Isaac Christensen (isaac.christensen@se-eng.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/6665
commit 108370ba6019904b832e88da3e0cb079ba192e1b Author: Isaac Christensen isaac.christensen@se-eng.com Date: Thu Aug 14 12:23:24 2014 -0600
libpayload: change cb_range to lb_range
Patch 'coreboot_tables: reduce redundant data structures' (1f5487a) added a new lb_range structure to coreboot and libpayload but the original chromium patch added cb_range to libpayload instead. A followup patch 'arm: libpayload: Add cache coherent DMA memory definition and management' (b8fad3d) used the incorrect cb_range structure but this wasn't caught since the current verification build doesn't build libpayload for arm.
Change-Id: I7cedc66a4794bf4daa214f54be6e917f96418ff6 Signed-off-by: Isaac Christensen isaac.christensen@se-eng.com --- payloads/libpayload/arch/armv7/coreboot.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/payloads/libpayload/arch/armv7/coreboot.c b/payloads/libpayload/arch/armv7/coreboot.c index e16c354..1397fc1 100644 --- a/payloads/libpayload/arch/armv7/coreboot.c +++ b/payloads/libpayload/arch/armv7/coreboot.c @@ -110,7 +110,7 @@ static void cb_parse_vdat(unsigned char *ptr, struct sysinfo_t *info)
static void cb_parse_dma(unsigned char *ptr) { - struct cb_range *dma = (struct cb_range *)ptr; + struct lb_range *dma = (struct lb_range *)ptr; init_dma_memory(phys_to_virt(dma->range_start), dma->range_size); }
