Attention is currently required from: Stefan Ott, Angel Pons, Alexander Couzens.
Arthur Heymans has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/69297 )
Change subject: cpu/intel/speedstep: Have nb and sb code provide c5/c6/slfm ......................................................................
C5, C6 and slfm depend on the southbridge and the northbridge to be able to provide this functionality, with some just lacking the possibility to do so. Move the devicetree configuration to the southbridge.
This removes the need for a magic lapic in the devicetree.
Change-Id: I4a9b1e684a7927259adae9b1d42a67e907722109 Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- D src/cpu/intel/model_1067x/chip.h M src/cpu/intel/model_1067x/model_1067x_init.c M src/include/cpu/intel/speedstep.h M src/mainboard/acer/g43t-am3/devicetree.cb M src/mainboard/asrock/g41c-gs/variants/g41c-gs-r2/devicetree.cb M src/mainboard/asrock/g41c-gs/variants/g41c-gs/devicetree.cb M src/mainboard/asrock/g41c-gs/variants/g41m-gs/devicetree.cb M src/mainboard/asrock/g41c-gs/variants/g41m-s3/devicetree.cb M src/mainboard/asrock/g41c-gs/variants/g41m-vs3-r2/devicetree.cb M src/mainboard/asus/p5gc-mx/devicetree.cb M src/mainboard/asus/p5qc/variants/p5q/devicetree.cb M src/mainboard/asus/p5qc/variants/p5q_pro/devicetree.cb M src/mainboard/asus/p5qc/variants/p5q_se/devicetree.cb M src/mainboard/asus/p5qc/variants/p5qc/devicetree.cb M src/mainboard/asus/p5qc/variants/p5ql_pro/devicetree.cb M src/mainboard/asus/p5ql-em/devicetree.cb M src/mainboard/asus/p5qpl-am/devicetree.cb M src/mainboard/foxconn/g41s-k/devicetree.cb M src/mainboard/gigabyte/ga-945gcm-s2l/devicetree.cb M src/mainboard/gigabyte/ga-g41m-es2l/devicetree.cb M src/mainboard/intel/dg41wv/devicetree.cb M src/mainboard/intel/dg43gt/devicetree.cb M src/mainboard/lenovo/t400/devicetree.cb M src/mainboard/lenovo/thinkcentre_a58/devicetree.cb M src/mainboard/lenovo/x200/devicetree.cb M src/mainboard/roda/rk9/devicetree.cb M src/northbridge/intel/gm45/chip.h M src/northbridge/intel/gm45/northbridge.c M src/northbridge/intel/i945/northbridge.c M src/northbridge/intel/x4x/northbridge.c M src/southbridge/intel/i82801gx/lpc.c M src/southbridge/intel/i82801ix/lpc.c M src/southbridge/intel/i82801jx/lpc.c 33 files changed, 97 insertions(+), 122 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/97/69297/1
diff --git a/src/cpu/intel/model_1067x/chip.h b/src/cpu/intel/model_1067x/chip.h deleted file mode 100644 index b298615..0000000 --- a/src/cpu/intel/model_1067x/chip.h +++ /dev/null @@ -1,7 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ - -struct cpu_intel_model_1067x_config { - int c5 : 1; - int c6 : 1; - int slfm : 1; -}; diff --git a/src/cpu/intel/model_1067x/model_1067x_init.c b/src/cpu/intel/model_1067x/model_1067x_init.c index 02e6032..c4afccd 100644 --- a/src/cpu/intel/model_1067x/model_1067x_init.c +++ b/src/cpu/intel/model_1067x/model_1067x_init.c @@ -17,17 +17,12 @@ { msr_t msr;
