Patrick Georgi (patrick@georgi-clan.de) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/4498
commit 9b1277db22f05abd02b299c02b639360df65787b Author: Rudolf Marek r.marek@assembler.cz Date: Sat Dec 7 22:34:24 2013 +0100
Implement proper IT8728F PNP ops
The Asus F2A85-M has IT8306E which is a stripped down version of this SIO. Implement the PNP SIO ops and do the HWM setup. If there is future user implement some config option for devicetree.cb. Implement missing early calls needed for F2A85-M.
Change-Id: Ibc4f3fafc3ffb1cd799948e63be01e6924b45d6c Signed-off-by: Rudolf Marek r.marek@assembler.cz --- src/superio/ite/it8728f/Makefile.inc | 2 + src/superio/ite/it8728f/chip.h | 33 ++++++++ src/superio/ite/it8728f/early_serial.c | 23 ++++++ src/superio/ite/it8728f/early_serial.h | 3 + src/superio/ite/it8728f/it8728f.h | 2 + src/superio/ite/it8728f/superio.c | 141 +++++++++++++++++++++++++++++++++ 6 files changed, 204 insertions(+)
diff --git a/src/superio/ite/it8728f/Makefile.inc b/src/superio/ite/it8728f/Makefile.inc index d8d4f6a..46fd40a 100644 --- a/src/superio/ite/it8728f/Makefile.inc +++ b/src/superio/ite/it8728f/Makefile.inc @@ -19,3 +19,5 @@ ##
romstage-$(CONFIG_SUPERIO_ITE_IT8728F) += early_serial.c +ramstage-$(CONFIG_SUPERIO_ITE_IT8728F) += superio.c + diff --git a/src/superio/ite/it8728f/chip.h b/src/superio/ite/it8728f/chip.h new file mode 100644 index 0000000..8013531 --- /dev/null +++ b/src/superio/ite/it8728f/chip.h @@ -0,0 +1,33 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2006 Uwe Hermann uwe@hermann-uwe.de + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#ifndef SUPERIO_ITE_IT8728F_CHIP_H +#define SUPERIO_ITE_IT8728F_CHIP_H + +#include <device/device.h> +#include <pc80/keyboard.h> +#include <uart8250.h> + +struct superio_ite_it8728f_config { + + struct pc_keyboard keyboard; +}; + +#endif diff --git a/src/superio/ite/it8728f/early_serial.c b/src/superio/ite/it8728f/early_serial.c index 7fbd061..78a49aa 100644 --- a/src/superio/ite/it8728f/early_serial.c +++ b/src/superio/ite/it8728f/early_serial.c @@ -69,3 +69,26 @@ void it8728f_enable_serial(device_t dev, u16 iobase) /* (3) Exit the configuration state (MB PnP mode). */ it8728f_exit_conf(dev); } + +/* + * We need to set enable 3VSBSW#, this was documented only in IT8712F_V0.9.2! + * + * LDN 7, reg 0x2a - needed for S3, or memory power will be cut off. + * + * Enable 3VSBSW#. (For System Suspend-to-RAM) + * 0: 3VSBSW# will be always inactive. + * 1: 3VSBSW# enabled. It will be (NOT SUSB#) NAND SUSC#. + */ +void it8728f_enable_3vsbsw(device_t dev) +{ + it8728f_enter_conf(dev); + it8728f_sio_write(dev, IT8728F_CONFIG_REG_MFC, 0x80); + it8728f_exit_conf(dev); +} + +void it8728f_kill_watchdog(device_t dev) +{ + it8728f_enter_conf(dev); + it8728f_sio_write(dev, IT8728F_CONFIG_REG_WATCHDOG, 0x00); + it8728f_exit_conf(dev); +} diff --git a/src/superio/ite/it8728f/early_serial.h b/src/superio/ite/it8728f/early_serial.h index a146f4c..3443e0d 100644 --- a/src/superio/ite/it8728f/early_serial.h +++ b/src/superio/ite/it8728f/early_serial.h @@ -37,4 +37,7 @@ void it8728f_24mhz_clkin(device_t dev); /* Enable the serial port(s). */ void it8728f_enable_serial(device_t dev, u16 iobase);
+void it8728f_kill_watchdog(device_t dev); +void it8728f_enable_3vsbsw(device_t dev); + #endif diff --git a/src/superio/ite/it8728f/it8728f.h b/src/superio/ite/it8728f/it8728f.h index 603e467..9a92f5a 100644 --- a/src/superio/ite/it8728f/it8728f.h +++ b/src/superio/ite/it8728f/it8728f.h @@ -38,5 +38,7 @@ #define IT8728F_CONFIG_REG_CHIPVERS 0x22 /* Chip version */ #define IT8728F_CONFIG_REG_CLOCKSEL 0x23 /* Clock Selection. */ #define IT8728F_CONFIG_REG_SWSUSP 0x24 /* Software Suspend, Flash I/F. 'Special register' */ +#define IT8728F_CONFIG_REG_WATCHDOG 0x72 /* Watchdog control. */ +#define IT8728F_CONFIG_REG_MFC 0x2a /* Multi-function control */
