Attention is currently required from: Karthik Ramasubramanian, Gwendal Grignou. Hello build bot (Jenkins), Tim Wawrzynczak, SH Kim, Paul Menzel, Karthik Ramasubramanian,
https://review.coreboot.org/c/coreboot/+/59608
Change subject: driver/i2c: Add sx9360 driver ......................................................................
Add driver for setting up Semtech sx9360 SAR sensor. The driver is based on sx9310.c. The core of the driver is the same, but the bindings are slightly different.
Registers are documented in the kernel tree: Documentation/devicetree/bindings/iio/proximity/semtech,sx9360.yaml [https://patchwork.kernel.org/project/linux-iio/patch/20211213024057.3824985-...]
Signed-off-by: Seunghwan Kim sh_.kim@samsung.corp-partner.google.com Signed-off-by: Gwendal Grignou gwendal@chromium.org Change-Id: I0a912f184e6f3501f894cca24c0d71a2c3087516 --- A src/drivers/i2c/sx9360/Kconfig A src/drivers/i2c/sx9360/Makefile.inc A src/drivers/i2c/sx9360/chip.h A src/drivers/i2c/sx9360/sx9360.c 4 files changed, 154 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/08/59608/6