- /* Find pointer to CPU configuration. */ - const struct device *lapic = dev_find_lapic(SPEEDSTEP_APIC_MAGIC); - const struct cpu_intel_model_1067x_config *const conf = - (lapic && lapic->chip_info) ? lapic->chip_info : NULL; - /* Is C5 requested and supported? */ - const int c5 = conf && conf->c5 && + const int c5 = southbridge_support_c5() && (rdmsr(MSR_BBL_CR_CTL3).lo & (3 << 30)) && !(rdmsr(MSR_FSB_FREQ).lo & (1 << 31)); /* Is C6 requested and supported? */ - const int c6 = conf && conf->c6 && + const int c6 = southbridge_support_c6() && ((cpuid_edx(5) >> (6 * 4)) & 0xf) && c5;
const int cst_range = (c6 ? 6 : (c5 ? 5 : 4)) - 2; /* zero means lvl2 */ @@ -75,14 +70,9 @@ { msr_t msr;
- /* Find pointer to CPU configuration. */ - const struct device *lapic = dev_find_lapic(SPEEDSTEP_APIC_MAGIC); - struct cpu_intel_model_1067x_config *const conf = - (lapic && lapic->chip_info) ? lapic->chip_info : NULL; - msr = rdmsr(MSR_EXTENDED_CONFIG); /* Super LFM supported? */ - if (conf && conf->slfm && (msr.lo & (1 << 27))) + if (northbridge_support_slfm() && (msr.lo & (1 << 27))) msr.lo |= (1 << 28); /* Enable Super LFM. */ wrmsr(MSR_EXTENDED_CONFIG, msr);
diff --git a/src/include/cpu/intel/speedstep.h b/src/include/cpu/intel/speedstep.h index e085e34..1a31c25 100644 --- a/src/include/cpu/intel/speedstep.h +++ b/src/include/cpu/intel/speedstep.h @@ -3,11 +3,9 @@ #ifndef CPU_INTEL_SPEEDSTEP_H #define CPU_INTEL_SPEEDSTEP_H
+#include <stdbool.h> #include <stdint.h>
-/* Magic value used to locate speedstep configuration in the device tree */ -#define SPEEDSTEP_APIC_MAGIC 0xACAC - /* MWAIT coordination I/O base address. This must match * the _PR_.CP00 PM base address. */ @@ -92,4 +90,8 @@ #define SPEEDSTEP_MIN_POWER_PENRYN 15000 #define SPEEDSTEP_SLFM_POWER_PENRYN 12000
+bool southbridge_support_c5(void); +bool southbridge_support_c6(void); +bool northbridge_support_slfm(void); + #endif /* CPU_INTEL_SPEEDSTEP_H */ diff --git a/src/mainboard/acer/g43t-am3/devicetree.cb b/src/mainboard/acer/g43t-am3/devicetree.cb index 713ac40..1f2bc08 100644 --- a/src/mainboard/acer/g43t-am3/devicetree.cb +++ b/src/mainboard/acer/g43t-am3/devicetree.cb @@ -6,9 +6,6 @@ chip cpu/intel/socket_LGA775 device lapic 0 on end end - chip cpu/intel/model_1067x # CPU - device lapic 0xacac off end - end end device domain 0 on ops x4x_pci_domain_ops # PCI domain diff --git a/src/mainboard/asrock/g41c-gs/variants/g41c-gs-r2/devicetree.cb b/src/mainboard/asrock/g41c-gs/variants/g41c-gs-r2/devicetree.cb index 5d10628..385ba03 100644 --- a/src/mainboard/asrock/g41c-gs/variants/g41c-gs-r2/devicetree.cb +++ b/src/mainboard/asrock/g41c-gs/variants/g41c-gs-r2/devicetree.cb @@ -6,9 +6,6 @@ chip cpu/intel/socket_LGA775 device lapic 0 on end end - chip cpu/intel/model_1067x # CPU - device lapic 0xACAC off end - end end device domain 0 on ops x4x_pci_domain_ops # PCI domain diff --git a/src/mainboard/asrock/g41c-gs/variants/g41c-gs/devicetree.cb b/src/mainboard/asrock/g41c-gs/variants/g41c-gs/devicetree.cb index d0759e2..6749b1a 100644 --- a/src/mainboard/asrock/g41c-gs/variants/g41c-gs/devicetree.cb +++ b/src/mainboard/asrock/g41c-gs/variants/g41c-gs/devicetree.cb @@ -6,9 +6,6 @@ chip cpu/intel/socket_LGA775 device lapic 0 on end end - chip cpu/intel/model_1067x # CPU - device lapic 0xACAC off end - end end device domain 0 on ops x4x_pci_domain_ops # PCI domain diff --git a/src/mainboard/asrock/g41c-gs/variants/g41m-gs/devicetree.cb b/src/mainboard/asrock/g41c-gs/variants/g41m-gs/devicetree.cb index 818ceaa..8aaee07 100644 --- a/src/mainboard/asrock/g41c-gs/variants/g41m-gs/devicetree.cb +++ b/src/mainboard/asrock/g41c-gs/variants/g41m-gs/devicetree.cb @@ -6,9 +6,6 @@ chip cpu/intel/socket_LGA775 device lapic 0 on end end - chip cpu/intel/model_1067x # CPU - device lapic 0xACAC off end - end end device domain 0 on ops x4x_pci_domain_ops # PCI domain diff --git a/src/mainboard/asrock/g41c-gs/variants/g41m-s3/devicetree.cb b/src/mainboard/asrock/g41c-gs/variants/g41m-s3/devicetree.cb index 9f4142b..9bb107b 100644 --- a/src/mainboard/asrock/g41c-gs/variants/g41m-s3/devicetree.cb +++ b/src/mainboard/asrock/g41c-gs/variants/g41m-s3/devicetree.cb @@ -6,9 +6,6 @@ chip cpu/intel/socket_LGA775 device lapic 0 on end end - chip cpu/intel/model_1067x # CPU - device lapic 0xACAC off end - end end device domain 0 on ops x4x_pci_domain_ops # PCI domain diff --git a/src/mainboard/asrock/g41c-gs/variants/g41m-vs3-r2/devicetree.cb b/src/mainboard/asrock/g41c-gs/variants/g41m-vs3-r2/devicetree.cb index e0df76b..9017361 100644 --- a/src/mainboard/asrock/g41c-gs/variants/g41m-vs3-r2/devicetree.cb +++ b/src/mainboard/asrock/g41c-gs/variants/g41m-vs3-r2/devicetree.cb @@ -6,9 +6,6 @@ chip cpu/intel/socket_LGA775 device lapic 0 on end end - chip cpu/intel/model_1067x # CPU - device lapic 0xACAC off end - end end device domain 0 on ops x4x_pci_domain_ops # PCI domain diff --git a/src/mainboard/asus/p5gc-mx/devicetree.cb b/src/mainboard/asus/p5gc-mx/devicetree.cb index ad9b961..5837a70 100644 --- a/src/mainboard/asus/p5gc-mx/devicetree.cb +++ b/src/mainboard/asus/p5gc-mx/devicetree.cb @@ -7,9 +7,6 @@ chip cpu/intel/socket_LGA775 device lapic 0 on end end - chip cpu/intel/model_1067x - device lapic 0xACAC off end - end end
device domain 0 on diff --git a/src/mainboard/asus/p5qc/variants/p5q/devicetree.cb b/src/mainboard/asus/p5qc/variants/p5q/devicetree.cb index c452672..d7d4655 100644 --- a/src/mainboard/asus/p5qc/variants/p5q/devicetree.cb +++ b/src/mainboard/asus/p5qc/variants/p5q/devicetree.cb @@ -6,9 +6,6 @@ chip cpu/intel/socket_LGA775 device lapic 0 on end end - chip cpu/intel/model_1067x # CPU - device lapic 0xACAC off end - end end device domain 0 on ops x4x_pci_domain_ops # PCI domain diff --git a/src/mainboard/asus/p5qc/variants/p5q_pro/devicetree.cb b/src/mainboard/asus/p5qc/variants/p5q_pro/devicetree.cb index b0452d4..d6dbc2d 100644 --- a/src/mainboard/asus/p5qc/variants/p5q_pro/devicetree.cb +++ b/src/mainboard/asus/p5qc/variants/p5q_pro/devicetree.cb @@ -6,9 +6,6 @@ chip cpu/intel/socket_LGA775 device lapic 0 on end end - chip cpu/intel/model_1067x # CPU - device lapic 0xacac off end - end end device domain 0 on ops x4x_pci_domain_ops # PCI domain diff --git a/src/mainboard/asus/p5qc/variants/p5q_se/devicetree.cb b/src/mainboard/asus/p5qc/variants/p5q_se/devicetree.cb index 8390bc0..f099ab2 100644 --- a/src/mainboard/asus/p5qc/variants/p5q_se/devicetree.cb +++ b/src/mainboard/asus/p5qc/variants/p5q_se/devicetree.cb @@ -6,9 +6,6 @@ chip cpu/intel/socket_LGA775 device lapic 0 on end end - chip cpu/intel/model_1067x # CPU - device lapic 0xacac off end - end end device domain 0 on ops x4x_pci_domain_ops # PCI domain diff --git a/src/mainboard/asus/p5qc/variants/p5qc/devicetree.cb b/src/mainboard/asus/p5qc/variants/p5qc/devicetree.cb index 70e82e8..54f9dcf 100644 --- a/src/mainboard/asus/p5qc/variants/p5qc/devicetree.cb +++ b/src/mainboard/asus/p5qc/variants/p5qc/devicetree.cb @@ -6,9 +6,6 @@ chip cpu/intel/socket_LGA775 device lapic 0 on end end - chip cpu/intel/model_1067x # CPU - device lapic 0xacac off end - end end device domain 0 on ops x4x_pci_domain_ops # PCI domain diff --git a/src/mainboard/asus/p5qc/variants/p5ql_pro/devicetree.cb b/src/mainboard/asus/p5qc/variants/p5ql_pro/devicetree.cb index 8390bc0..f099ab2 100644 --- a/src/mainboard/asus/p5qc/variants/p5ql_pro/devicetree.cb +++ b/src/mainboard/asus/p5qc/variants/p5ql_pro/devicetree.cb @@ -6,9 +6,6 @@ chip cpu/intel/socket_LGA775 device lapic 0 on end end - chip cpu/intel/model_1067x # CPU - device lapic 0xacac off end - end end device domain 0 on ops x4x_pci_domain_ops # PCI domain diff --git a/src/mainboard/asus/p5ql-em/devicetree.cb b/src/mainboard/asus/p5ql-em/devicetree.cb index a839b9d..8e061f2 100644 --- a/src/mainboard/asus/p5ql-em/devicetree.cb +++ b/src/mainboard/asus/p5ql-em/devicetree.cb @@ -6,9 +6,6 @@ chip cpu/intel/socket_LGA775 device lapic 0 on end end - chip cpu/intel/model_1067x # CPU - device lapic 0xacac off end - end end device domain 0 on ops x4x_pci_domain_ops # PCI domain diff --git a/src/mainboard/asus/p5qpl-am/devicetree.cb b/src/mainboard/asus/p5qpl-am/devicetree.cb index 82b1c61..57d0b8f 100644 --- a/src/mainboard/asus/p5qpl-am/devicetree.cb +++ b/src/mainboard/asus/p5qpl-am/devicetree.cb @@ -6,9 +6,6 @@ chip cpu/intel/socket_LGA775 device lapic 0 on end end - chip cpu/intel/model_1067x # CPU - device lapic 0xacac off end - end end device domain 0 on ops x4x_pci_domain_ops # PCI domain diff --git a/src/mainboard/foxconn/g41s-k/devicetree.cb b/src/mainboard/foxconn/g41s-k/devicetree.cb index 578f13d..f0f9056 100644 --- a/src/mainboard/foxconn/g41s-k/devicetree.cb +++ b/src/mainboard/foxconn/g41s-k/devicetree.cb @@ -6,9 +6,6 @@ chip cpu/intel/socket_LGA775 device lapic 0 on end end - chip cpu/intel/model_1067x # CPU - device lapic 0xACAC off end - end end device domain 0 on ops x4x_pci_domain_ops # PCI domain diff --git a/src/mainboard/gigabyte/ga-945gcm-s2l/devicetree.cb b/src/mainboard/gigabyte/ga-945gcm-s2l/devicetree.cb index 28af26f..c30f272 100644 --- a/src/mainboard/gigabyte/ga-945gcm-s2l/devicetree.cb +++ b/src/mainboard/gigabyte/ga-945gcm-s2l/devicetree.cb @@ -7,9 +7,6 @@ chip cpu/intel/socket_LGA775 device lapic 0 on end end - chip cpu/intel/model_1067x - device lapic 0xACAC off end - end end
