the following patch was just integrated into master: commit f44319c12d4dc228cc193233b422c4afafe480bd Author: Vadim Bendebury vbendeb@chromium.org Date: Tue Nov 4 16:17:33 2014 -0800
util/bimgtool: Add verification mode
When only one argument is passed on the command line, consider this argument the name of the BIMG formatted file, and verify its integrity.
Update the help/usage text to match new behavior.
BRANCH=none BUG=none
TEST=when the corrupted coreboot BIMG image is passed as the only argument, this utility reports the problem. With the build fixed, the check passes without errors (the second invocation below).
$ build/util/bimgtool/bimgtool /build/urara/firmware/coreboot.rom.serial Data header CRC mismatch at 0 $ build/util/bimgtool/bimgtool /build/urara/firmware/coreboot.rom.serial $
Change-Id: I9f0672caa38e3d27917471fc5137ede4ca466e9a Signed-off-by: Patrick Georgi pgeorgi@chromium.org Original-Commit-Id: 3e631c311dbf2fb04714e437f95c41629155527f Original-Change-Id: Ie56f87f99838891d8e341d7989c614efbcabe0cd Original-Signed-off-by: Vadim Bendebury vbendeb@chromium.org Original-Reviewed-on: https://chromium-review.googlesource.com/227522 Original-Reviewed-by: Zdenko Pulitika zdenko.pulitika@imgtec.com Original-Tested-by: Ionela Voinescu ionela.voinescu@imgtec.com Reviewed-on: http://review.coreboot.org/9452 Tested-by: build bot (Jenkins) Reviewed-by: Paul Menzel paulepanter@users.sourceforge.net Reviewed-by: Stefan Reinauer stefan.reinauer@coreboot.org
See http://review.coreboot.org/9452 for details.
