Attention is currently required from: Felix Held, Jason Glenesk.
Fred Reitberger has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/76094?usp=email )
Change subject: mb/amd/birman/Kconfig: Select SPI_FLASH_EXIT_4_BYTE_ADDR_MODE_ALWAYS ......................................................................
Always exit 4-byte addressing mode to prevent errors when the spi flash is not left in 4-byte addressing mode.
Signed-off-by: Fred Reitberger reitbergerfred@gmail.com Change-Id: I9884b85bc3b0a9b654a2cb91fb314b0869abd622 --- M src/mainboard/amd/birman/Kconfig 1 file changed, 2 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/94/76094/1
diff --git a/src/mainboard/amd/birman/Kconfig b/src/mainboard/amd/birman/Kconfig index d7fd1a5..95115ee 100644 --- a/src/mainboard/amd/birman/Kconfig +++ b/src/mainboard/amd/birman/Kconfig @@ -15,7 +15,8 @@ select PCIEXP_L1_SUB_STATE select SOC_AMD_COMMON_BLOCK_ESPI_RETAIN_PORT80_EN if !SOC_AMD_COMMON_BLOCK_SIMNOW_BUILD select SOC_AMD_COMMON_BLOCK_SIMNOW_SUPPORTED - select SPI_FLASH_FORCE_4_BYTE_ADDR_MODE + select SPI_FLASH_EXIT_4_BYTE_ADDR_MODE + select SPI_FLASH_EXIT_4_BYTE_ADDR_MODE_ALWAYS
config FMDFILE default "src/mainboard/amd/birman/chromeos_glinda.fmd" if CHROMEOS && BOARD_AMD_BIRMAN_GLINDA