register "pci_mmio_size" = "768" diff --git a/src/mainboard/gigabyte/ga-g41m-es2l/devicetree.cb b/src/mainboard/gigabyte/ga-g41m-es2l/devicetree.cb index d216863..eef02ec 100644 --- a/src/mainboard/gigabyte/ga-g41m-es2l/devicetree.cb +++ b/src/mainboard/gigabyte/ga-g41m-es2l/devicetree.cb @@ -6,9 +6,6 @@ chip cpu/intel/socket_LGA775 device lapic 0 on end end - chip cpu/intel/model_1067x # CPU - device lapic 0xACAC off end - end end device domain 0 on ops x4x_pci_domain_ops # PCI domain diff --git a/src/mainboard/intel/dg41wv/devicetree.cb b/src/mainboard/intel/dg41wv/devicetree.cb index 9e5c136..e05e7f7 100644 --- a/src/mainboard/intel/dg41wv/devicetree.cb +++ b/src/mainboard/intel/dg41wv/devicetree.cb @@ -6,9 +6,6 @@ chip cpu/intel/socket_LGA775 device lapic 0 on end end - chip cpu/intel/model_1067x # CPU - device lapic 0xACAC off end - end end device domain 0 on ops x4x_pci_domain_ops # PCI domain diff --git a/src/mainboard/intel/dg43gt/devicetree.cb b/src/mainboard/intel/dg43gt/devicetree.cb index 5e2eb9d..80d2bf7 100644 --- a/src/mainboard/intel/dg43gt/devicetree.cb +++ b/src/mainboard/intel/dg43gt/devicetree.cb @@ -6,9 +6,6 @@ chip cpu/intel/socket_LGA775 device lapic 0 on end end - chip cpu/intel/model_1067x # CPU - device lapic 0xacac off end - end end device domain 0 on ops x4x_pci_domain_ops # PCI domain diff --git a/src/mainboard/lenovo/t400/devicetree.cb b/src/mainboard/lenovo/t400/devicetree.cb index b50e28d..38b1df2 100644 --- a/src/mainboard/lenovo/t400/devicetree.cb +++ b/src/mainboard/lenovo/t400/devicetree.cb @@ -8,22 +8,13 @@ register "gpu_panel_power_backlight_off_delay" = "2500" # Tx: 250ms register "gpu_panel_power_cycle_delay" = "3" # T4: 200ms
+ register "slfm" = "1" + device cpu_cluster 0 on ops gm45_cpu_bus_ops chip cpu/intel/socket_p device lapic 0 on end end - chip cpu/intel/model_1067x - # Magic APIC ID to locate this chip - device lapic 0xACAC off end - - # Enable Super LFM - register "slfm" = "1" - - # Enable C5, C6 - register "c5" = "1" - register "c6" = "1" - end end
register "pci_mmio_size" = "2048" diff --git a/src/mainboard/lenovo/thinkcentre_a58/devicetree.cb b/src/mainboard/lenovo/thinkcentre_a58/devicetree.cb index a4b9ac8..fb14fa5 100644 --- a/src/mainboard/lenovo/thinkcentre_a58/devicetree.cb +++ b/src/mainboard/lenovo/thinkcentre_a58/devicetree.cb @@ -6,9 +6,6 @@ chip cpu/intel/socket_LGA775 device lapic 0 on end end - chip cpu/intel/model_1067x # CPU - device lapic 0xACAC off end - end end device domain 0 on ops x4x_pci_domain_ops # PCI domain diff --git a/src/mainboard/lenovo/x200/devicetree.cb b/src/mainboard/lenovo/x200/devicetree.cb index f335624..977387b 100644 --- a/src/mainboard/lenovo/x200/devicetree.cb +++ b/src/mainboard/lenovo/x200/devicetree.cb @@ -8,22 +8,13 @@ register "gpu_panel_power_backlight_off_delay" = "2500" # Tx: 250ms register "gpu_panel_power_cycle_delay" = "3" # T4: 200ms
+ register "slfm" = "1" + device cpu_cluster 0 on ops gm45_cpu_bus_ops chip cpu/intel/socket_BGA956 device lapic 0 on end end - chip cpu/intel/model_1067x - # Magic APIC ID to locate this chip - device lapic 0xACAC off end - - # Enable Super LFM - register "slfm" = "1" - - # Enable C5, C6 - register "c5" = "1" - register "c6" = "1" - end end
