Arthur Heymans (arthur@aheymans.xyz) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/16354
commit 6b3dcd0eeafc1367189146dd0ccf58c8bac9ad64 Author: Arthur Heymans arthur@aheymans.xyz Date: Tue Aug 30 13:42:33 2016 +0200
[NEEDS TESTING] lenovo/T400: correct GPIO for hybrid driver
Currently the hybrid driver uses GPIO 52 to configure mux. This is not the right GPIO on the T400 according to the schematics "MALIBU-3 EXT". It should be GPIO22.
The polarities on the gpio's are also set differently on Lenovo T400. On the Lenovo T400 HIGH on GPIO22 means enable.
Previously also gpio 49 (GFX_PWR_EN) and 19 (BKLT_CTRL_SEL), were configured for hybrid graphics to work on T400, but this was reverted in 14d1a93e: "Revert mainboard/lenovo/t400: Add initial hybrid graphics support". This patch sets those gpios correctly again for the Lenovo T400.
This also adds a IDG disable op, since it is used here to uncleam the VGA from the IGD.
Change-Id: I3167303abeb6b3711d53508c61a340d03b1e050a Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- src/drivers/lenovo/Kconfig | 5 +++++ src/drivers/lenovo/hybrid_graphics.c | 19 +++++++++++++++++-- src/mainboard/lenovo/t400/Kconfig | 16 ++++++++++++++++ src/mainboard/lenovo/t400/romstage.c | 12 ++++++++++++ src/northbridge/intel/gm45/gma.c | 13 +++++++++++++ 5 files changed, 63 insertions(+), 2 deletions(-)
diff --git a/src/drivers/lenovo/Kconfig b/src/drivers/lenovo/Kconfig index 38b86da..4c62de1 100644 --- a/src/drivers/lenovo/Kconfig +++ b/src/drivers/lenovo/Kconfig @@ -39,3 +39,8 @@ config HYBRID_GRAPHICS_GPIO_NUM help Set a default GPIO that sets the panel LVDS signal routing to integrated or discrete GPU. + +config ENABLE_DISCRETE_IS_HIGH + depends on DRIVERS_LENOVO_HYBRID_GRAPHICS + bool + default n diff --git a/src/drivers/lenovo/hybrid_graphics.c b/src/drivers/lenovo/hybrid_graphics.c index 9b46646..1560eb7 100644 --- a/src/drivers/lenovo/hybrid_graphics.c +++ b/src/drivers/lenovo/hybrid_graphics.c @@ -43,9 +43,18 @@ static void hybrid_graphics_disable_peg(struct device *dev) { struct device *peg_dev; + u8 disable_lvl = CONFIG_ENABLE_DISCRETE_IS_HIGH ? + GPIO_LEVEL_LOW : GPIO_LEVEL_HIGH;
/* connect LVDS interface to iGPU */ - set_gpio(CONFIG_HYBRID_GRAPHICS_GPIO_NUM, GPIO_LEVEL_HIGH); + set_gpio(CONFIG_HYBRID_GRAPHICS_GPIO_NUM, disable_lvl); + /* configure BKLT_CTL */ + if (CONFIG_BKLT_CTRL_SEL_GPIO) + set_gpio(CONFIG_BKLT_CTRL_SEL_GPIO, disable_lvl); + /* configure GFX_PWR_EN_GPIO */ + if (CONFIG_GFX_PWR_EN_GPIO) + set_gpio(CONFIG_GFX_PWR_EN_GPIO, disable_lvl); + printk(BIOS_DEBUG, "Hybrid graphics: Switching panel to integrated GPU.\n"); dev->enabled = 0;
@@ -62,13 +71,19 @@ static void hybrid_graphics_disable_peg(struct device *dev) static void hybrid_graphics_enable_peg(struct device *dev) { u8 hybrid_graphics_mode; + u8 enable_lvl = CONFIG_ENABLE_DISCRETE_IS_HIGH ? + GPIO_LEVEL_HIGH : GPIO_LEVEL_LOW;
hybrid_graphics_mode = HYBRID_GRAPHICS_INTEGRATED; get_option(&hybrid_graphics_mode, "hybrid_graphics_mode");
