Angel Pons has submitted this change. ( https://review.coreboot.org/c/coreboot/+/55490 )
Change subject: soc/intel/broadwell: Separate PCH Kconfig ......................................................................
Split up PCH Kconfig into a separate file. While we're at it, also sort selected options alphabetically.
Tested with BUILD_TIMELESS=1, coreboot.rom for the Purism Librem 13 v1 remains identical when not adding the .config file in it.
Change-Id: Ic3ff982e7108bf2d25a22e56ac2fbb93070df164 Signed-off-by: Angel Pons th3fanbus@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/55490 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Arthur Heymans arthur@aheymans.xyz --- M src/soc/intel/broadwell/Kconfig A src/soc/intel/broadwell/pch/Kconfig 2 files changed, 72 insertions(+), 68 deletions(-)
Approvals: build bot (Jenkins): Verified Arthur Heymans: Looks good to me, approved
diff --git a/src/soc/intel/broadwell/Kconfig b/src/soc/intel/broadwell/Kconfig index 593b13a..6979e2a 100644 --- a/src/soc/intel/broadwell/Kconfig +++ b/src/soc/intel/broadwell/Kconfig @@ -5,58 +5,14 @@
if SOC_INTEL_BROADWELL
-config INTEL_LYNXPOINT_LP - bool - default y if SOC_INTEL_BROADWELL - config SOC_SPECIFIC_OPTIONS def_bool y - select ACPI_INTEL_HARDWARE_SLEEP_VALUES - select ACPI_SOC_NVS - select AZALIA_PLUGIN_SUPPORT - select BOOT_DEVICE_SUPPORTS_WRITES select CACHE_MRC_SETTINGS select CPU_INTEL_HASWELL - select MRC_SETTINGS_PROTECT select HAVE_DISPLAY_MTRRS - select HAVE_SMI_HANDLER - select SOUTHBRIDGE_INTEL_COMMON_ACPI_MADT - select SOUTHBRIDGE_INTEL_COMMON_EARLY_SMBUS - select SOUTHBRIDGE_INTEL_COMMON_RESET - select SOUTHBRIDGE_INTEL_COMMON_RTC - select SOUTHBRIDGE_INTEL_COMMON_SMBUS - select SOUTHBRIDGE_INTEL_COMMON_SPI_ICH9 - select HAVE_USBDEBUG - select IOAPIC - select INTEL_LYNXPOINT_LP - select REG_SCRIPT - select RTC - select SPI_FLASH - select INTEL_DESCRIPTOR_MODE_CAPABLE - select HAVE_EM100PRO_SPI_CONSOLE_SUPPORT select INTEL_GMA_ACPI - select HAVE_POWER_STATE_AFTER_FAILURE - select HAVE_POWER_STATE_PREVIOUS_AFTER_FAILURE - -config PCIEXP_ASPM - bool - default y - -config PCIEXP_AER - bool - default y - -config PCIEXP_COMMON_CLOCK - bool - default y - -config PCIEXP_CLK_PM - bool - default y - -config PCIEXP_L1_SUB_STATE - bool - default y + select MRC_SETTINGS_PROTECT + select REG_SCRIPT
config BROADWELL_VBOOT_IN_BOOTBLOCK depends on VBOOT @@ -152,28 +108,6 @@
endif # HAVE_MRC
-config SERIALIO_UART_CONSOLE - bool - default n - select DRIVERS_UART_8250MEM_32 - help - Selected by mainboards where SerialIO UARTs can be used to retrieve - coreboot logs. Boards also need to set UART_FOR_CONSOLE accordingly. - -config CONSOLE_UART_BASE_ADDRESS - default 0xd6000000 if SERIALIO_UART_CONSOLE - -config EHCI_BAR - hex - default 0xd8000000 - -config SERIRQ_CONTINUOUS_MODE - bool - default y - help - If you set this option to y, the serial IRQ machine will be - operated in continuous mode. - config HAVE_REFCODE_BLOB depends on ARCH_X86 bool "An external reference code blob should be put into cbfs." @@ -191,4 +125,6 @@
endif # HAVE_REFCODE_BLOB
+source "src/soc/intel/broadwell/pch/Kconfig" + endif diff --git a/src/soc/intel/broadwell/pch/Kconfig b/src/soc/intel/broadwell/pch/Kconfig new file mode 100644 index 0000000..c743049 --- /dev/null +++ b/src/soc/intel/broadwell/pch/Kconfig @@ -0,0 +1,68 @@ +config INTEL_LYNXPOINT_LP + bool + default y if SOC_INTEL_BROADWELL + +config PCH_SPECIFIC_OPTIONS + def_bool y + select ACPI_INTEL_HARDWARE_SLEEP_VALUES + select ACPI_SOC_NVS + select AZALIA_PLUGIN_SUPPORT + select BOOT_DEVICE_SUPPORTS_WRITES + select HAVE_EM100PRO_SPI_CONSOLE_SUPPORT + select HAVE_POWER_STATE_AFTER_FAILURE + select HAVE_POWER_STATE_PREVIOUS_AFTER_FAILURE + select HAVE_SMI_HANDLER + select HAVE_USBDEBUG + select INTEL_DESCRIPTOR_MODE_CAPABLE + select INTEL_LYNXPOINT_LP + select IOAPIC + select RTC + select SOUTHBRIDGE_INTEL_COMMON_ACPI_MADT + select SOUTHBRIDGE_INTEL_COMMON_EARLY_SMBUS + select SOUTHBRIDGE_INTEL_COMMON_RESET + select SOUTHBRIDGE_INTEL_COMMON_RTC + select SOUTHBRIDGE_INTEL_COMMON_SMBUS + select SOUTHBRIDGE_INTEL_COMMON_SPI_ICH9 + select SPI_FLASH + +config EHCI_BAR + hex + default 0xd8000000 + +config SERIRQ_CONTINUOUS_MODE + bool + default y + help + If you set this option to y, the serial IRQ machine will be + operated in continuous mode. + +config PCIEXP_ASPM + bool + default y + +config PCIEXP_AER + bool + default y + +config PCIEXP_COMMON_CLOCK + bool + default y + +config PCIEXP_CLK_PM + bool + default y + +config PCIEXP_L1_SUB_STATE + bool + default y + +config SERIALIO_UART_CONSOLE + bool + default n + select DRIVERS_UART_8250MEM_32 + help + Selected by mainboards where SerialIO UARTs can be used to retrieve + coreboot logs. Boards also need to set UART_FOR_CONSOLE accordingly. + +config CONSOLE_UART_BASE_ADDRESS + default 0xd6000000 if SERIALIO_UART_CONSOLE