register "pci_mmio_size" = "2048" diff --git a/src/mainboard/roda/rk9/devicetree.cb b/src/mainboard/roda/rk9/devicetree.cb index 7e53df8..f0dd425 100644 --- a/src/mainboard/roda/rk9/devicetree.cb +++ b/src/mainboard/roda/rk9/devicetree.cb @@ -1,22 +1,12 @@ chip northbridge/intel/gm45 # IGD Displays register "gfx" = "GMA_STATIC_DISPLAYS(0)" + register "slfm" = "1" device cpu_cluster 0 on ops gm45_cpu_bus_ops chip cpu/intel/socket_BGA956 device lapic 0 on end end - chip cpu/intel/model_1067x - # Magic APIC ID to locate this chip - device lapic 0xACAC off end - - # Enable Super LFM - register "slfm" = "1" - - # Enable C5, C6 - register "c5" = "1" - register "c6" = "1" - end end
register "pci_mmio_size" = "2048" diff --git a/src/northbridge/intel/gm45/chip.h b/src/northbridge/intel/gm45/chip.h index 0d09bb4..76cecca 100644 --- a/src/northbridge/intel/gm45/chip.h +++ b/src/northbridge/intel/gm45/chip.h @@ -19,6 +19,7 @@ * Maximum PCI mmio size in MiB. */ u16 pci_mmio_size; + int slfm; };
#endif /* NORTHBRIDGE_INTEL_GM45_CHIP_H */ diff --git a/src/northbridge/intel/gm45/northbridge.c b/src/northbridge/intel/gm45/northbridge.c index 31e3de4..c6fa0e0 100644 --- a/src/northbridge/intel/gm45/northbridge.c +++ b/src/northbridge/intel/gm45/northbridge.c @@ -7,6 +7,7 @@ #include <commonlib/helpers.h> #include <console/console.h> #include <cpu/cpu.h> +#include <cpu/intel/speedstep.h> #include <cpu/intel/smm_reloc.h> #include <device/device.h> #include <device/pci_def.h> @@ -257,3 +258,10 @@ CHIP_NAME("Intel GM45 Northbridge") .init = gm45_init, }; + +bool northbridge_support_slfm(void) +{ + struct device *gmch = __pci_0_00_0; + struct northbridge_intel_gm45_config *config = gmch->chip_info; + return config->slfm == 1; +} diff --git a/src/northbridge/intel/i945/northbridge.c b/src/northbridge/intel/i945/northbridge.c index c175576..0027656 100644 --- a/src/northbridge/intel/i945/northbridge.c +++ b/src/northbridge/intel/i945/northbridge.c @@ -10,6 +10,7 @@ #include <device/pci_ids.h> #include <acpi/acpi.h> #include <cpu/intel/smm_reloc.h> +#include <cpu/intel/speedstep.h> #include "i945.h"
static void mch_domain_read_resources(struct device *dev) @@ -164,3 +165,8 @@ struct chip_operations northbridge_intel_i945_ops = { CHIP_NAME("Intel i945 Northbridge") }; + +bool northbridge_support_slfm(void) +{ + return false; +} diff --git a/src/northbridge/intel/x4x/northbridge.c b/src/northbridge/intel/x4x/northbridge.c index da046d1..cfa57ad 100644 --- a/src/northbridge/intel/x4x/northbridge.c +++ b/src/northbridge/intel/x4x/northbridge.c @@ -12,6 +12,7 @@ #include <northbridge/intel/x4x/chip.h> #include <northbridge/intel/x4x/x4x.h> #include <cpu/intel/smm_reloc.h> +#include <cpu/intel/speedstep.h>
static void mch_domain_read_resources(struct device *dev) { @@ -194,3 +195,8 @@ CHIP_NAME("Intel 4-Series Northbridge") .init = x4x_init, }; + +bool northbridge_support_slfm(void) +{ + return false; +} diff --git a/src/southbridge/intel/i82801gx/lpc.c b/src/southbridge/intel/i82801gx/lpc.c index 4d82706..18443cc 100644 --- a/src/southbridge/intel/i82801gx/lpc.c +++ b/src/southbridge/intel/i82801gx/lpc.c @@ -1,5 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0-only */