#endif diff --git a/src/superio/ite/it8728f/superio.c b/src/superio/ite/it8728f/superio.c new file mode 100644 index 0000000..67699fa --- /dev/null +++ b/src/superio/ite/it8728f/superio.c @@ -0,0 +1,141 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2006 Uwe Hermann uwe@hermann-uwe.de + * Copyright (C) 2007 Philipp Degler pdegler@rumms.uni-mannheim.de + * Copyright (C) 2013 Rudolf Marek r.marek@assembler.cz + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <device/device.h> +#include <device/pnp.h> +#include <uart8250.h> +#include <pc80/keyboard.h> +#include <arch/io.h> +#include <stdlib.h> +#include "chip.h" +#include "it8728f.h" + +static void pnp_enter_ext_func_mode(device_t dev) +{ + u16 port = dev->path.pnp.port; + + outb(0x87, port); + outb(0x01, port); + outb(0x55, port); + outb((port == 0x4e) ? 0xaa : 0x55, port); +} + +static void pnp_exit_ext_func_mode(device_t dev) +{ + pnp_write_config(dev, 0x02, 0x02); +} + +static u8 hwm_read(u16 base, u8 reg) +{ + outb(reg, base + 5); + return inb(base + 6); +} + +static void hwm_write(u16 base, u8 reg, u8 val) +{ + outb(reg, base + 5); + outb(val, base + 6); +} + +static void it8728f_init(device_t dev) +{ + struct superio_ite_it8728f_config *conf = dev->chip_info; + + if (!dev->enabled) + return; + + switch (dev->path.pnp.device) { + case IT8728F_FDC: /* TODO. */ + break; + case IT8728F_PP: /* TODO. */ + break; + case IT8728F_EC: + { + /* keep it simple for now, configuration options may come later */ + u8 tmp; + u16 base; + pnp_enter_ext_func_mode(dev); + pnp_set_logical_device(dev); + /* there must be better way to read the I/O base */ + base = ((u16) pnp_read_config(dev, 0x60) << 8); + base |= pnp_read_config(dev, 0x61); + tmp = hwm_read(base, 0x14); + /* setup fan polarity */ + hwm_write(base, 0x14, tmp | (1 << 7)); + /* enable fans 1-3 */ + tmp = hwm_read(base, 0x13); + hwm_write(base, 0x13, tmp | (7 << 4)); + /* enable termistor temps for temp1-temp3 */ + tmp = hwm_read(base, 0x51); + hwm_write(base, 0x51, tmp | (7 << 3)); + /* fan2 is using temp1 */ + hwm_write(base, 0x16, 0x80); + pnp_exit_ext_func_mode(dev); + break; + } + case IT8728F_KBCK: + set_kbc_ps2_mode(); + pc_keyboard_init(&conf->keyboard); + break; + case IT8728F_KBCM: /* TODO. */ + break; + case IT8728F_IR: /* TODO. */ + break; + } +} + +static const struct pnp_mode_ops pnp_conf_mode_ops = { + .enter_conf_mode = pnp_enter_ext_func_mode, + .exit_conf_mode = pnp_exit_ext_func_mode, +}; + +static struct device_operations ops = { + .read_resources = pnp_read_resources, + .set_resources = pnp_set_resources, + .enable_resources = pnp_enable_resources, + .enable = pnp_alt_enable, + .init = it8728f_init, + .ops_pnp_mode = &pnp_conf_mode_ops, +}; + +static struct pnp_info pnp_dev_info[] = { + { &ops, IT8728F_FDC, PNP_IO0 | PNP_IRQ0 | PNP_DRQ0, {0x0ff8, 0}, }, + { &ops, IT8728F_SP1, PNP_IO0 | PNP_IRQ0, {0x0ff8, 0}, }, + { &ops, IT8728F_SP2, PNP_IO0 | PNP_IRQ0, {0x0ff8, 0}, }, + { &ops, IT8728F_PP, PNP_IO0 | PNP_IRQ0 | PNP_DRQ0, {0x0ffc, 0}, }, + { &ops, IT8728F_EC, PNP_IO0 | PNP_IO1 | PNP_IRQ0, {0x0ff8, 0}, {0x0ff8, 4}, }, + { &ops, IT8728F_KBCK, PNP_IO0 | PNP_IO1 | PNP_IRQ0, {0x0fff, 0}, {0x0fff, 4}, }, + { &ops, IT8728F_KBCM, PNP_IRQ0, }, + { &ops, IT8728F_GPIO, PNP_IO0 | PNP_IO1 | PNP_IO2 | PNP_IRQ0, {0x0fff, 0}, {0x0ff8, 0}, {0x0ff8, 0}, }, + { &ops, IT8728F_IR, PNP_IO0 | PNP_IRQ0, {0x0ff8, 0}, }, +}; + +static void enable_dev(struct device *dev) +{ + pnp_enable_devices(dev, &pnp_ops, + ARRAY_SIZE(pnp_dev_info), pnp_dev_info); +} + +struct chip_operations superio_ite_it8728f_ops = { + CHIP_NAME("ITE IT8728F Super I/O") + .enable_dev = enable_dev, +};
