Felix Held has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/42783 )
Change subject: mb/amd/mandolin/devicetree: add comment about chip behind GPP bridge 3 ......................................................................
Change-Id: Ie1fcfb18a3ccf08c62210eec07d8965696f11da9 Signed-off-by: Felix Held felix-coreboot@felixheld.de --- M src/mainboard/amd/mandolin/devicetree.cb 1 file changed, 1 insertion(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/83/42783/1
diff --git a/src/mainboard/amd/mandolin/devicetree.cb b/src/mainboard/amd/mandolin/devicetree.cb index d94084c..709778d 100644 --- a/src/mainboard/amd/mandolin/devicetree.cb +++ b/src/mainboard/amd/mandolin/devicetree.cb @@ -45,7 +45,7 @@ device pci 0.0 on end # Root Complex device pci 0.2 on end # IOMMU device pci 1.0 on end # Dummy Host Bridge - device pci 1.3 on end # Bridge + device pci 1.3 on end # Bridge to PCIe Ethernet chip device pci 8.0 on end # Dummy Host Bridge device pci 8.1 on # Bridge to Bus A device pci 0.0 on end # Internal GPU
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/42783 )
Patch Set 1: Code-Review+2
Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/42783 )
Change-Id: Ie1fcfb18a3ccf08c62210eec07d8965696f11da9 Signed-off-by: Felix Held felix-coreboot@felixheld.de Reviewed-on: https://review.coreboot.org/c/coreboot/+/42783 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Angel Pons th3fanbus@gmail.com --- M src/mainboard/amd/mandolin/devicetree.cb 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/src/mainboard/amd/mandolin/devicetree.cb b/src/mainboard/amd/mandolin/devicetree.cb index 179582b..0167048 100644 --- a/src/mainboard/amd/mandolin/devicetree.cb +++ b/src/mainboard/amd/mandolin/devicetree.cb @@ -45,7 +45,7 @@ device pci 0.0 on end # Root Complex device pci 0.2 on end # IOMMU device pci 1.0 on end # Dummy Host Bridge - device pci 1.3 on end # Bridge + device pci 1.3 on end # Bridge to PCIe Ethernet chip device pci 8.0 on end # Dummy Host Bridge device pci 8.1 on # Bridge to Bus A device pci 0.0 on end # Internal GPU
