Attention is currently required from: Dinesh Gehlot, Jayvik Desai.
Subrata Banik has posted comments on this change by Dinesh Gehlot. ( https://review.coreboot.org/c/coreboot/+/83667?usp=email )
Change subject: vc/google/chromeos/Kconfig: Enable config to determine eSOL status ......................................................................
Patch Set 3:
File src/vendorcode/google/chromeos/Kconfig:
https://review.coreboot.org/c/coreboot/+/83667/comment/180675e4_666e8594?usp... : PS3, Line 82: CHROMEOS_ENABLES_ESOL can we use this as a choice menu where, default `y` if libgfxinit (device/Kconfig) or uGOP (which could come from FSP driver) , otherwise `n`.
hence, the flow would be like
1. either mainboard or soc selects MAINBOARD_HAS_EARLY_LIBGFXINIT 2. or SOC_INTEL_METEORLAKE_SIGN_OF_LIFE would select the FSP Kconfig
no one needs to select this config because either #1 or #2 should set this Kconfig set to enable otherwise eSOL not enabled.
