Aaron Durbin (adurbin@chromium.org) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/10151
commit 3aca557cb59241f962ccb3b3d52e419568b353be Author: Aaron Durbin adurbin@chromium.org Date: Fri May 8 15:54:31 2015 -0500
chromeos: add missing vboot functions
Somewhere along the development path the following vboot functions were dropped: int vboot_enable_developer(void) int vboot_enable_recovery(void)
Add them back, but also refactor the flag extraction so as not duplicate all that same logic.
Change-Id: Id58f3b99f29caeff98b2d3111cfa28241d15b54f Signed-off-by: Aaron Durbin adurbin@chromium.org --- src/vendorcode/google/chromeos/chromeos.c | 19 +++++++++++++++++-- 1 file changed, 17 insertions(+), 2 deletions(-)
diff --git a/src/vendorcode/google/chromeos/chromeos.c b/src/vendorcode/google/chromeos/chromeos.c index fb72673..1e49bd1 100644 --- a/src/vendorcode/google/chromeos/chromeos.c +++ b/src/vendorcode/google/chromeos/chromeos.c @@ -26,7 +26,7 @@ #include <console/console.h> #include "vboot_handoff.h"
-int vboot_skip_display_init(void) +static int vboot_handoff_flag(uint32_t flag) { struct vboot_handoff *vbho;
@@ -35,7 +35,22 @@ int vboot_skip_display_init(void) if (vbho == NULL) return 0;
- return !(vbho->init_params.out_flags & VB_INIT_OUT_ENABLE_DISPLAY); + return !!(vbho->init_params.out_flags & flag); +} + +int vboot_skip_display_init(void) +{ + return !vboot_handoff_flag(VB_INIT_OUT_ENABLE_DISPLAY); +} + +int vboot_enable_developer(void) +{ + return vboot_handoff_flag(VB_INIT_OUT_ENABLE_DEVELOPER); +} + +int vboot_enable_recovery(void) +{ + return vboot_handoff_flag(VB_INIT_OUT_ENABLE_RECOVERY); }
int __attribute__((weak)) clear_recovery_mode_switch(void)
