Felix Held has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/61776 )
Change subject: Revert "cpu/x86/lapic: Unconditionally use CPUID leaf 0xb if available"
Patch Set 2:
Commit Message:
https://review.coreboot.org/c/coreboot/+/61776/comment/8a7ef137_aaadd791
PS1, Line 16: valid APIC ID.
!cpu_is_amd() wouldn't be the right check there, since cezanne does support x2apic and cpuid_ext(0xb […]
the picasso/rv1 ppr #55570 Rev 3.16 which i looked at when reviewing the original patch has the lower byte of cpuid_ext(0xb, 0).edx defined as APIC ID:
CPUID_Fn0000000B_EDX [Extended Topology Enumeration] (Core::X86::Cpuid::ExtTopEnumEdx)
Bits 7:0: ApicId: APIC ID. Read-only. Reset: XXh. APIC ID.
in revision 3.14 of the same document the whole CPUID_Fn0000000B_EDX is however defined as reserved.
To view, visit
Gerrit-Project: coreboot
Gerrit-Branch: master
Gerrit-Change-Id: If1e3c55ce2d048b14c08e06bb79810179a87993d
Gerrit-Change-Number: 61776
Gerrit-PatchSet: 2
Gerrit-Owner: Felix Held
felix-coreboot@felixheld.de
Gerrit-Reviewer: Angel Pons
th3fanbus@gmail.com
Gerrit-Reviewer: Arthur Heymans
arthur@aheymans.xyz
Gerrit-Reviewer: Christian Walter
christian.walter@9elements.com
Gerrit-Reviewer: Kyösti Mälkki
kyosti.malkki@gmail.com
Gerrit-Reviewer: Raul Rangel
rrangel@chromium.org
Gerrit-Reviewer: Tim Wawrzynczak
twawrzynczak@chromium.org
Gerrit-Reviewer: Wonkyu Kim
wonkyu.kim@intel.com
no-reply@coreboot.org
Gerrit-CC: 9elements QA
hardwaretestrobot@gmail.com
Gerrit-Comment-Date: Thu, 10 Feb 2022 13:20:50 +0000
Gerrit-HasComments: Yes
Gerrit-Has-Labels: No
Comment-In-Reply-To: Kyösti Mälkki
Comment-In-Reply-To: Felix Held
Gerrit-MessageType: comment
