS. */ + enable_smbus(); + + write_acpi16(0x2, 0x0); + write_acpi32(0x28, 0x0); + write_acpi32(0x2c, 0x0); + if (!s3resume) { + read_acpi32(0x4); + read_acpi32(0x20); + read_acpi32(0x34); + write_acpi16(0x0, 0x900); + write_acpi32(0x20, 0xffff7ffe); + write_acpi32(0x34, 0x56974); + pci_write_config8(PCH_LPC_DEV, GEN_PMCON_3, + pci_read_config8(PCH_LPC_DEV, GEN_PMCON_3) | 2); + } + + early_thermal_init(); + + timestamp_add_now(TS_BEFORE_INITRAM); + + chipset_init(s3resume); + raminit(s3resume, spd_addrmap); + + timestamp_add_now(TS_AFTER_INITRAM); + + intel_early_me_status(); + + if (s3resume) { + /* Clear SLP_TYPE. This will break stage2 but + * we care for that when we get there. + */ + reg32 = inl(DEFAULT_PMBASE + 0x04); + outl(reg32 & ~(7 << 10), DEFAULT_PMBASE + 0x04); + } + +#if CONFIG_HAVE_ACPI_RESUME + /* If there is no high memory area, we didn't boot before, so + * this is not a resume. In that case we just create the cbmem toc. + */ + if (s3resume) { + void *resume_backup_memory; + + /* For non-S3-resume, CBMEM is inited in raminit code. */ + if (cbmem_recovery(1)) { + printk(BIOS_ERR, "Failed S3 resume.\n"); + ram_check(0x100000, 0x200000); + + /* Failed S3 resume, reset to come up cleanly */ + outb(0xe, 0xcf9); + hlt(); + } + + resume_backup_memory = cbmem_find(CBMEM_ID_RESUME); + + /* copy 1MB - 64K to high tables ram_base to prevent memory corruption + * through stage 2. We could keep stuff like stack and heap in high tables + * memory completely, but that's a wonderful clean up task for another + * day. + */ + if (resume_backup_memory) + memcpy(resume_backup_memory, (void *)CONFIG_RAMBASE, + HIGH_MEMORY_SAVE); + + /* Magic for S3 resume */ + pci_write_config32(PCI_DEV(0, 0x00, 0), SKPAD, 0xcafed00d); + } else { + pci_write_config32(PCI_DEV(0, 0x00, 0), SKPAD, 0xcafebabe); + quick_ram_check(); + } +#endif + + timestamp_add_now(TS_END_ROMSTAGE); +} diff --git a/src/mainboard/packardbell/ms2290/smi.h b/src/mainboard/packardbell/ms2290/smi.h new file mode 100644 index 0000000..e69de29 diff --git a/src/mainboard/packardbell/ms2290/smihandler.c b/src/mainboard/packardbell/ms2290/smihandler.c new file mode 100644 index 0000000..5051efd --- /dev/null +++ b/src/mainboard/packardbell/ms2290/smihandler.c @@ -0,0 +1,113 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2008-2009 coresystems GmbH + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of + * the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <arch/io.h> +#include <console/console.h> +#include <cpu/x86/smm.h> +#include "southbridge/intel/ibexpeak/nvs.h" +#include "southbridge/intel/ibexpeak/pch.h" +#include "southbridge/intel/ibexpeak/me.h" +#include <northbridge/intel/sandybridge/sandybridge.h> +#include <cpu/intel/model_2065x/model_2065x.h> +#include <ec/acpi/ec.h> +#include <pc80/mc146818rtc.h> +#include <delay.h> +#include "smi.h" + +/* The southbridge SMI handler checks whether gnvs has a + * valid pointer before calling the trap handler + */ +extern global_nvs_t *gnvs; + +static void mainboard_smm_init(void) +{ + printk(BIOS_DEBUG, "initializing SMI\n"); +} + +int mainboard_io_trap_handler(int smif) +{ + static int smm_initialized; + + if (!smm_initialized) { + mainboard_smm_init(); + smm_initialized = 1; + } + + switch (smif) { + + default: + return 0; + } + + /* On success, the IO Trap Handler returns 1 + * On failure, the IO Trap Handler returns a value != 1 */ + return 1; +} + +void mainboard_smi_gpi(u32 gpi_sts) +{ +} + +static int mainboard_finalized = 0; + +int mainboard_smi_apmc(u8 data) +{ + u16 pmbase = pci_read_config16(PCI_DEV(0, 0x1f, 0), 0x40) & 0xfffc; + u8 tmp; + + printk(BIOS_DEBUG, "%s: pmbase %04X, data %02X\n", __func__, pmbase, + data); + + if (!pmbase) + return 0; + + switch (data) { + case APM_CNT_FINALIZE: + printk(BIOS_DEBUG, "APMC: FINALIZE\n"); + if (mainboard_finalized) { + printk(BIOS_DEBUG, "APMC#: Already finalized\n"); + return 0; + } + + intel_me_finalize_smm(); + intel_pch_finalize_smm(); + intel_sandybridge_finalize_smm(); + intel_model_2065x_finalize_smm(); + + mainboard_finalized = 1; + break; + case APM_CNT_ACPI_ENABLE: + tmp = pci_read_config8(PCI_DEV(0, 0x1f, 0), 0xbb); + tmp &= ~0x03; + tmp |= 0x02; + pci_write_config8(PCI_DEV(0, 0x1f, 0), 0xbb, tmp); + break; + case APM_CNT_ACPI_DISABLE: + tmp = pci_read_config8(PCI_DEV(0, 0x1f, 0), 0xbb); + tmp &= ~0x03; + tmp |= 0x01; + pci_write_config8(PCI_DEV(0, 0x1f, 0), 0xbb, tmp); + break; + default: + break; + } + return 0; +}