if (hybrid_graphics_mode == HYBRID_GRAPHICS_DISCRETE) { /* connect LVDS interface to dGPU */ - set_gpio(CONFIG_HYBRID_GRAPHICS_GPIO_NUM, GPIO_LEVEL_LOW); + set_gpio(CONFIG_HYBRID_GRAPHICS_GPIO_NUM, enable_lvl); + if (CONFIG_BKLT_CTRL_SEL_GPIO) + set_gpio(CONFIG_BKLT_CTRL_SEL_GPIO, enable_lvl); + if (CONFIG_GFX_PWR_EN_GPIO) + set_gpio(CONFIG_GFX_PWR_EN_GPIO, enable_lvl); printk(BIOS_DEBUG, "Hybrid graphics: Switching panel to discrete GPU.\n"); dev->enabled = 1;
diff --git a/src/mainboard/lenovo/t400/Kconfig b/src/mainboard/lenovo/t400/Kconfig index a444bf8..a136dd0 100644 --- a/src/mainboard/lenovo/t400/Kconfig +++ b/src/mainboard/lenovo/t400/Kconfig @@ -56,4 +56,20 @@ config ONBOARD_VGA_IS_PRIMARY bool default y
+config HYBRID_GRAPHICS_GPIO_NUM + int + default 22 + +config BKLT_CTRL_SEL_GPIO + int + default 19 + +config GFX_PWR_EN_GPIO + int + default 49 + +config ENABLE_DISCRETE_IS_HIGH + bool + default y + endif # BOARD_LENOVO_T400 diff --git a/src/mainboard/lenovo/t400/romstage.c b/src/mainboard/lenovo/t400/romstage.c index bba53d1..7cf0f90 100644 --- a/src/mainboard/lenovo/t400/romstage.c +++ b/src/mainboard/lenovo/t400/romstage.c @@ -35,6 +35,9 @@ #define LPC_DEV PCI_DEV(0, 0x1f, 0) #define MCH_DEV PCI_DEV(0, 0, 0)
+#define HYBRID_GRAPHICS_INT_CLAIM_VGA 0x2 +#define HYBRID_GRAPHICS_SEC_VGA_EN 0x2 + static void early_lpc_setup(void) { /* Set up SuperIO LPC forwards */ @@ -156,6 +159,15 @@ void mainboard_romstage_entry(unsigned long bist) outl(inl(DEFAULT_GPIOBASE + 0x38) & ~0x400, DEFAULT_GPIOBASE + 0x38);
cbmem_initted = !cbmem_recovery(s3resume); + + /* Enable dGPU. this is required for the Lenovo hybrid driver */ + reg16 = pci_read_config16(MCH_DEV, D0F0_GGC); + pci_write_config16(MCH_DEV, D0F0_GGC, + reg16 | HYBRID_GRAPHICS_INT_CLAIM_VGA); + reg16 = pci_read_config16(MCH_DEV, D0F0_DEVEN); + pci_write_config16(MCH_DEV, D0F0_DEVEN, + reg16 | HYBRID_GRAPHICS_SEC_VGA_EN); + #if CONFIG_HAVE_ACPI_RESUME /* If there is no high memory area, we didn't boot before, so * this is not a resume. In that case we just create the cbmem toc. diff --git a/src/northbridge/intel/gm45/gma.c b/src/northbridge/intel/gm45/gma.c index a89f9bb..18c770c 100644 --- a/src/northbridge/intel/gm45/gma.c +++ b/src/northbridge/intel/gm45/gma.c @@ -540,6 +540,18 @@ static struct pci_operations gma_pci_ops = { .set_subsystem = gma_set_subsystem, };
+static void gma_func0_disable(struct device *dev) +{ + u16 reg16; + device_t dev_host = dev_find_slot(0, PCI_DEVFN(0, 0)); + + reg16 = pci_read_config16(dev_host, D0F0_GGC); + reg16 |= (1 << 1); /* disable VGA decode */ + pci_write_config16(dev_host, D0F0_GGC, reg16); + + dev->enabled = 0; +} + static struct device_operations gma_func0_ops = { .read_resources = pci_dev_read_resources, .set_resources = pci_dev_set_resources, @@ -548,6 +560,7 @@ static struct device_operations gma_func0_ops = { .init = gma_func0_init, .scan_bus = 0, .enable = 0, + .disable = gma_func0_disable, .ops_pci = &gma_pci_ops, };