+#include <cpu/intel/speedstep.h> #include <console/console.h> #include <device/device.h> #include <device/pci.h> @@ -486,3 +487,13 @@ .vendor = PCI_VID_INTEL, .devices = pci_device_ids, }; + +bool southbridge_support_c5(void) +{ + return false; +} + +bool southbridge_support_c6(void) +{ + return false; +} diff --git a/src/southbridge/intel/i82801ix/lpc.c b/src/southbridge/intel/i82801ix/lpc.c index e39c95a..a5e70fb 100644 --- a/src/southbridge/intel/i82801ix/lpc.c +++ b/src/southbridge/intel/i82801ix/lpc.c @@ -1,5 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0-only */
+#include <cpu/intel/speedstep.h> #include <console/console.h> #include <device/device.h> #include <device/pci.h> @@ -137,6 +138,20 @@ pci_write_config32(dev, D31F0_GPIO_ROUT, reg32); }
+bool southbridge_support_c5(void) +{ + struct device *lpc_dev = __pci_0_1f_0; + struct southbridge_intel_i82801ix_config *config = lpc_dev->chip_info; + return config->c5_enable == 1; +} + +bool southbridge_support_c6(void) +{ + struct device *lpc_dev = __pci_0_1f_0; + struct southbridge_intel_i82801ix_config *config = lpc_dev->chip_info; + return config->c6_enable == 1; +} + static void i82801ix_power_options(struct device *dev) { u8 reg8; @@ -216,15 +231,15 @@ reg16 |= (1 << 10); // BIOS_PCI_EXP_EN - Desktop/Mobile only if (CONFIG(DEBUG_PERIODIC_SMI)) reg16 |= (3 << 0); // Periodic SMI every 8s - if (config->c5_enable) + if (southbridge_support_c5()) reg16 |= (1 << 11); /* Enable C5, C6 and PMSYNC# */ pci_write_config16(dev, D31F0_GEN_PMCON_1, reg16);
/* Set exit timings for C5/C6. */ - if (config->c5_enable) { + if (southbridge_support_c5()) { reg8 = pci_read_config8(dev, D31F0_C5_EXIT_TIMING); reg8 &= ~((7 << 3) | (7 << 0)); - if (config->c6_enable) + if (southbridge_support_c6()) reg8 |= (5 << 3) | (3 << 0); /* 38-44us PMSYNC# to STPCLK#, 95-102us DPRSTP# to STP_CPU# */ else diff --git a/src/southbridge/intel/i82801jx/lpc.c b/src/southbridge/intel/i82801jx/lpc.c index 41bcccd..301c0d5 100644 --- a/src/southbridge/intel/i82801jx/lpc.c +++ b/src/southbridge/intel/i82801jx/lpc.c @@ -13,6 +13,7 @@ #include <arch/ioapic.h> #include <acpi/acpi.h> #include <cpu/x86/smm.h> +#include <cpu/intel/speedstep.h> #include <acpi/acpigen.h> #include <arch/smp/mpspec.h> #include "chip.h" @@ -139,6 +140,20 @@ pci_write_config32(dev, D31F0_GPIO_ROUT, reg32); }
+bool southbridge_support_c5(void) +{ + struct device *lpc_dev = __pci_0_1f_0; + struct southbridge_intel_i82801jx_config *config = lpc_dev->chip_info; + return config->c5_enable == 1; +} + +bool southbridge_support_c6(void) +{ + struct device *lpc_dev = __pci_0_1f_0; + struct southbridge_intel_i82801jx_config *config = lpc_dev->chip_info; + return config->c6_enable == 1; +} + static void i82801jx_power_options(struct device *dev) { u8 reg8; @@ -218,15 +233,15 @@ reg16 |= (1 << 10); // BIOS_PCI_EXP_EN - Desktop/Mobile only if (CONFIG(DEBUG_PERIODIC_SMI)) reg16 |= (3 << 0); // Periodic SMI every 8s - if (config->c5_enable) + if (southbridge_support_c5()) reg16 |= (1 << 11); /* Enable C5, C6 and PMSYNC# */ pci_write_config16(dev, D31F0_GEN_PMCON_1, reg16);
